How about the consensus on the CPU at this time; should it/could it equal or best the abilities of the AC86U in handling OpenVPN encryption mgmt and thru-put speed??
Also, at the projected selling price point in Singapore, $500 sing. dollars, is it worth upgrading from AC86U.... I paid approx 300 sing dollars for the AC86U which I thought was a reasonable price over in this part of the planet.
Forgive my ignorance but is that different from downloading the firmware from Asus site? If not, the initial firmware is available to download.Too early to tell as there's no source code available to evaluate it.
tell us more and please post some pictures where GUI is different or enhanced to known 86UGot two of them in yesterday. Using one as my main router and the other as a bridge in another building. I'm getting 2-3 times the speed I was getting with 2 GT-AC5300's. Not assuming this means anything for possible firmware support but, doesn't look like theres any of the proprietary stuff the GT has:
Thats exactly what I supposed.Webui is almost identical to the RT-AC86U, except for the 802.11ax related settings.
Thanks. Our cat broke our RT-AC5300 the other day….. Guess that an RT-AC86U is the best choice at current….
usually throwing it down the shelf - you never had a catWhat did the Cat do to brake your router? I'm curious.
usually throwing it down the shelf - you never had a cat [emoji14]
But would be nice to see which 5G channels are supported and which are usable for 160/80/40/20 MHz bandwith, depending on region.
That does not mean that it is supported on this router by Asus!DFS channels are now supported in the US.
Since the list of channels will vary between region, it's kinda pointless to post a list, as it would obviously be specific to the region of the poster.
Otherwise they could be set on RT-AC68U or RT-AC86U too ...
Welcome To SNBForums
