120- 128 on 5ghz at 160 mhz are open for use, at least in the U.S. Attached a screen shot for you.Thats exactly what I supposed.
But would be nice to see which 5G channels are supported and which are usable for 160/80/40/20 MHz bandwith, depending on region.
There is no setting for Switzerland in Asus firmware, you would need to use EU (or something else) and with EU there are not ch. >149 supported at all.@all
I have the RT-AC88U and i might change to RT-AX88U in the future... but i wonder about the bandwidth "limitations".
I live in Switzerland so the Channels with higher Bandwidth are very limited.
If i'm not wrong there is "only" One Channel (155) with 80MHz Bandwidth but much lower power output (25mw?).
Is there a way for me to improve that in some way?
https://en.wikipedia.org/wiki/List_of_WLAN_channels#5_GHz_(802.11a/h/j/n/ac/ax)
"2-3 times the speed"; what exactly are these faster speeds you are referring to? What is faster...file transfers....what?Got two of them in yesterday. Using one as my main router and the other as a bridge in another building. I'm getting 2-3 times the speed I was getting with 2 GT-AC5300's. Not assuming this means anything for possible firmware support but, doesn't look like theres any of the proprietary stuff the GT has:
What is the file in download link used for?https://dlcdnets.asus.com/pub/ASUS/wireless/RT-AX88U/GPL_RT_AX88U_30043844730.zip
Released yesterday (today), 10/22/2018.
Looks to be a superior unit to netgear's version
https://wikidevi.com/wiki/Netgear_Jaguar_(Nighthawk_X12)
3 more ports and usb 3.1, not to mention twice the ram.
Great news, hopefully all works out and it can be included for future Merlin firmware updates. Can't wait to replace my ageing RT-AC87U with this one.Source code.
Maybe it's time to drop some of the older model routers in favor of the incoming AX models.
Is there a possibility that all routers will merge to this new code in future updates?
Good god, that is one ridiculous looking router. For $450 better to use a real firewall (pfsense, sophos, sonicwall, etc), and some ap's.
Wanted to post the same, so that mr RMerlin could take a look into the source
Right now I can't seem to use my AX88U actively in my current setup because of some vlan issues. With merlin fw on my AC87U I just need to set my vlan for the phone box and it works flawlessly. With the Asus firmware on the AX88U it somehow doesn't quite work, it connects a bit but the phone somehow doesn't work. I haven't quite figured out what the difference is yet. One thing I noticed that robocfg is no longer present, I'm not sure which tool replaces it however.
In the mean time I'm trying to get it sorted together with Asus, but I also report myself for active testing if any (hopefully) merlin firmware comes along![]()
Welcome To SNBForums
