May I assume this port can be used for WAN/Internet? I have a Comcast XFinity XB7 (bridge mode) with 2.5Gbps port and I'm looking to upgrade to a router that has 2.5Gbps internet ethernet interface. RT-AX89X says 10Gbps so I am going to assume this port is also able to negotiate 2.5Gbps. Either that or I go with the RT-AX86U coming out soon which has a 2.5Gbps port.Yep, same as I'm using the 2.5gb port on the ax1100 for my nas and ax wifi cards for pumping 4k rips through the house to multiple devices simultaniously quite happily with bandwidth to spare
You're using it on the LAN with your NAS and I'm looking for a port to use upstream to the Xfinity modem. The specs say WAN/LAN for that port. My only concern is that it won't negotiate 2.5Gbps with the Comcast modem.
