RT-AX88U : TX throughput problem
yeah it was already forced on 160mhz since day one.
@andywee show the current power Wifi and region
2.4Hz
wl -i eth6 txpwr_adj_est
5Hz
wl -i eth7 txpwr_adj_est
region
nvram show | grep -E 'territory_code|ccode|regrev|regulation|wl[0-9]_country|wl[0-9]_reg_mode|:max' | sort
2.4Hz
5Hz
region
ASUSWRT-Merlin RT-AX88U 386.2_6 Sun Jun 6 16:35:13 UTC 2021
admin@RT-AX88U:/tmp/home/root# wl -i eth6 txpwr_adj_est
Last adjusted est. power (chanspec:0x1808): 24.25 24.00 24.00 24.00
admin@RT-AX88U:/tmp/home/root# wl -i eth7 txpwr_adj_est
Last adjusted est. power (chanspec:0xe832): 18.75 19.50 19.75 19.50
admin@RT-AX88U:/tmp/home/root# nvram show | grep -E 'territory_code|ccode|regrev|regulation|wl[0-9]_country|wl[0-9]_reg_mode|:max' | sort
size: 76084 bytes (54988 left)
1:ccode=US
1:maxp2ga0=0x6E
1:maxp2ga1=0x6E
1:maxp2ga2=0x6E
1:maxp2ga3=0x6E
1:regrev=823
2:ccode=US
2:maxp5gb0a0=110
2:maxp5gb0a1=110
2:maxp5gb0a2=110
2:maxp5gb0a3=110
2:maxp5gb1a0=110
2:maxp5gb1a1=110
2:maxp5gb1a2=110
2:maxp5gb1a3=110
2:maxp5gb2a0=110
2:maxp5gb2a1=110
2:maxp5gb2a2=110
2:maxp5gb2a3=110
2:maxp5gb3a0=110
2:maxp5gb3a1=110
2:maxp5gb3a2=110
2:maxp5gb3a3=110
2:maxp5gb4a0=110
2:maxp5gb4a1=110
2:maxp5gb4a2=110
2:maxp5gb4a3=110
2:regrev=823
territory_code=TW/01
wl0_country_code=US
wl0_country_rev=823
wl0_reg_mode=d
wl1_country_code=US
wl1_country_rev=823
wl1_reg_mode=h
Taiwan and american US/823..... something new...
For US/823
8, /*  Locale Maxpwr: 8 elt(s) */
     86, RANGE_5G_20M_36_36,   RATE_SET_5G_20M_15, /* 21.50dBm,      36, (OFDM6-54_CDD1, MCS0-7_CDD1, VHT8-9SS1_CDD1, OFDM6-
     88, RANGE_5G_20M_36_36,   RATE_SET_5G_20M_16, /* 22.00dBm,      36, (MCS0-7, VHT8-9SS1, MCS0-7_STBC, VHT8-9SS1_STBC, MCS8-15,
     86, RANGE_5G_20M_40_48,   RATE_SET_5G_20M_15, /* 21.50dBm,   40-48, (OFDM6-54_CDD1, MCS0-7_CDD1, VHT8-9SS1_CDD1, OFDM6-
     88, RANGE_5G_20M_40_48,   RATE_SET_5G_20M_16, /* 22.00dBm,   40-48, (MCS0-7, VHT8-9SS1, MCS0-7_STBC, VHT8-9SS1_STBC, MCS8-15,
     62, RANGE_5G_20M_52_144,  RATE_SET_5G_20M_15, /* 15.50dBm,  52-144, (OFDM6-54_CDD1, MCS0-7_CDD1, VHT8-9SS1_CDD1, OFDM6-
     64, RANGE_5G_20M_52_144,  RATE_SET_5G_20M_16, /* 16.00dBm,  52-144, (MCS0-7, VHT8-9SS1, MCS0-7_STBC, VHT8-9SS1_STBC, MCS8-15,
     88, RANGE_5G_20M_149_165, RATE_SET_5G_20M_15, /* 22.00dBm, 149-165, (OFDM6-54_CDD1, MCS0-7_CDD1, VHT8-9SS1_CDD1, OFDM6-
     96, RANGE_5G_20M_149_165, RATE_SET_5G_20M_16, /* 24.00dBm, 149-165, (MCS0-7, VHT8-9SS1, MCS0-7_STBC, VHT8-9SS1_STBC, MCS8-15,
     76, RANGE_5G_40M_38_38,   RATE_SET_5G_40M_3, /* 19.00dBm,      38, (OFDM6-54_TXBF1, MCS0-7_TXBF1, VHT8-9SS1_TXBF1, VHT10-
     80, RANGE_5G_40M_38_38,   RATE_SET_5G_40M_17, /* 20.00dBm,      38, (OFDM6-54, MCS0-7, VHT8-9SS1, OFDM6-54_CDD1, MCS0-7_CDD1,
     86, RANGE_5G_40M_46_46,   RATE_SET_5G_40M_3, /* 21.50dBm,      46, (OFDM6-54_TXBF1, MCS0-7_TXBF1, VHT8-9SS1_TXBF1, VHT10-
     96, RANGE_5G_40M_46_46,   RATE_SET_5G_40M_17, /* 24.00dBm,      46, (OFDM6-54, MCS0-7, VHT8-9SS1, OFDM6-54_CDD1, MCS0-7_CDD1,
     62, RANGE_5G_40M_54_142,  RATE_SET_5G_40M_3, /* 15.50dBm,  54-142, (OFDM6-54_TXBF1, MCS0-7_TXBF1, VHT8-9SS1_TXBF1, VHT10-
     72, RANGE_5G_40M_54_142,  RATE_SET_5G_40M_17, /* 18.00dBm,  54-142, (OFDM6-54, MCS0-7, VHT8-9SS1, OFDM6-54_CDD1, MCS0-7_CDD1,
     88, RANGE_5G_40M_151_159, RATE_SET_5G_40M_3, /* 22.00dBm, 151-159, (OFDM6-54_TXBF1, MCS0-7_TXBF1, VHT8-9SS1_TXBF1, VHT10-
     96, RANGE_5G_40M_151_159, RATE_SET_5G_40M_17, /* 24.00dBm, 151-159, (OFDM6-54, MCS0-7, VHT8-9SS1, OFDM6-54_CDD1, MCS0-
        6, /*  Locale Maxpwr: 6 elt(s) */
     82, RANGE_5G_80M_42_42,   RATE_SET_5G_80M_2, /* 20.50dBm,      42, (OFDM6-54_TXBF1, MCS0-7_TXBF1, VHT8-9SS1_TXBF1, VHT10-
     80, RANGE_5G_80M_42_42,   RATE_SET_5G_80M_17, /* 20.00dBm,      42, (OFDM6-54, MCS0-7, VHT8-9SS1, OFDM6-54_CDD1, MCS0-7_CDD1,
     62, RANGE_5G_80M_58_138,  RATE_SET_5G_80M_2, /* 15.50dBm,  58-138, (OFDM6-54_TXBF1, MCS0-7_TXBF1, VHT8-9SS1_TXBF1, VHT10-
     72, RANGE_5G_80M_58_138,  RATE_SET_5G_80M_17, /* 18.00dBm,  58-138, (OFDM6-54, MCS0-7, VHT8-9SS1, OFDM6-54_CDD1, MCS0-7_CDD1,
     88, RANGE_5G_80M_155_155, RATE_SET_5G_80M_2, /* 22.00dBm,     155, (OFDM6-54_TXBF1, MCS0-7_TXBF1, VHT8-9SS1_TXBF1, VHT10-
     96, RANGE_5G_80M_155_155, RATE_SET_5G_80M_17, /* 24.00dBm,     155, (OFDM6-54, MCS0-7, VHT8-9SS1, OFDM6-54_CDD1, MCS0-7_CDD1,
        4, /*  Locale Maxpwr: 4 elt(s) */
     74, RANGE_5G_160M_50_50,  RATE_SET_5G_160M_0, /* 18.50dBm,      50, (OFDM6-54_TXBF1, MCS0-7_TXBF1, VHT8-9SS1_TXBF1, VHT10-
     72, RANGE_5G_160M_50_50,  RATE_SET_5G_160M_5, /* 18.00dBm,      50, (OFDM6-54, MCS0-7, VHT8-9SS1, OFDM6-54_CDD1, MCS0-7_CDD1,
     62, RANGE_5G_160M_114_114, RATE_SET_5G_160M_0, /* 15.50dBm,     114, (OFDM6-54_TXBF1, MCS0-7_TXBF1, VHT8-9SS1_TXBF1, VHT10-
     72, RANGE_5G_160M_114_114, RATE_SET_5G_160M_5, /* 18.00dBm,     114, (OFDM6-54, MCS0-7, VHT8-9SS1, OFDM6-54_CDD1, MCS0-7_CDD1,
15, /*  Locale Maxpwr: 15 elt(s) */
     80, RANGE_2G_20M_1_1,     RATE_SET_2G_20M_12, /* 20.00dBm,       1, (OFDM6-54_CDD1, MCS0-7_CDD1, VHT8-9SS1_CDD1, OFDM6-54_TXBF1,
     72, RANGE_2G_20M_1_1,     RATE_SET_2G_20M_14, /* 18.00dBm,       1, (MCS0-7, VHT8-9SS1, MCS0-7_STBC, VHT8-9SS1_STBC, MCS8-15, VHT8-
     96, RANGE_2G_20M_1_11,    RATE_SET_2G_20M_10, /* 24.00dBm,    1-11, (DSSS1-11_MULTI1) */
     87, RANGE_2G_20M_2_2,     RATE_SET_2G_20M_12, /* 21.75dBm,       2, (OFDM6-54_CDD1, MCS0-7_CDD1, VHT8-9SS1_CDD1, OFDM6-54_TXBF1,
     86, RANGE_2G_20M_2_2,     RATE_SET_2G_20M_14, /* 21.50dBm,       2, (MCS0-7, VHT8-9SS1, MCS0-7_STBC, VHT8-9SS1_STBC, MCS8-15, VHT8-
     88, RANGE_2G_20M_3_3,     RATE_SET_2G_20M_12, /* 22.00dBm,       3, (OFDM6-54_CDD1, MCS0-7_CDD1, VHT8-9SS1_CDD1, OFDM6-54_TXBF1,
     96, RANGE_2G_20M_3_3,     RATE_SET_2G_20M_14, /* 24.00dBm,       3, (MCS0-7, VHT8-9SS1, MCS0-7_STBC, VHT8-9SS1_STBC, MCS8-15, VHT8-
     88, RANGE_2G_20M_4_8,     RATE_SET_2G_20M_12, /* 22.00dBm,     4-8, (OFDM6-54_CDD1, MCS0-7_CDD1, VHT8-9SS1_CDD1, OFDM6-
     96, RANGE_2G_20M_4_8,     RATE_SET_2G_20M_14, /* 24.00dBm,     4-8, (MCS0-7, VHT8-9SS1, MCS0-7_STBC, VHT8-9SS1_STBC, MCS8-15, VHT8-
     88, RANGE_2G_20M_9_9,     RATE_SET_2G_20M_12, /* 22.00dBm,       9, (OFDM6-54_CDD1, MCS0-7_CDD1, VHT8-9SS1_CDD1, OFDM6-54_TXBF1,
     94, RANGE_2G_20M_9_9,     RATE_SET_2G_20M_14, /* 23.50dBm,       9, (MCS0-7, VHT8-9SS1, MCS0-7_STBC, VHT8-9SS1_STBC, MCS8-15, VHT8-
     87, RANGE_2G_20M_10_10,   RATE_SET_2G_20M_12, /* 21.75dBm,      10, (OFDM6-54_CDD1, MCS0-7_CDD1, VHT8-9SS1_CDD1, OFDM6-
     86, RANGE_2G_20M_10_10,   RATE_SET_2G_20M_14, /* 21.50dBm,      10, (MCS0-7, VHT8-9SS1, MCS0-7_STBC, VHT8-9SS1_STBC, MCS8-15,
     78, RANGE_2G_20M_11_11,   RATE_SET_2G_20M_12, /* 19.50dBm,      11, (OFDM6-54_CDD1, MCS0-7_CDD1, VHT8-9SS1_CDD1, OFDM6-
     82, RANGE_2G_20M_11_11,   RATE_SET_2G_20M_14, /* 20.50dBm,      11, (MCS0-7, VHT8-9SS1, MCS0-7_STBC, VHT8-9SS1_STBC, MCS8-15,
     62, RANGE_2G_40M_3_3,     RATE_SET_2G_40M_5, /* 15.50dBm,       3, (OFDM6-54_TXBF1, MCS0-7_TXBF1, VHT8-9SS1_TXBF1, VHT10-
     68, RANGE_2G_40M_3_3,     RATE_SET_2G_40M_21, /* 17.00dBm,       3, (OFDM6-54, MCS0-7, VHT8-9SS1, OFDM6-54_CDD1, MCS0-7_CDD1,
     66, RANGE_2G_40M_4_4,     RATE_SET_2G_40M_5, /* 16.50dBm,       4, (OFDM6-54_TXBF1, MCS0-7_TXBF1, VHT8-9SS1_TXBF1, VHT10-
     68, RANGE_2G_40M_4_4,     RATE_SET_2G_40M_21, /* 17.00dBm,       4, (OFDM6-54, MCS0-7, VHT8-9SS1, OFDM6-54_CDD1, MCS0-7_CDD1,
     74, RANGE_2G_40M_5_5,     RATE_SET_2G_40M_23, /* 18.50dBm,       5, (OFDM6-54, MCS0-7, VHT8-9SS1, OFDM6-54_CDD1, MCS0-7_CDD1,
     76, RANGE_2G_40M_6_8,     RATE_SET_2G_40M_5, /* 19.00dBm,     6-8, (OFDM6-54_TXBF1, MCS0-7_TXBF1, VHT8-9SS1_TXBF1, VHT10-
     80, RANGE_2G_40M_6_8,     RATE_SET_2G_40M_21, /* 20.00dBm,     6-8, (OFDM6-54, MCS0-7, VHT8-9SS1, OFDM6-54_CDD1, MCS0-7_CDD1,
     76, RANGE_2G_40M_9_9,     RATE_SET_2G_40M_23, /* 19.00dBm,       9, (OFDM6-54, MCS0-7, VHT8-9SS1, OFDM6-54_CDD1, MCS0-7_CDD1,
19dB is very low power for 5Hz ... it`s 89mW.
p.s. try 149-161 channels at 80Mhz, it will give ~ 24 dB + antenna / ~300mW
ok, I'll give it a try. I can roughly understand your charts. but how to do see my charts? LOL it's nowhere as comprehensive as yours. I have a RT-AC3100 also. I am wondering what's its like
Last adjusted est. power (chanspec:0x1808): 24.00 23.75 24.00 24.00
Last adjusted est. power (chanspec:0xe09b): 23.75 24.00 24.00 23.75
size: 75695 bytes (55377 left)
1:ccode=US
1:maxp2ga0=0x6E
1:maxp2ga1=0x6E
1:maxp2ga2=0x6E
1:maxp2ga3=0x6E
1:regrev=823
2:ccode=US
2:maxp5gb0a0=110
2:maxp5gb0a1=110
2:maxp5gb0a2=110
2:maxp5gb0a3=110
2:maxp5gb1a0=110
2:maxp5gb1a1=110
2:maxp5gb1a2=110
2:maxp5gb1a3=110
2:maxp5gb2a0=110
2:maxp5gb2a1=110
2:maxp5gb2a2=110
2:maxp5gb2a3=110
2:maxp5gb3a0=110
2:maxp5gb3a1=110
2:maxp5gb3a2=110
2:maxp5gb3a3=110
2:maxp5gb4a0=110
2:maxp5gb4a1=110
2:maxp5gb4a2=110
2:maxp5gb4a3=110
2:regrev=823
wl0_country_code=US
wl0_country_rev=823
wl0_reg_mode=d
wl1_country_code=US
wl1_country_rev=823
wl1_reg_mode=h
for chn100 i get
Last adjusted est. power (chanspec:0xe02a): 21.75 22.00 22.00 22.00
maybe something has changed since 2020. check the current power through the command line, it will be more reliable this way
22dB - 158mW
the power may differ even on adjacent channels, for example 100 and 102/104
Are you in a noisy WiFi neighborhood? If so, enable OFDMA DL only.
The benefits of OFDMA are it creates signal diversity in a noisy radio environment. Diversity helps to counter the effects of co channel interference.
hate to diy up old topic.. but I am also having the same problem on my ax88u
I still cant enable AX @2409/2409.
it's only when I turn off AX/160mhz and switch to AC/160 then I managed to secure 1733/1733
AX/160 only gets me 2409/229
the thing is all my 4 AX laptops are doing 2409/229.
hi
did you find a solution?
I have the same problem with my AX86!
My 2 PCs (AX200 and 210) can' t go up than 229 Mbps with RX rate in AX mode (ok in AC mode)
on PS5 the upload rise at 5mb/s
no problems with TX rate
driver PC: intel 22.50.1.1
driver router: merlin 386.2_6
thanks a lot
