RT-BE88U - How to remove or prevent creation of IOT VLAN (3006 firmware)
mmjlmjl
I installed an RT-BE88U, installed the latest Merlin firmware on it (release 3006.102.2_2). During the wizard I choose the AP functionality, it then asks for an SSID for normal and IOT network, the latter cannot be skipped. Once up and running I want to define my own VLANs and delete the IOT one, however I can only switch it off, not remove it completely. Any way to do this (i did not find yet...)?
I accidentally found a way after some trial and error attempts: choose to configure manually, then choose AP mode, the wizard then presents you the wifi configuration (normal wifi + iot. Then press the back button of your browser, the layout changes to the way it is in the regular router interface and it will sk you for a username and password for access to the router, next screen: tadaaa it shows only normal Wi-Fi, not the IOT ;) Also you get the option to configure 2.4G and 5G bands with different SSIDs (if you require). After the reboot the router is in "Router mode" though ...
I then simply put it in AP mode under Administration, got the wizard again (but only for the normal wifi VLAN, and I was done.
To me this would be the preferred way to set up a router or AP, without the ASUS defined IOT (which cannot be removed). @RMerlin: this would e a bug fix in my view (or you might see it as a feature request).
Everything related to wifi is outside of my control.
