RT-BE92U and Nvidia Shield Pro 2019
freddyjuarez
So idk what to do anymore is 2019 devices considered legacy devices????
Isn't Wi-Fi 7 backwards compatible
My Nvidia Shield Pro will only only only connect to the 2.4 Ghz_Iot
On the other 2.4 Ghz it connects but disconnects seconds after
On the 5Ghz says connecting then after trying for several seconds it says Couldn't find Asus 5Ghz, I'm like wtf you mean you can't find it....
Check out a screenshot of the router wireless settings....
My 2019 Shields don't have a problem with my AX router. My 5 GHz SSID is set to 80 MHz and WPA2/WPA3.
