I see some other threads on the BE92U rebooting. But I think the situation I'm in is different.
I have it configure in AP Mode, so not as a router. It's on my local LAN and sits behind a hardware firewall. I had four(4) cables plugged into the LAN ports, the feed to a large switch with Internet access, two wired IoT devices and a desktop PC. I had trouble with it a week ago when it arrived and I just plugged it into a switch and disabled the 5 an 6Ghz radios and setup only WPA2. It seemed to run ok that way for several days.
Yesterday I swapped it in for the RT-AX86U that was my main Access Point. It immediately began rebooting itself in anywhere from 20 to 30 minutes. Today I bought a small five(5) port switch and moved everything onto that switch and plugged the RT-BE92U into also. So there's nothing plugged into it now but the single cable giving it access to my LAN and the Internet.
I was thinking that having all the other things plugged into it was perhaps contributing to the rebooting. But, no joy on that. It is continuing to reboot at the same 20-30 min interval.
I've now turned off the 5 & 6 Ghz radios, disabled WiFi 7, but left WPA2/3 on. Nothing seems to be helping.
I did get the new firmware, 3.0.0.6.102_37526 installed yesterday. I did a Hard Factory reset after installing it too. That's why I deployed it yesterday, I was hoping it would resolve the issues I had last week.
Doubt anyone has an answer, and I have called support to open a ticket; no work done on it yet though. Just letting the community know.
