RT-N16 router not staying in rescue mode.
kar2wlan
hello
i have tried to upgrade DD-WRT to asus merlin LTS firmware.
now router is not staying in rescue mode.
attaching a link of video.
plz help me rescue my router.
Please do not double-post/cross-post across forums.
try 30-30-30 Reset: Press reset button for 30 seconds. While holding, unplug router for 30 seconds, power on, hold 30 seconds
there is on RT-N16 I have this router from 2009 and it helped me XX no of times. 30/30/30 is not working from Asus N66U but was for routers before.
you can try 30/30/30 with WPS (not reset) button for RT-N16 too
I think it depends on the firmware level though? If the firmware is current, 30-30-30 doesn't do anything except what a regular reset via the Reset button does.
not sure, I am not expert in this matter just used it 100+ times on WL-500W and N16 and worked - soft I used was dd-wrt, tomato
same ref https://wiki.dd-wrt.com/wiki/index.php/Hard_reset_or_30/30/30
what is strange and basically not approved anywhere (same pages tell it can damage router) I used 30/30/30 way on AC66u, AC56U and AC68U A1 when nothing else was working and was able to recovered it to point I was able to use Firmware Restoration or TFTP.
Okay, let me clarify the point above. There is no 30-30-30 reset on Asus routers running Asuswrt firmware.
30-30-30 reset may work on dd-wrt and tomato (as it is designed to) powered Asus hardware.
Firstly return stock firmware by tftp before updating merlin.
