RT-N66U/AC56U/AC66U/AC68U/AC87U/_3.0.0.4_378_6065- Firmwares
Please note] This version changed the login authentication method.
Wath that means how is the login now then?
Please unplug the hard drive before updating firmware.
Are they refer to the HDD that is plugged in the USB ports?
Yes, they refer to any USB storage attached to it.
About the login, now instead of the common pop-up window requesting login, you'll login on the WebGUI (mainly to avoid letting someone save the login credentials)
On RT-N66U 2.4 ghz band stopped broadcasting with less than 60 hours of uptime. New view list didn't show 2.4 ghz devices connected while wireless log showed them as connected and connection time was increasing.
I'm still having this problem about once a week. Anybody with this problem too? Any suggestion?
