RT-N66U: Can't transfer 1GB files to USB port...
rirusssma
I was able to transfer large files to the HD attached to the USB port on the RT-N66U without any problems. Now, only small files of 10mb or so can be transferred.
I have cleaned out everything possible, the HD has way enough space, the computers HD are large in capacity where the files come from.
The PC is hardwired to the Router.
I get this error after a long idle HERE
Any suggestions where to start looking? :confused:
could not understand if this is a new problem on and old drive, or a new problem on a new drive.
I have no direct experience with usb connected to router drives, but I do know that disk formats matter (e.g. If it is formatted FAT32, then that format cannot handle file sizes >4GB...)
probably wants linux extfs - formatted by the router. Some routers I've read have no formatter/initializer.
NTFS under Linux is really slow, esp. writes.
Yes, that was it ...... the Formatting..
All we sometimes need is a different view to see things clear.
Thanks so much for your great help.
Thank you kenhlan
Thank you stevech
Regards.-:)
Know that linux extfs varieties can be mounted and read under windows with freeware...
http://www.diskinternals.com/download/
E.g., USB3 or eSATA connected to NAS for backups. If needed, plug into windows PC and get files.
You can also read them via a Linux LiveCD or in a Linux VM. The Disk Internals driver is easier but the other two options I've found to be much more reliable.
