I even see a colon or semicolon in the SSID's of sentinelvdxYou shouldn't be using spaces or certain special characters in your ssid's.
After updating from 3.0.0.4.376.1071 I experienced a challenge:
I have fixed ip and a domain pointing to my fixed IP. In my internal routing forwarding table I have various units connected at different ports.
With firmware 1071 I could, from my lan, access all local units like this: www.domain.com:5001 (www.domain.com is routed to my fixed IP).
Now I have to use the internal address when I am in my own LAN (192.168.0.3:5001). When I am connected to an external net I can still use www.domain.com:5001.
This means that I need 2 different setups on all my applications depending on if I am in MY net or any other net. In the last firmware (1071) I could use the same "external" (www.domain.com:5001) always (internal and external). With several units on the net this is a challenge. It doesn't matter if I use the webadress or my fixed (external) IP address, -same results.
Sounds like a bug?
Any increase in WiFi range with this firmware?
It is the effect of more text in the signature and else then the part that should make sense.Merlin fork?
Just an FYI--
Yesterday, I installed my brand new RT-AC66U. I upgraded the firmware to the latest version: 3.0.0.4.376.2524.
Thread starter | Title | Forum | Replies | Date |
B | DSL-N66U Probably a stupid question | ASUS N Routers & Adapters | 3 | |
E | asus rt-n66u replacement | ASUS N Routers & Adapters | 25 | |
L | N66U to what ? | ASUS N Routers & Adapters | 4 | |
L | RT-N66U | ASUS N Routers & Adapters | 3 | |
F | Asus rt-n66u | ASUS N Routers & Adapters | 11 |
Welcome To SNBForums
