For Windows: InSSIDer.which mobile app do you recommend to find the least congested channels?
For Android: Wifi Analyzer by Kevin Yuan.
Johns fork is a derivative of Asuswrt-Merlin and uses old SDK5 wireless drivers for at least the RT-N66U:is John's fork a derivative of Merlin's? Stock?
http://www.snbforums.com/threads/fork-update-for-374-43-available-v15e5.18914/
Stock firmware changed longer ago to SDK6 drivers which are more compliant to the formal rules.
The Software Development Kit (SDK) comes from Broadcom, the wireless chip manufacturer.
Some users claim better wireless performance with the old SDK5 drivers, I do not notice a difference.
Stock firmware is usually most up to date with security fixes, drivers and other software packages.I am confused, so which is a better and more stable build, Merlin's or John's? or are they basically the same but which to choose depends on your needs?
I assume stock firmware, Asuswrt-Merlin and Johns fork are equal in stability as long as they are based on the same GPL.
Asuswrt-Merlin adds features to stock firmware, and is allways a little behind stock firmware (RMerlin needs to get the latest GPL files from Asus to make his builds):
http://www.lostrealm.ca/tower/node/79
Johns fork is behind Asuswrt-Merlin.
Firmware choice depends on your personal preferences and needs.
Wireless performance may depend on your regulatory domain (country).how is Merlin's 378.55 FW, better wifi?
I am in Europe/the Netherlands and do not see any wireless performance difference between old and new drivers.
Setting guidelines:
Set 2.4 GHz to a Channel bandwidth of 20 MHz.
For 2.4 GHz disable b/g Protection (use of old 802.11b devices combined with 802.11n is anyway not recommended).
Set a different SSID for 2.4 GHz and 5 GHz, e.g. "myhome" and "myhome5", this makes it easier to connect a client device to the right frequency band.
Use alphanumeric characters only for the SSID's (Aa to Zz and 0 to 9, no spaces and no odd characters).
Use InSSIDer or a similar program to determine the usage of wireless channels in your neighborhood, do the check at various locations in your house. Do this check at least every month (new neighbor devices may have arrived or neighbors may have changed their settings).
Set 2.4 GHz to the least used channel out of 1, 6 or 11.
Leave 5 GHz to Auto channel (if possible exclude DFS channels) or set it to the least used channel out of 36, 40, 44 or 48 (the non DFS channels).
The range of 5 GHz is practical about half of 2.4 GHz.
Google for DFS or look here:
https://en.wikipedia.org/wiki/List_of_WLAN_channels
DFS may cause 5 GHz to appear working intermittent due to the required waiting time.
Older firmware (and maybe the SDK5 driver) may not even include de DFS channels.
Relative position of the router to the client devices is important, a free line of sight is ideal.
Keep as much as free space around the router as possible, do NOT place the router in a cabinet, do not place it on top of another electronic device.
Keep the router on distance from your modem, your TV, wireless telephones, microwaves and bluetooth devices.
Keep the router on distance from materials that absorb or disturb radio signals e.g. metal objects, concrete walls or floors and waterfilled objects.
Keep an eye on router temperature, place the router on a hard surface to allow natural ventilation through the router box.
Experiment with the location of the router and antenna orientation.
