SNBForums
This is a sample guest message. Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
RT- N66U Log Question
dsring
I noticed the following in my RT-N66U log. What does it mean?
May 2 04:18:13 kernel: br0: received tcn bpdu on port 2(eth1)\
May 2 04:18:13 kernel: br0: topology change detected, sending tcn bpdu\
May 2 04:18:15 kernel: br0: received tcn bpdu on port 2(eth1)\
May 2 04:18:15 kernel: br0: topology change detected, sending tcn bpdu\
May 2 04:18:17 kernel: br0: received tcn bpdu on port 2(eth1)\
May 2 04:18:17 kernel: br0: topology change detected, sending tcn bpdu\
May 2 04:18:19 kernel: br0: received tcn bpdu on port 2(eth1)\
May 2 04:18:19 kernel: br0: topology change detected, sending tcn bpdu\
May 2 04:18:21 kernel: br0: received tcn bpdu on port 2(eth1)\
May 2 04:18:21 kernel: br0: topology change detected, sending tcn bpdu\
May 2 04:18:23 kernel: br0: received tcn bpdu on port 2(eth1)\
May 2 04:18:23 kernel: br0: topology change detected, sending tcn bpdu\
May 2 04:18:25 kernel: br0: received tcn bpdu on port 2(eth1)\
May 2 04:18:25 kernel: br0: topology change detected, sending tcn bpdu\
May 2 04:18:27 kernel: br0: received tcn bpdu on port 2(eth1)\
May 2 04:18:27 kernel: br0: topology change detected, sending tcn bpdu\
May 2 04:18:29 kernel: br0: received tcn bpdu on port 2(eth1)\
May 2 04:18:29 kernel: br0: topology change detected, sending tcn bpdu\
May 2 04:18:31 kernel: br0: received tcn bpdu on port 2(eth1)\
May 2 04:18:31 kernel: br0: topology change detected, sending tcn bpdu\
May 2 04:18:33 kernel: br0: received tcn bpdu on port 2(eth1)\
May 2 04:18:33 kernel: br0: topology change detected, sending tcn bpdu\
May 2 04:18:35 kernel: br0: received tcn bpdu on port 2(eth1)\
May 2 04:18:35 kernel: br0: topology change detected, sending tcn bpdu\
May 2 04:18:37 kernel: br0: received tcn bpdu on port 2(eth1)\
May 2 04:18:37 kernel: br0: topology change detected, sending tcn bpdu\
May 2 04:18:39 kernel: br0: received tcn bpdu on port 2(eth1)\
May 2 04:18:39 kernel: br0: topology change detected, sending tcn bpdu\
May 2 04:18:41 kernel: br0: received tcn bpdu on port 2(eth1)\
May 2 04:18:41 kernel: br0: topology change detected, sending tcn bpdu\
May 2 04:18:43 kernel: br0: received tcn bpdu on port 2(eth1)\
May 2 04:18:43 kernel: br0: topology change detected, sending tcn bpdu\
May 2 04:18:45 kernel: br0: received tcn bpdu on port 2(eth1)\
May 2 04:18:45 kernel: br0: topology change detected, sending tcn bpdu\
May 2 04:18:47 kernel: br0: received tcn bpdu on port 2(eth1)\
May 2 04:18:47 kernel: br0: topology change detected, sending tcn bpdu\
is port 2 (eth1) connected to a bridge? Need to know more about your configuration.
--bill
It is connected to a Realtek NIC that has been disabled. I believe the message may be related to Spanning Tree Protocol (STP). I am not sure that I need STP enabled. I have since disabled it in the router to see if the messages cease, and to see if it affects performance. Thanks.
