Hi everyone. My router (RT-N66U) dead after reboot.
Power led fast blinking all the time , restore mode working - I tryed clear nvram from web CFI , also tryed all official and alternative firmware - flashing ok, then reboots and rapid power led fast blinking again.
In console I can see:
In CFE mode:
I can also enter to CFE by ctrl-c:
Can anyone help?
Replacing the reset button will help?
Decompressing...done
tmp_ret= 0
CFE version 5.100.127 based on BBP 1.0.37 for BCM947XX (32bit,SP,LE)
Build Date: 五 12月 9 10:10:49 CST 2011 (boyau@localhost.localdomain)
Copyright (C) 2000-2008 Broadcom Corporation.
Init Arena
Init Devs.
Boot partition size = 262144(0x40000)
et0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 5.100.127
CPU type 0x19749: 600MHz
Tot mem: 131072 KBytes
CFE mem: 0x80700000 - 0x8079D320 (643872)
Data: 0x807330F0 - 0x807363B0 (12992)
BSS: 0x807363B0 - 0x80737320 (3952)
Heap: 0x80737320 - 0x8079B320 (409600)
Stack: 0x8079B320 - 0x8079D320 (8192)
Text: 0x80700000 - 0x807330E8 (209128)
Device eth0: hwaddr 10-xxxx, ipaddr 192.168.1.1, mask 255.255.255.0
gateway not set, nameserver not set
Null Rescue Flag.
Wait until reset button released...
In CFE mode:
tmp_ret= 0
Init Arena
Init Devs.
Null Rescue Flag.
Hello!! Enter Rescue Mode: (by Force)
Reading :: TFTP Server.
Failed.: Timeout occured
Failed.: Interrupted
CFE>
CFE>
CFE>
CFE> help
help
Available commands:
et Broadcom Ethernet utility.
show clocks Show current values of the clocks.
nvram NVRAM utility.
reboot Reboot.
flash Update a flash memory device
batch Load a batch file into memory and execute it
go Verify and boot OS image.
boot Load an executable file into memory and execute it
load Load an executable file into memory without executing it
save Save a region of memory to a remote file via TFTP
ping Ping a remote IP host.
arp Display or modify the ARP Table
ifconfig Configure the Ethernet interface
help Obtain help for CFE commands
For more information about a command, enter 'help command-name'
*** command status = 0
CFE>
Can anyone help?
