samsonite444
Hi, need some help on some settings, just recieved the RT-N66U b.1 router, planning on installing the forks update 374.43 as I believe gives the best wireless range as the house is quiet big.
Haven't used the router yet but as soon as I switch it on will I have to perform a factory reset first then install forks update and then do another factory reset again?
Also for the wireless 2.4ghz mode which number shall I set this to 20mhz or 40mhz...
thanks
thanks
