No, had not enabled that option. This is what I did after reading your post. This will give me a report every hour or so, by this I understand that there is no live view of the IP using the data?
Is my setting correct?
Yes, IPTraffic also has a Realtime page.
Where could the IPTraffic Realtime page be found? I've looked every option and seems that I missed it.
Is there any "hit" though to using RAM to store the information; I'm not interestest in saving the data, just looking at it from time to time for a real-time check. I don't want or need to save it to a USB disk, but does enabling the IP-specific monitoring cause any adverse effects on RAM? I can't see any negative impact that would affect performance based on the crude percentage graph on the Network Map page, but just wondering if it causes any RAM overflow if this is used long term.
Traffic monitor tab then click on the drop down arrow on the right and select per device.
Welcome To SNBForums
