Hello,
I installed Rtorrent by this tutorial: https://github.com/Entware-ng/Entware-ng/wiki/Using-Rtorrent
But Rtorrent doesn't start.
I have Merlin latest firmware on Asus ac87u.
Here is what i got after running Rtorrent installation script:
If I try to run manually:
Any ideas? Is it because I have transmission installed?
alex@ASUS_DRIVE:/tmp/mnt/Seagate_Backup_Plus_Drive/asusware.arm/etc/transmission# opkg install rtorrent-easy-install
Installing rtorrent-easy-install (0.2-3) to root...
Downloading http://pkg.entware.net/binaries/armv7/rtorrent-easy-install_0.2-3_armv7soft.ipk
Installing rutorrent-plugin-rpc (3.8-1) to root...
Downloading http://pkg.entware.net/binaries/armv7/rutorrent-plugin-rpc_3.8-1_armv7soft.ipk
Installing rutorrent (3.8-1) to root...
Downloading http://pkg.entware.net/binaries/armv7/rutorrent_3.8-1_armv7soft.ipk
Installing rtorrent-rpc (0.9.6-git-1-62cb5a4605c0664bc522e0e0da9c72f09cf643a9) to root...
Downloading http://pkg.entware.net/binaries/armv7/rtorrent-rpc_0.9.6-git-1-62cb5a4605c0664bc522e0e0da9c72f09cf643a9_armv7soft.ipk
Installing libtorrent (0.13.6-git-1-14e793b75dac95c51ad64ff9cd2dc6772b68c625) to root...
Downloading http://pkg.entware.net/binaries/armv7/libtorrent_0.13.6-git-1-14e793b75dac95c51ad64ff9cd2dc6772b68c625_armv7soft.ipk
Installing libsigcxx (2.5.4-1) to root...
Downloading http://pkg.entware.net/binaries/armv7/libsigcxx_2.5.4-1_armv7soft.ipk
Installing xmlrpc-c-server (1.39.12-1) to root...
Downloading http://pkg.entware.net/binaries/armv7/xmlrpc-c-server_1.39.12-1_armv7soft.ipk
Installing xmlrpc-c (1.39.12-1) to root...
Downloading http://pkg.entware.net/binaries/armv7/xmlrpc-c_1.39.12-1_armv7soft.ipk
Installing xmlrpc-c-internal (1.39.12-1) to root...
Downloading http://pkg.entware.net/binaries/armv7/xmlrpc-c-internal_1.39.12-1_armv7soft.ipk
Installing xmlrpc-c-common (1.39.12-1) to root...
Downloading http://pkg.entware.net/binaries/armv7/xmlrpc-c-common_1.39.12-1_armv7soft.ipk
Installing coreutils-stat (8.23-3) to root...
Downloading http://pkg.entware.net/binaries/armv7/coreutils-stat_8.23-3_armv7soft.ipk
Installing coreutils (8.23-3) to root...
Downloading http://pkg.entware.net/binaries/armv7/coreutils_8.23-3_armv7soft.ipk
Installing coreutils-id (8.23-3) to root...
Downloading http://pkg.entware.net/binaries/armv7/coreutils-id_8.23-3_armv7soft.ipk
Installing gzip (1.8-1) to root...
Downloading http://pkg.entware.net/binaries/armv7/gzip_1.8-1_armv7soft.ipk
Installing curl (7.54.1-1) to root...
Downloading http://pkg.entware.net/binaries/armv7/curl_7.54.1-1_armv7soft.ipk
Installing screen (4.6.1-1) to root...
Downloading http://pkg.entware.net/binaries/armv7/screen_4.6.1-1_armv7soft.ipk
Installing libncurses (6.0-1c) to root...
Downloading http://pkg.entware.net/binaries/armv7/libncurses_6.0-1c_armv7soft.ipk
Installing php7-cgi (7.1.9-1) to root...
Downloading http://pkg.entware.net/binaries/armv7/php7-cgi_7.1.9-1_armv7soft.ipk
Installing php7 (7.1.9-1) to root...
Downloading http://pkg.entware.net/binaries/armv7/php7_7.1.9-1_armv7soft.ipk
Installing libpcre (8.41-2) to root...
Downloading http://pkg.entware.net/binaries/armv7/libpcre_8.41-2_armv7soft.ipk
Installing libxml2 (2.9.5-1) to root...
Downloading http://pkg.entware.net/binaries/armv7/libxml2_2.9.5-1_armv7soft.ipk
Installing lighttpd-mod-fastcgi (1.4.45-7) to root...
Downloading http://pkg.entware.net/binaries/armv7/lighttpd-mod-fastcgi_1.4.45-7_armv7soft.ipk
Installing lighttpd (1.4.45-7) to root...
Downloading http://pkg.entware.net/binaries/armv7/lighttpd_1.4.45-7_armv7soft.ipk
Installing lighttpd-mod-scgi (1.4.45-7) to root...
Downloading http://pkg.entware.net/binaries/armv7/lighttpd-mod-scgi_1.4.45-7_armv7soft.ipk
Installing lighttpd-mod-auth (1.4.45-7) to root...
Downloading http://pkg.entware.net/binaries/armv7/lighttpd-mod-auth_1.4.45-7_armv7soft.ipk
Configuring xmlrpc-c-common.
Configuring xmlrpc-c-internal.
Configuring xmlrpc-c.
Configuring libpcre.
Configuring libxml2.
Configuring php7.
Configuring php7-cgi.
Configuring coreutils.
Configuring coreutils-stat.
Configuring libsigcxx.
Configuring libtorrent.
Configuring xmlrpc-c-server.
Configuring rtorrent-rpc.
Configuring coreutils-id.
Configuring gzip.
Configuring curl.
Configuring rutorrent.
Configuring rutorrent-plugin-rpc.
Configuring libncurses.
Configuring screen.
Configuring lighttpd.
Configuring lighttpd-mod-fastcgi.
Configuring lighttpd-mod-scgi.
Configuring lighttpd-mod-auth.
Configuring rtorrent-easy-install.
#### Welcome to rtorrent easy installation script!
We assuming no lighttpd/rtorrent/rutorrent was installed before!
Please, answer a few question to configure torrent client.
Default aswers given in [brackets], just hit Enter to accept it.
Type "username:password" if you want to protect Web UI or hit Enter to leave password protection disabled []: alex:pass
Which port should be used by web interface? [81]: 81
Enter (maximal) download speed in KB/s [2048]: 20480
Enter (maximal) upload speed in KB/s [20480]: 0
Enter folder name on USB drive where torrent content should be stored [/opt/torrents]: /tmp/mnt/Seagate_Backup_Plus_Drive/Torrents
Done! You may open 51411-51412 TCP/UDP ports on your router to
facilitate uploading/donwloading. It's not necessary but recommended.
rutorrent web UI will be available at following URL:
http://<ip_address_of_router>:<port>/rutorrent
Do you wish to start torrent client? [y]: y
Starting lighttpd... already running.
Starting rtorrent... failed.
Collected errors:
* pkg_run_script: package "rtorrent-easy-install" postinst script returned status 255.
alex@ASUS_DRIVE:/tmp/home/root# /opt/etc/init.d/S85rtorrent start
