RTRMON RTRMON v2.1.5 -Apr 12, 2025- Monitor your Router's Health (New: AMTM, Network Conn/Bandwidth/Diag + Port Scanner + Speedtest)
Not that I'd personally be comfortable running a router with 384.13_10, but this definitely attests to how universal @Viktor Jaep's RTRMON script is!
Unintended side-effects... I promise you it was not by design. :p
Well, it appears to for 384., 386., 3004.388., and 3006.102.
I mean, yeah... I worked SUPER hard ensuring compatibility across the spectrum of firmwares... literally nights and weekends, uphill both ways in the snow if you catch my drift. If you rename the "rtrmon.sh" script to "rtrmon.exe", it will even work on Windows machines, or so I'm told. LOL
Receiving an error when type "rt" in AMTM. Any idea what's going on?
Doesn't look like it exists on your router. You can always drop to a prompt, and see if you can find the "rtrmon.sh" file sitting under /jffs/scripts?
Huge thanks to @ExtremeFiretop for his contribution to RTRMON on this one. Some small but significant changes to the way client names are looked up when using MLO on your fancy WiFi 7's. ;) It's been a while since I've smashed all the commit buttons right on github to get that new release out there, so here goes!
What's new?
v2.1.5 - (April 12, 2025)
- PATCH:
Thanks to @ExtremeFiretop for providing a fix for the way RTRMON looks up client name based on the MAC address used for association, as it might not find the correct hostname if the DHCP lease is associated with the MLD MAC. This was based on RMerlin's note here: https://www.snbforums.com/threads/even-when-not-using-mlo-it-still-changes-some-stuff.94070/
Download link (or update directly within AMTM):
curl --retry 3 "https://raw.githubusercontent.com/ViktorJp/RTRMON/master/rtrmon.sh" -o "/jffs/scripts/rtrmon.sh" && chmod 755 "/jffs/scripts/rtrmon.sh"
Page 6 showing current connections/bandwidth for your WAN, LAN and VPN Connections:
And Page 7 provides you with all the current connection information as clients connected to your Wi-Fi networks, LAN, VLANs, AiMesh nodes, etc. will be displayed here.
How is this script supposed to run?​
I would recommend running this script in its own SSH window from a PC that's connected directly to the Asus router, or from a utility like 'Screen', as it loops and checks the various stats every 10 seconds. Instructions:
  1. Download and install directly from AMTM, or using your favorite SSH tools, copy & paste this command:
  2. Configure it using this command:
    sh /jffs/scripts/rtrmon.sh -setup
  3. Run it standalone in an SSH window with this command:
    sh /jffs/scripts/rtrmon.sh -monitor
  4. Or, using the screen utility, which has now been built-in:
    sh /jffs/scripts/rtrmon.sh -screen
  5. To make it even easier, simply execute the script name with the commandline switch, like so:
    rtrmon -screen
    -or-
    rtrmon -monitor
    -or-
    rtrmon -setup
    etc...
Please note: in order to use the shortcut method as explained in step 5, you will need to log out of your SSH session completely/close it, then re-open it and log back in. Then you can use the command "rtrmon" from any subfolder location.
Do I need to configure anything?​
You can enter the setup screen with the command 'sh rtrmon.sh -setup' or by hitting the "M" key in the main UI:
Hitting the "1" option, there are currently 13 items you can configure (you can also access this screen by using 'sh rtrmon.sh -config'):
The really important ones probably are your max speeds... as those will differ from router to router, home to home, location to location. Each menu item has detailed explanations on what each one means. If you have any further questions, please feel free to post in the thread below.
I'm definitely looking for your feedback... what works, what doesn't... what else would you like to see. But all-in-all, as good ideas come up for things to possibly add, very much a WIP (work-in-progress).
Very nice. One interesting output feature is the way that Ethernet connected devices that are on the same VLAN subnet as a guest network display.
Thank you for your continuing work on this utility.
