Running ac66u and ac68u together
Configure a unique ssid for each band and each router.
If you're using the RMerlin firmware; you may find the 'Roaming assistance' setting useful in getting you to 'automatically' switch you to the stronger signal.
Using the same ssid per band will probably be an exercise in frustration - especially if the overlap is as strong as you indicate.
I am using AC68 as main router and N66 operating as Repeater. I have configured it both ways, and also prefer to have unique SSIDs on each repeater band to have more control over exactly which router a device is connected to.
Which brings me to "roaming assist", that sounded like a great option to disconnect device below a certain signal strength and connect to the other router...however, this actually causes the 2.4Ghz radio to be disabled? I created a separate post 15585 for this issue.
