rv042 pptp vpn help!
Jvivek
Well i have a complicated setup, So I will draw it out
adsl internet------>main router(192.168.1.1)----->Switch-------Clients
cable internet-------rv042-----------^
basically cable internet is being used strictly for pptp vpn.
here are my issues
pptp service online. ip 192.168.1.200-205
I need users connecting through rv042 to be able to talk to network on the main router.
What I have tried so far with no success
Network mode on rv042 changed to routed from gateway since it is being used strictly for vpn
I want computer connected through vpn to pass all traffic through main router, including external/internal.
sadly no documentation from linksys.
I can't think of a simple way to get this to work. Why don't you use the dual-WAN capability of the RV042 instead of two routers?
the reason for two routers is that rv042 wont do icmp and some other issues
Any help would be appreciated
You have 2 different gateways on the same LAN...devices that use the RV0 as their gateway will be accessible.
I agree...ditch the other router, use the RV0 as your edge and utilize its dual WAN ports.
What do you mean the RV0 won't do ICMP?
