Hi all,
After a recent upgrade to 386.2 (I have also tried 386.3) - my router keeps getting kernel panics.
Nothing seems to stop working except my WAN - which is PPPoE based. Hard resetting the modem OR flipping the "Internet Connection" toggle on "Network Map" restores it.
I can't seem to find a trigger either.
Not sure where to go from here. Could someone lend a pointer please?
Aug 18 01:03:00 kernel: CPU: 1 PID: 26636 Comm: dcd Tainted: P O 4.1.52 #1
Aug 18 01:03:00 kernel: Hardware name: Generic DT based system
Aug 18 01:03:00 kernel: task: d5ef7000 ti: d07d6000 task.ti: d07d6000
Aug 18 01:03:00 kernel: PC is at 0xb6c9239c
Aug 18 01:03:00 kernel: LR is at 0x1e808
Aug 18 01:03:00 kernel: pc : [<b6c9239c>] lr : [<0001e808>] psr: 600f0010
Aug 18 01:03:00 kernel: sp : bed84958 ip : 000a3050 fp : b5dff024
Aug 18 01:03:00 kernel: r10: 000a33c8 r9 : b5dff680 r8 : 000a387c
Aug 18 01:03:00 kernel: r7 : b5dff6b8 r6 : 000a3876 r5 : 00000000 r4 : b5dff664
Aug 18 01:03:00 kernel: r3 : 00000000 r2 : 88b48e00 r1 : 0007e101 r0 : 00000000
Aug 18 01:03:00 kernel: Flags: nZCv IRQs on FIQs on Mode USER_32 ISA ARM Segment user
Aug 18 01:03:00 kernel: Control: 10c5387d Table: 0cc4c04a DAC: 00000015
Aug 18 01:03:00 kernel: [<c0026fe0>] (unwind_backtrace) from [<c0022c38>] (show_stack+0x10/0x14)
Aug 18 01:03:00 kernel: [<c0022c38>] (show_stack) from [<c048e07c>] (dump_stack+0x8c/0xa0)
Aug 18 01:03:00 kernel: [<c048e07c>] (dump_stack) from [<c003ac88>] (get_signal+0x490/0x558)
Aug 18 01:03:00 kernel: [<c003ac88>] (get_signal) from [<c00221d0>] (do_signal+0xc8/0x3ac)
Aug 18 01:03:00 kernel: [<c00221d0>] (do_signal) from [<c0022658>] (do_work_pending+0x94/0xa4)
Aug 18 01:03:00 kernel: [<c0022658>] (do_work_pending) from [<c001f4cc>] (work_pending+0xc/0x20)
Aug 18 01:08:57 kernel: CPU: 1 PID: 32067 Comm: dcd Tainted: P O 4.1.52 #1
Aug 18 01:08:57 kernel: Hardware name: Generic DT based system
Aug 18 01:08:57 kernel: task: cda34c00 ti: cd070000 task.ti: cd070000
Aug 18 01:08:57 kernel: PC is at 0xb6ccd39c
Aug 18 01:08:57 kernel: LR is at 0x1e808
Aug 18 01:08:57 kernel: pc : [<b6ccd39c>] lr : [<0001e808>] psr: 600f0010
Aug 18 01:08:57 kernel: sp : beca6958 ip : 000a3050 fp : b5dff024
Aug 18 01:08:57 kernel: r10: 000a33c8 r9 : b5dff680 r8 : 000a387c
Aug 18 01:08:57 kernel: r7 : b5dff6b8 r6 : 000a3876 r5 : 00000000 r4 : b5dff664
Aug 18 01:08:57 kernel: r3 : 00000000 r2 : 35019300 r1 : 0007e101 r0 : 00000000
Aug 18 01:08:57 kernel: Flags: nZCv IRQs on FIQs on Mode USER_32 ISA ARM Segment user
Aug 18 01:08:57 kernel: Control: 10c5387d Table: 0cae404a DAC: 00000015
Aug 18 01:08:57 kernel: [<c0026fe0>] (unwind_backtrace) from [<c0022c38>] (show_stack+0x10/0x14)
Aug 18 01:08:57 kernel: [<c0022c38>] (show_stack) from [<c048e07c>] (dump_stack+0x8c/0xa0)
Aug 18 01:08:57 kernel: [<c048e07c>] (dump_stack) from [<c003ac88>] (get_signal+0x490/0x558)
Aug 18 01:08:57 kernel: [<c003ac88>] (get_signal) from [<c00221d0>] (do_signal+0xc8/0x3ac)
Aug 18 01:08:57 kernel: [<c00221d0>] (do_signal) from [<c0022658>] (do_work_pending+0x94/0xa4)
Aug 18 01:08:57 kernel: [<c0022658>] (do_work_pending) from [<c001f4cc>] (work_pending+0xc/0x20)
