Samba user names missing (RT-N66U 378.55)
mrkorb
Picture says it all. The user names just aren't there beside the icons. The only way to check which user you are working with is to select one and click the edit button, which pops open the little edit box that displays the name. I tried highlighting with my mouse to see if maybe they were just the same color as the background, but nothing appeared except a lot of blue highlight.
This is a fresh install and reset to default using 378.55.
Open the web browser console and look for any Javascript error.
Also make sure your USB disk does not contain any non-standard partition, that could confuse the router.
And of course when I come back to it 12 hours later, the user names are right there where they should be. Sorry for the hasty bug report.
