VPNMON VPNMON-R2 v2.0 -Jul 10, 2022- Monitor your VPN connection's Health (Thread locked/closed)
Yeah, I just updated to 2.0 and realized I wrote that incorrectly and couldn't fix it before you saw it. LOL
I meant random.
If I use random and have a lowest ping value, the random one is often the same one with a high ping.
Yep, if you use 'random', then it doesn't care about the lowest ping/lowest load. It will literally pick a random connection, even if it's a higher ping/load... distance and speed be damned! In this case, it does still care about the high ping and load parameters that you have configured. So if this connection exceeds 150ms or 50% load, it will initiate another random reset.
Since that could cause a near-infinite loop. is it possible to exclude slots that exceed values in the random selection?
I can go 24hrs without a reset using these defaults:
- NordVPN SuperRandom -- random selection of 5 servers gave me 73ms, 39ms, 33ms, 35ms and 54ms. Load on my current server = 18%.
- Ping reset > 100ms
- Load reset > 50%
It's unlikely my connection will reset until it's scheduled to. What kinds of servers are you connecting to?
- Load reset > 50%
I'm connecting to US servers in NYC, Buffalo, Miami, and Dallas. I'm currently in Costa Rica. The Miami servers generally have the best ping times.
In situations where your servers are far away, ping will most likely be higher. In those cases, I would probably bump up your "ping reset" parameter from 100ms (default) to something higher, based on what you're seeing in the UI... maybe 150-175?
If you're using the "lowest ping reset option", there may be cases where there might be a chance for it to prefer other servers that are competing for a lower ping, then increase the chances from 5 (default), to perhaps 10... in order to give your connection a chance to redeem itself as the server with the lowest ping, and would then restart the counter before it drops/reconnects.
Stuck on this screen, last log entry is from 12hrs prior, Whats wrong ?
After reset via command line
* ADDED: The ability to reset the VPN with a "vpnmon-r2.sh -reset" commandline switch. This gives you the same functionality that VPNON gave you, and are able to use this method to randomly reset your VPN connection using CRON jobs. VPNMON-R2 running in its own SSH or Screen window will be aware of these actions, will pause the UI while the reset is running, and will resume when finished.
Looks like its “vpnmon-r2 -reset”
Making any kind of changes in wan, restarts all VPNs that have “Automatic start at boot time” enabled, don't know if it has to do with vpnmon
Wow, that's certainly a weird one... First off:
1.) Did you schedule a manual reset using the "vpnmon-r2 -reset' switch? And there's no logs from this?
2.) Could you please run these statements, and tell me what you see?
nvram get wan0_state_t
nvram get wan1_state_t
nvram get wan0_ifname
nvram get wan1_ifname
I'm not making any changes in the WAN settings - just reporting on what it sees... that's pretty much hard-coded on your router. I would highly recommend you do not have any of your VPN Client slots "automatically start at boot time", because that's just going to hose things up more.
Yup, just did that
No, you didn't run any manual "vpnmon-r2 -reset" command, or you did, but they didn't leave a log?
I'm assuming it's normal for you to have both your WAN0 and WAN1 be in an active state?
Here's a sample of what appears in my logs after a manual command-line "vpnmon-r2 -reset" happens:
Mon Jul 11 13:00:01 DST 2022 - VPNMON-R2 ----------> INFO: Executing VPN Reset via Commandline Switch
Mon Jul 11 13:00:01 DST 2022 - VPNMON-R2 - Executing VPN Reset
Mon Jul 11 13:00:13 DST 2022 - VPNMON-R2 - Killed all VPN Client Connections
Mon Jul 11 13:00:37 DST 2022 - VPNMON-R2 - Updated Skynet Whitelist
Mon Jul 11 13:00:45 DST 2022 - VPNMON-R2 - Refreshed VPN Slots 1 - 5 from 2124 SuperRandom NordVPN Server Locations
Mon Jul 11 13:00:46 DST 2022 - VPNMON-R2 - Randomly selected VPN4 Client ON
Mon Jul 11 13:01:22 DST 2022 - VPNMON-R2 - Successfully updated YazFi guest network(s) with the current VPN slot.
Mon Jul 11 13:01:22 DST 2022 - VPNMON-R2 - VPN Reset Finished
Mon Jul 11 13:01:25 DST 2022 - VPNMON-R2 - Trimmed the log file down to 1000 lines
Mon Jul 11 13:01:33 EDT 2022 - VPNMON-R2 - API call made to update VPN city to Dallas
No, i didn't run any manual “vpnmon-r2 -reset” command
Yes, I have wan fail over, 2 separate connections, its courtesy of Dual Wan monitor script by @Ranger802004
Yesterdays Log
Mon Jul 11 21:31:47 IST 2022 - VPNMON-R2 - Executing VPN Reset
Mon Jul 11 21:31:51 IST 2022 - VPNMON-R2 - Killed all VPN Client Connections
Mon Jul 11 21:32:51 IST 2022 - VPNMON-R2 ----------> ERROR: WAN CONNECTIVITY ISSUE DETECTED
Mon Jul 11 21:32:51 IST 2022 - VPNMON-R2 - WAN Link Detected -- Trying to reconnect/Reset VPN
Mon Jul 11 21:33:55 IST 2022 - VPNMON-R2 - Executing VPN Reset
Mon Jul 11 21:33:59 IST 2022 - VPNMON-R2 - Killed all VPN Client Connections
Mon Jul 11 21:34:59 IST 2022 - VPNMON-R2 ----------> ERROR: WAN CONNECTIVITY ISSUE DETECTED
Mon Jul 11 21:34:59 IST 2022 - VPNMON-R2 - WAN Link Detected -- Trying to reconnect/Reset VPN
Mon Jul 11 21:36:04 IST 2022 - VPNMON-R2 - Executing VPN Reset
Mon Jul 11 21:36:08 IST 2022 - VPNMON-R2 - Killed all VPN Client Connections
Mon Jul 11 21:37:08 IST 2022 - VPNMON-R2 ----------> ERROR: WAN CONNECTIVITY ISSUE DETECTED
Mon Jul 11 21:37:08 IST 2022 - VPNMON-R2 - WAN Link Detected -- Trying to reconnect/Reset VPN
Mon Jul 11 21:38:10 IST 2022 - VPNMON-R2 - Successfully wrote a new config file
Mon Jul 11 21:38:12 IST 2022 - VPNMON-R2 - Executing VPN Reset
Mon Jul 11 21:38:16 IST 2022 - VPNMON-R2 - Killed all VPN Client Connections
Mon Jul 11 21:39:16 IST 2022 - VPNMON-R2 ----------> ERROR: WAN CONNECTIVITY ISSUE DETECTED
Mon Jul 11 21:39:16 IST 2022 - VPNMON-R2 - WAN Link Detected -- Trying to reconnect/Reset VPN
Mon Jul 11 21:40:21 IST 2022 - VPNMON-R2 - Executing VPN Reset
Mon Jul 11 21:40:25 IST 2022 - VPNMON-R2 - Killed all VPN Client Connections
Tue Jul 12 07:34:16 IST 2022 - VPNMON-R2 ----------> INFO: Executing VPN Reset via Commandline Switch
Tue Jul 12 07:34:16 IST 2022 - VPNMON-R2 - Executing VPN Reset
Tue Jul 12 07:34:21 IST 2022 - VPNMON-R2 - Killed all VPN Client Connections
Tue Jul 12 07:34:53 IST 2022 - VPNMON-R2 - Updated Skynet Whitelist
Tue Jul 12 07:34:53 IST 2022 - VPNMON-R2 - VPN3 Client ON - Lowest PING of 5 VPN slots
Tue Jul 12 07:34:55 IST 2022 - VPNMON-R2 - VPN Reset Finished
Tue Jul 12 07:34:58 IST 2022 - VPNMON-R2 - Trimmed the log file down to 1000 lines
Tue Jul 12 07:35:31 IST 2022 - VPNMON-R2 - API call made to update WAN city to Mumbai
Tue Jul 12 07:35:33 IST 2022 - VPNMON-R2 - API call made to update VPN city to Singapore
Tue Jul 12 07:39:44 IST 2022 - VPNMON-R2 ----------> INFO: Executing VPN Reset via Commandline Switch
Tue Jul 12 07:39:44 IST 2022 - VPNMON-R2 - Executing VPN Reset
Tue Jul 12 07:39:49 IST 2022 - VPNMON-R2 - Killed all VPN Client Connections
Tue Jul 12 07:40:21 IST 2022 - VPNMON-R2 - Updated Skynet Whitelist
Tue Jul 12 07:40:21 IST 2022 - VPNMON-R2 - VPN4 Client ON - Lowest PING of 5 VPN slots
Tue Jul 12 07:40:23 IST 2022 - VPNMON-R2 - VPN Reset Finished
Tue Jul 12 07:40:25 IST 2022 - VPNMON-R2 - Trimmed the log file down to 1000 lines
Tue Jul 12 07:42:22 IST 2022 - VPNMON-R2 ----------> ERROR: Multiple VPN Client Connections detected - Executing VPN Reset
Tue Jul 12 07:42:22 IST 2022 - VPNMON-R2 - Executing VPN Reset
Tue Jul 12 07:42:28 IST 2022 - VPNMON-R2 - Killed all VPN Client Connections
Tue Jul 12 07:43:01 IST 2022 - VPNMON-R2 - Updated Skynet Whitelist
Tue Jul 12 07:43:02 IST 2022 - VPNMON-R2 - VPN3 Client ON - Lowest PING of 5 VPN slots
Tue Jul 12 07:43:04 IST 2022 - VPNMON-R2 - VPN Reset Finished
Tue Jul 12 07:43:06 IST 2022 - VPNMON-R2 - Trimmed the log file down to 1000 lines
Tue Jul 12 07:43:06 IST 2022 - VPNMON-R2 - Resuming normal operations
Tue Jul 12 07:43:07 IST 2022 - VPNMON-R2 - API call made to update VPN city to Singapore
Tue Jul 12 07:45:56 IST 2022 - VPNMON-R2 ----------> ERROR: Multiple VPN Client Connections detected - Executing VPN Reset
Tue Jul 12 07:45:56 IST 2022 - VPNMON-R2 - Executing VPN Reset
Tue Jul 12 07:46:01 IST 2022 - VPNMON-R2 - Killed all VPN Client Connections
Tue Jul 12 07:46:33 IST 2022 - VPNMON-R2 - Updated Skynet Whitelist
Tue Jul 12 07:46:34 IST 2022 - VPNMON-R2 - VPN3 Client ON - Lowest PING of 5 VPN slots
Tue Jul 12 07:46:36 IST 2022 - VPNMON-R2 - VPN Reset Finished
Tue Jul 12 07:46:38 IST 2022 - VPNMON-R2 - Trimmed the log file down to 1000 lines
Tue Jul 12 07:46:38 IST 2022 - VPNMON-R2 - Resuming normal operations
Tue Jul 12 07:46:39 IST 2022 - VPNMON-R2 - API call made to update VPN city to Singapore
Tue Jul 12 07:54:55 IST 2022 - VPNMON-R2 ----------> ERROR: WAN DOWN
Tue Jul 12 07:55:11 IST 2022 - VPNMON-R2 ----------> ERROR: WAN DOWN
Tue Jul 12 07:56:31 IST 2022 - VPNMON-R2 - API call made to update WAN city to Mumbai
Tue Jul 12 07:56:45 IST 2022 - VPNMON-R2 ----------> ERROR: Connection failed - Executing VPN Reset
Tue Jul 12 07:56:45 IST 2022 - VPNMON-R2 - Executing VPN Reset
Tue Jul 12 07:56:49 IST 2022 - VPNMON-R2 - Killed all VPN Client Connections
Tue Jul 12 07:57:22 IST 2022 - VPNMON-R2 - Updated Skynet Whitelist
Tue Jul 12 07:57:23 IST 2022 - VPNMON-R2 - VPN4 Client ON - Lowest PING of 5 VPN slots
Tue Jul 12 07:57:25 IST 2022 - VPNMON-R2 - VPN Reset Finished
Tue Jul 12 07:57:27 IST 2022 - VPNMON-R2 - Trimmed the log file down to 1000 lines
Tue Jul 12 07:57:27 IST 2022 - VPNMON-R2 - Resuming normal operations
Tue Jul 12 07:57:58 IST 2022 - VPNMON-R2 ----------> ERROR: Connection failed - Executing VPN Reset
Tue Jul 12 07:57:58 IST 2022 - VPNMON-R2 - Executing VPN Reset
Tue Jul 12 07:58:02 IST 2022 - VPNMON-R2 - Killed all VPN Client Connections
Tue Jul 12 07:58:34 IST 2022 - VPNMON-R2 - Updated Skynet Whitelist
Tue Jul 12 07:58:34 IST 2022 - VPNMON-R2 - VPN1 Client ON - Lowest PING of 5 VPN slots
Tue Jul 12 07:58:36 IST 2022 - VPNMON-R2 - VPN Reset Finished
Tue Jul 12 07:58:39 IST 2022 - VPNMON-R2 - Trimmed the log file down to 1000 lines
Tue Jul 12 07:58:39 IST 2022 - VPNMON-R2 - Resuming normal operations
Tue Jul 12 07:58:40 IST 2022 - VPNMON-R2 - API call made to update VPN city to Singapore
As you can see, No activity between, till i initiated the command line reset
Yesterdays Log
I noticed a few of these in your log:
This message could only appear if you executed the "vpnmon-r2 -reset" command... I have no other place where a log entry like that would originate from.
Do you have the "timeout" utility installed?
This is the first time I manually initiated the reset, in fact I had just found out that
.sh is not needed
Full log in case you want to take a closer look: vpnmon-r2.log
Don't know why the log dates are jumbled
