Has anyone got Samba4 working on a R7800? How did you do it? I've got it almost working, apart from the critical part of getting it to serve up files. I'll post all the details, as I've had to do a lot of tweaking, but TLDR;
The last line stops
To get
To set up user-level share control, I first had to create new
Finally, I had to set up my Samba configuration file. I've copied the Samba4 version here, but my Samba3 version is virtually identical. The main difference was that I had to specify different paths to the log file (possibly because the Entware version of Samba4 is compiled with a default
What I can't do is actually browse the files in any share I create. When I try to open the share in Windows, I get the error "\\Nighthawk\USB_Storage is unavailable. If the location is on this PC, make sure the device or drive is connected or the disc is inserted, and then try again..." Connecting from an Android client gives a similar message. When I examine
smbd
gives invalid file handle errors when it tries to open the directories that it is supposed to be sharing.What I'm trying to do
I want to use my R7800 as a mini NAS to serve files on my home network, principally to Windows 10 & 11 clients. Now that Windows has disabled SMB1 and Guest mode access, I want to bring my configuration up to date with WSD instead of NetBIOS for host discovery, proper user-level file share security, and ideally SMB3 as the transfer protocol. I can do most of this with Samba3, but moving from SMB2 to SMB3 seems to require using Samba4.My set-up
- Netgear R7800 Nighthawk X4S with Voxel V1.0.2.113SF firmware (thanks Voxel!)
- Entware installed on WD Elements external USB HDD, mounted at
/tmp/mnt/sda1
, formatted with ext4. This drive also has the files I want to share. - SSH access enabled (so I'm happy configuring from the command line, and don't need to use the GUI to configure Samba).
smbd
v3.6.25 from Voxel's firmware (works).smbd
v4.18.8 from Voxel's Entware repo (doesn't work).- Windows 10 and 11 SMB clients, with SMB1 and NetBIOS over TCP disabled.
- Various other non-Windows clients (Raspberry Pi, Android, etc.) that are less important to support.
What I've done that works
Now that SMB1 is disabled by default on Windows, Samba servers don't show up in the Network area of Windows File Explorer any more. The solution is to use WSD instead. Hence I've followed the instructions in the Readme for Voxel's firmware to install Entware, then installed thesamba4-server
and wsdd2
packages:
/opt/bin/opkg update
/opt/bin/opkg upgrade
/opt/bin/opkg install wsdd2
rm /opt/etc/init.d/S99wsdd2
wsdd
using Entware's startup scripts. When I used these, I found that my router would be discovered by Windows, but with a default Entware hostname, ignoring what I set as a command line parameter. This meant that Windows couldn't open a connection to the router. When I ran wsdd
directly, it worked fine and used the same hostname as smbd
without any further configuration.To get
wsdd
to start and stop automatically, I added it to the Samba init script, /etc/init.d/samba
. I also removed the commands to run AFP (as I don't have any Apple devices) and changed the commands that set up configuration files, to use my custom versions rather than the firmware defaults. (Not relevant to Samba, but I also removed AFP from my Avahi configuration at this point). My /etc/init.d/samba
file now looks like this:
Bash:
#!/bin/sh /etc/rc.common
START=86
CUSTOM=/mnt/sda1/firmware
PRIVATE_DIR=/tmp/private
start()
RUN_D=/var/run/samba
SMB_CONF_DIR=/tmp/samba
SYS_CONF_DIR=/tmp/config
SMBD_PID_F=$RUN_D/smbd.pid
SMB_PASSWD_DIR=/tmp/smbpasswd
mkdir -p /var/run/samba/locks
mkdir -p $SMB_CONF_DIR
# cp -f $CUSTOM/etc/samba/samba3.conf $SMB_CONF_DIR/smb.conf
cp -f $CUSTOM/etc/samba/samba4.conf $SMB_CONF_DIR/smb.conf
cp -f $CUSTOM/etc/samba/lowcase.dat $SMB_CONF_DIR
cp -f $CUSTOM/etc/samba/upcase.dat $SMB_CONF_DIR
cp -f $CUSTOM/etc/samba/valid.dat $SMB_CONF_DIR
mkdir -p $SYS_CONF_DIR
cp -f $CUSTOM/usr/config/passwd $SYS_CONF_DIR
cp -f $CUSTOM/usr/config/group $SYS_CONF_DIR
mkdir -p $PRIVATE_DIR
cp -f $CUSTOM/etc/samba/smbpasswd $PRIVATE_DIR
cp -f $CUSTOM/etc/samba/passdb.tdb $PRIVATE_DIR
mkdir -p $RUN_D
/usr/sbin/update_smb
/etc/init.d/dbus start
/etc/init.d/avahi-daemon start
/opt/bin/wsdd2 -d
stop() {
killall -9 smbd
cp -f $PRIVATE_DIR/passdb.tdb $CUSTOM/etc/samba/passdb.tdb
/etc/init.d/avahi-daemon stop
/etc/init.d/dbus stop
killall wsdd2
boot() {
start &
/etc/init.d/kcode boot
[ "$1" = "start" ] && start
[ "$1" = "stop" ] && stop
smbd
is actually started by /usr/sbin/update_smb
, which is a binary in the firmware and is hard coded to use the original Samba3 smbd
. It also re-writes /etc/smb.conf
, which is unhelpful. I used strings
to try to guess what it was doing, then created a replacement script to replicate the necessary bits:
Bash:
#!/bin/sh
if /bin/pidof smbd > /dev/zero 2>&1; then
# Restart any smbd processes that are already running
echo Restarting running smbd
/usr/bin/killall -SIGHUP smbd
else
# Start a new process
/usr/sbin/taskset -p 3 `/bin/pidof usb-storage` > /dev/null 2>&1
# Samba3
# /usr/sbin/taskset -c 1 /usr/sbin/smbd -D -l /var/log/log.smbd > /dev/null 2>&1
# Samba4
/usr/sbin/taskset -c 1 /opt/sbin/smbd -D --configfile /etc/samba/smb.conf -l /var/log > /dev/null 2>&1
/usr/sbin/taskset -p 1 `/bin/pidof usb-storage` > /dev/null 2>&1
fi
/etc/passwd
and /etc/groups
files, to create new Linux users. I was then able to use smbpasswd
to set up matching Samba users (which doesn't work if the Linux users aren't valid). I tried using a tbdsam
password backend for Samba4, but had to use a plain smbpasswd
file for Samba3, as tbdsam
isn't supported. Some of the tweaks to the init script make sure that all these configuration files are copied from my HDD to the right places at runtime.Finally, I had to set up my Samba configuration file. I've copied the Samba4 version here, but my Samba3 version is virtually identical. The main difference was that I had to specify different paths to the log file (possibly because the Entware version of Samba4 is compiled with a default
/opt
prefix on all its configuration files); this also had to be specified on the command line for Samba3, and caused server startup to abort if it was wrong. I also tried tweaking the protocol version configuration. For Samba3, I added min protocol = SMB2
to disable SMB1, and tried removing the max protocol = SMB2
line. However, SMB3 doesn't seem to be supported by Samba3 and I started to get connection areas. Samba4 defaults to SMB2 anyway, and seemed happy allowing any higher version, but I've restricted it to SMB2 for debugging.
[global]
workgroup = WORKGROUP
netbios name = Nighthawk
disable netbios = yes
lm announce = no
bind interfaces only = yes
server string = Study router
log file = /var/log
log level = 10
max log size = 10
obey pam restrictions = no
disable spoolss = yes
strict allocate = no
host msdfs = no
security = user
map to guest = Never
pam password change = no
smb encrypt = disabled
# min protocol = SMB3_11
max protocol = SMB2
passdb backend = smbpasswd:/mnt/sda1/firmware/etc/samba/smbpasswd
private dir = /tmp/private
state directory = /var/run/samba/locks
cache directory = /var/run/samba/locks
lock directory = /var/run/samba/locks
enable core files = no
deadtime = 30
use sendfile = yes
map archive = no
map hidden = no
map read only = no
map system = no
store dos attributes = yes
dos filemode = yes
oplocks = yes
level2 oplocks = yes
kernel oplocks = no
wide links = no
min receivefile size = 16384
socket options = IPTOS_LOWDELAY TCP_NODELAY SO_KEEPALIVE SO_RCVBUF=131072 SO_SNDBUF=131072
[USB_Storage]
path = /tmp/mnt/sda1/
browsable = yes
writeable = yes
guest ok = no
valid users = root, admin, james
force directory mode = 0777
force create mode = 0777
What doesn't work
With the above configuration (give or take logging), Samba3 seems to work fine. Samba4 works to a certain extent: I can discover the server in Windows (using WSD discovery), and after I have authenticated, I can see the shared folder. This tells me that user authentication is working: Windows 11 doesn't let you connect as a guest, so Samba won't show you the list of shares unless you are authenticated.What I can't do is actually browse the files in any share I create. When I try to open the share in Windows, I get the error "\\Nighthawk\USB_Storage is unavailable. If the location is on this PC, make sure the device or drive is connected or the disc is inserted, and then try again..." Connecting from an Android client gives a similar message. When I examine
/var/log/log.smbd
, I can see that the client connection is accepted and the user is validated, but when the server attempts to open the root directory of the share (i.e. .
), it gets a bad file handle, which leads to a NT_STATUS_INVALID_HANDLE
error, followed by NT_STATUS_OBJECT_PATH_NOT_FOUND
. This message is too long to include the log here, so I'll continue in a follow-on post.
