Hi All,
I have a ds1511+ running 5 2TB Samsung HD204UI drives in a RAID 5 configuration. System has not missed a beat since setup a year ago. But, I'm a little paranoid about losing data so I tried today to buy a spare Hdd in case of drive failure to find out Samsung drives are no longer available since being bought out by Seagate.
I'm trying to find the best replacement Hdd to drop into my RAID 5 in case of drive failure, keeping in mind the HD204UI specs and low 5400rpm spin rate.
I've been told as long as I put another 2TB drive in it will be ok, but do I need to make sure it's also a 5400rpm drive or could I use a 7200rpm drive (Seagate for example)
All my important stuff is backed up externally but I would still prefer not to have any loses especially if it can be avoided.
Any suggestions and technical advise will be appreciated.
