save/upload Manually Assigned IP around the DHCP list
It is incorporated once installed !
Yes, plus some more. Save the following files from /jffs/nvram:
custom_clientlist
custom_usericon
dhcp_staticlist
After reset, enable Manual Assignment in DHCP, restore the files, reboot.
You have all your DHCP reservations, custom client names and icons back.
Not applicable for most IoT devices like lights, switches, smart plugs, etc.
Hi, i'm trying this, connected to router via WINSCP, but the program can't download the files...
Unable to run SCP to start transfer. Make sure SCP is installed on the server and its path is included in the PATH variable. You can also try SFTP instead of SCP.
Command failed with return code 127.
Where i'm wrong?
Asus ET12 with latest firmware installed...
THANKS!
Asus ET12 is not compatible with Merlin firmware.. and has not a USB port.. :(
Where i'm wrong?
THANKS!
SCP was removed from stock firmware and it never supported SFTP.
