SBS. Script for using sing-box on Asus routers with Merlin firmware.
Assuming data goes from your client over wan to sinbox sbtun interface onwards to wan it will be subject of MASQUARADE when leaving the router wan interface which is why it appears to come from your router wan ip externally. But internally, what address would data appear to come from?
Are routes set up for this ip to go to sbtun interface. If your clients use policy route tables, are these routes present there as well?
Firewall issues, are proper firewall routes in place on the router to allow new connections to be made from sbtun to br0 interface?
Are lan client own firewall accepting incoming connections from sbtun address range?
The tun interface is not used to access the proxy server. Simply after adding the proxy server settings to the sing-box configuration file and after rebooting it, sing-box starts listening to the port specified in the proxy server settings, working as a regular proxy server. The tun interface does not even need to be specified in the configuration file, proxy servers do not interact with it in any way. We need to somehow understand where exactly the traffic addressed to local resources goes from sing-box. In my configuration file, it is specified that it should go to direct. This means that it will not be routed to any of the proxy tunnels specified in the configuration file. Where exactly it goes on the router is not clear to me. Although, perhaps, this is not particularly important. Traffic to external sites comes from the external IP address of the router, which means that from sing-box it goes to direct, and not to tunnels. Here are my routing rules:
0:      from all lookup local
78:     from 192.168.50.52 lookup main
79:     from 192.168.50.51 lookup main
80:     from 192.168.50.50 lookup main
81:     from 192.168.50.46 lookup main
82:     from 192.168.50.41 lookup main
83:     from 192.168.50.37 lookup main
84:     from 192.168.50.36 lookup main
85:     from 192.168.50.35 lookup main
86:     from 192.168.50.34 lookup main
87:     from 192.168.50.30 lookup main
88:     from 192.168.50.1 lookup main
89:     from 192.168.50.0/24 lookup 5553
90:     from all to 10.6.0.2 lookup main
90:     from all to 10.6.0.3 lookup main
90:     from all to 10.6.0.4 lookup main
90:     from all to 10.6.0.5 lookup main
90:     from all to 10.6.0.6 lookup main
90:     from all to 10.6.0.7 lookup main
32766:  from all lookup main
32767:  from all lookup default
Table 5553 is the table for sing-box. Here are the routes in this table:
default dev sbtun scope link
10.6.0.2 dev wgs1 scope link
10.6.0.3 dev wgs1 scope link
10.6.0.4 dev wgs1 scope link
10.6.0.5 dev wgs1 scope link
10.6.0.6 dev wgs1 scope link
10.6.0.7 dev wgs1 scope link
95.165.64.1 dev ppp0 proto kernel scope link
127.0.0.0/8 dev lo scope link
169.254.0.0/16 dev eth0 proto kernel scope link src 169.254.251.191
172.19.0.0/28 dev sbtun proto kernel scope link src 172.19.0.1
192.168.50.0/24 dev br0 proto kernel scope link src 192.168.50.1
Except for the default route, all others are automatically copied by the sing-box script from the 'main' table.
I noticed that for the built-in wireguard server in the nat table there is a rule
-A LOCALSRV -p udp -m udp --dport <wireguard_server_port> -j ACCEPT
I created similar ones for udp and tcp for my proxy server, but this did not solve the problem.
I believe that another problem I wrote about earlier has the same cause https://www.snbforums.com/threads/s...outers-with-merlin-firmware.90762/post-918618
I think I found the reason. On the router, the sing-box "auto_detect_interface" function works a little incorrectly. When I deleted it and manually specified the interface for proxy outbounds in the config, in my case it was ppp0, then everything worked as it should.
I concluded that "auto_detect_interface" worked correctly only for proxy outbounds, but for direct outbound it apparently assigned the wrong interface. I couldn't determine which one is correct for direct, it doesn't work with br0 or lo, but without specifying it everything works correctly.
This also solved the problem of lack of access to the DNS server in the local network.
I am confused by the description of this function https://sing-box.sagernet.org/configuration/route/#auto_detect_interface
But I still removed it and removed "bind_interface" from all outbounds in the configuration file, so far everything works correctly without them, I will observe for some time.
Another update of my script for downloading, installing, configuring and running sing-box on Asus routers with Merlin firmware.
Updated 10/13/2024. Version v1.5
Changes:
1. Added a new menu called by the
sbs server
command to specify ports that will be opened from WAN to the router when sing-box starts and closed when it stops. This will be useful for sing-box to work not only in client mode, but also in server mode with access from WAN, if you need it. For sing-box to work in server mode with access from WAN, specify at least one inbound proxy server with encryption and authorization in the sing-box configuration file.
2. The script code has been modified to work with only one TUN interface, since the functionality added by the second TUN interface can be implemented with just a couple of simple rules in the sing-box configuration file. This allowed us to solve problems when creating NAT rules for several subnets of different sizes, and also reduced the code size by a third.
3. Due to the reduction of the permitted number of tun interfaces to one, the template of the sing-box configuration file has been changed.
4. To maintain priorities, the logic of adding routing and nat rules by the main script and monitor has been changed. Now, when configuring the script in the 'sbs setup' menu, you can add any number of subnets of any size and in any order. As a result, in the routing and nat rules created by the script, smaller subnets will always have priority over larger ones.
5. A new option has been added to the IP address settings in the 'sbs setup' menu - 'Add/remove IP addresses'. It works like this: enter IP addresses, separating them with spaces, those that are already in the list will be removed from it, and those that are not will be added.
6. The item for editing the sbs-conf file in the nano editor has been removed from the 'sbs setup' menu.
7. Changed the menu command for editing and checking the config.json file from 'sbs edit' to
sbs config
8. The numbering of some of the choices provided by the script has been changed. Be careful when selecting options if you are used to their original numbering.
9. The names of variables in the sbs-conf file created by the script have been changed.
10. Several minor edits to the script code.
Updated to version 1.5.
1) After start have errors:
+0000 2024-10-14 22:42:07 ERROR [2795013845 3.6s] inbound/tun[tunin]: dial tcp 10.0.0.1:443: connect: connection timed out
+0000 2024-10-14 22:42:26 ERROR [3834953 3.10s] inbound/tun[tunin]: dial tcp 10.0.0.1:443: connect: connection timed out
+0000 2024-10-14 22:42:29 ERROR [2851788221 3.6s] inbound/tun[tunin]: dial tcp 10.0.0.1:443: connect: connection timed out
+0000 2024-10-14 22:42:47 ERROR [2587242586 3.11s] inbound/tun[tunin]: dial tcp 10.0.0.1:443: connect: connection timed out
+0000 2024-10-14 22:42:50 ERROR [3931895058 3.6s] inbound/tun[tunin]: dial tcp 10.0.0.1:443: connect: connection timed out
+0000 2024-10-14 22:43:08 ERROR [807860283 3.11s] inbound/tun[tunin]: dial tcp 10.0.0.1:443: connect: connection timed out
+0000 2024-10-14 22:43:11 ERROR [1764975789 3.6s] inbound/tun[tunin]: dial tcp 10.0.0.1:443: connect: connection timed out
+0000 2024-10-14 22:43:29 ERROR [1928847714 3.9s] inbound/tun[tunin]: dial tcp 10.0.0.1:443: connect: connection timed out
Didn't have it in 1.3. Everything works correctly, but I would like to fix them.
2) Didn't measure on 1.3, but now speed dropped from 500 Mbps to 100 when download/upload in direct mode (without VPN). I assume the situation was similar with 1.3. Are there any ways to increase performance?
P.S. ASUS RT-AX58U Firmware version 3.0.0.4.388_25127 with entware on hdd.
So you have stock firmware? Not Merlin? My script is designed for Merlin firmware and uses some of its features that are not available in the stock firmware, such as hook scripts. In any case, I suggest we discuss the problems in conversation.
Merlin doesn't release firmware for my router, so I installed the entware myself on external hdd
Updated 10/20/2024. Version v1.6
Changes:
1. Fixed termination of the sing-box process when exiting any script menu using the Ctrl+C key combination, if this menu was entered in the same terminal session as the last launch of sing-box.
2. When stopping sing-box, all records created by the sing-box script at its start are deleted from the firewall-start, nat-start and services-start scripts, according to the text of the "sing-box-script" comment added to the records. This guarantees the deletion of all records created by the script, without harming others.
3. Several more bugfixes.
Updated 11/25/2024. Version v1.7
Changes:
1. Implemented fakeip support for routing only selected domains via sing-box.
2. Removed the choice of DNS server source. Now sing-box can only use DNS servers specified in the sing-box configuration file.
3. Added the system kernel version to the 'sbs status' command output.
4. Bugfixes, improvements and optimizations.
New update of my script for downloading, installing, configuring and running sing-box on Asus routers with Merlin firmware.
Updated 04/09/2025. Version v1.8
Changes:
1. In the script code, 'curl' has been replaced with 'wget' to avoid errors on some routers.
2. The Russian and English versions of the script have been combined into one. The desired language is selected when installing the script, but it can then be changed through the menu called by the
sbs lang
command, or by selecting item 9 in the main menu called by the
sbs
command.
3. Optimization of some sections of the script code.
4. After updating to version 1.8, all subsequent updates will be performed only through the menu called by the
sbs update
command.
Updated 04/12/2025. Version v1.9
Changes:
1. The output of the
sbs status
command now includes information about ports from the WAN opened by the script, if the ports are configured in the
sbs server
menu and the script is running.
2. Now, when using regular sing-box routing for some IP addresses/subnets and routing via fakeip for others, you don't need to manually add IP addresses/subnets configured for operation via fakeip to the exceptions of regular routing. In this regard, changes have been made to the Readme (section IV, items 3 and 4).
3. Correction of the sorting order of subnets to form the correct order of routing rules.
Another update of my script for installing, configuring and running sing-box on Asus routers with Merlin firmware.
Updated 05/03/2025. Version v2.0
Changes:
1. When starting the script, a check for duplicates of added IP addresses and subnets is added. If any are found, the script start is canceled with a notification about duplicates. This is necessary for the correct operation of the script.
2. Added fakeip support for sing-box kernels versions 1.12.*
3. Added support for the tproxy interface.
4. A submenu of advanced settings has been added to the 'sbs setup' menu.
5. The option to change the routing table number has been moved to the submenu of advanced settings of the 'sbs setup' menu. Also, the ability to change the tproxy-mark has been added to this submenu, which appears if the tproxy interface is specified in the sing-box configuration file.
6. Optimization of some sections of the old code.
Updated 06/21/2025. Version v2.1
Changes:
1. When parsing the config.json configuration file by the script, commented lines are now ignored.
2. Added the ability to select a repository for installing the sing-box kernel. The official and 2 custom ones to choose from. For this, a 3rd item has been added to the 'sbs update' menu to change the sing-box kernel repository and configure custom repositories.
3. Several optimizations and improvements to the code of the main script and the monitor script.
Updated 07/17/2025. Version v2.2
Changes:
1. In the 'sbs update' menu, item 3 has been changed. Now, in addition to the submenu for selecting a repository, a submenu for selecting the sing-box kernel version has been added.
2. Automatic checks of the router's CPU architecture and the system kernel version have been added when installing the script. If the minimum requirements are not met, the installation is canceled with a message about the discrepancy between one or the other.
3. Some optimizations of the old code.
You can see the Readme.txt and Changes.txt files on the script's github page https://github.com/Dr4tez/sing-box4asus
Updated 09/28/2025. Version v2.3.0
Changes:
1. The mangle, nat, ip route, and ip rule rules generated by the script have been reworked. Packet marking is now also used for the tun interface.
2. The config.json configuration file no longer requires a special direct inbound for accepting DNS requests. The configuration file templates have been changed accordingly. Please make the corresponding change to your config.json configuration file.
3. Improvements and optimizations of the old code.
I installed version 2.3 and am just learning how it works, but today, through "sbs update," I discovered that 2.3.4 is already available. Does it make sense to update? Is this some kind of working, test version? Because it's not even clear what's changed in it.
Lately, I've adopted a rule: if updates contain only fixes for reported bugs, only the third digit of the version number changes, and I usually don't report such updates. You can see the code changes at https://github.com/Dr4tez/sing-box4asus/commits/main/sbs Typically, only one person reports a bug to me, I make a fix and notify them; most users don't even notice these bugs. Sometimes, when working on the next version, I notice something that others probably wouldn't notice and make corrections. Sometimes this only affects the text output by a script on the command line, and sometimes only comments in files.
I recommend always updating whenever a new version is found in the 'sbs update' menu, even if there are no messages about it. The test version is in a different branch.
... I recommend always updating whenever a new version is found in the 'sbs update' menu, even if there are no messages about it. The test version is in a different branch.
Got it. Thanks. Another question: if I use inbounds tproxy, is ALL external traffic from the LAN routed to the sing-box or just some of it, according to the rules specified in the JSON file?
When using TProxy, only TCP and UDP traffic from devices whose local IP addresses are specified in the 'sbs setup' menu reaches sing-box. This traffic is then routed by sing-box according to the rules specified in config.json.
You can route only traffic intended for proxying through the sing-box. To do this, specify the fakeip settings and the required fakeip rules for the selected devices in the config.json file, and then specify the IP addresses of these devices in the corresponding "sbs setup" menu item. This is described in the readme.txt.
Updated 12/01/2025. Version v2.4.0
Changes:
1. Added a menu for setting RAM usage limits, called with the 'sbs limit' command.
2. Added support for the wireguard and anytls types to the 'sbs server' menu.
3. The output of the 'sbs status' command, when sing-box is running, now includes the time and date the main sing-box script was started, its unique memory and CPU usage, the interface type used (TUN or TPROXY), and the time and date the sbs-monitor script was started.
4. Changed the logic for navigating and entering values in all menus: now you exit by pressing Enter without entering values, '0' clears the values, and '0 <new_values>' replaces all values with new ones.
5. Input validation has been added to all menus.
6. Only one custom repository can now be configured in the 'sbs update' menu. If you were using any of them, you will need to configure it again after the update.
7. The 'sbs setup' menu has been renamed from "Script configuration menu." to "Menu for setting up devices routing via sing-box."
8. In the 'sbs setup' menu, the 'Advanced, but not required, settings.' has been renamed to "Optional expert settings."
9. Numerous messages have been changed and added.
10. Some changes and additions to the readme.
11. Some changes to the menu structures.
12. Improvements and optimizations of the old code.
