v1rt
This is the firewall-start that's currently active. Today is Sunday. My son's connection got blocked an hour after the schedule that is active in iptables. I thought it was fixed but it isn't.
Here is my firewall-start script.
My mac laptop is showing the same time but timezone is showing CDT.
In my Asus Administration->System tab under Miscellaneous then Time Zone, it says (GMT-6:00) Central Time (US, Canada)
Here is the output of iptables -vnL
https://gist.github.com/c0debreaker/72dee8f738c8f85d507c
Now, I removed the --kerneltz and refreshed the firewall script, this is the output iptables -vnL. It is now in UTC. https://gist.github.com/c0debreaker/e4d9c956ca49b20f6b6a
#!/bin/sh
# Locate both "RELATED,ESTABLISHED" and "INVALID" rules to place the Inserts after
InsLoc=`iptables -nvL INPUT --lin | grep -A 1 -i "RELATED,ESTABLISHED" | tail -n 1 | awk '{ print $1 }'`
if [ "x$InsLoc" == "x" ]
then
# echo "Rule RELATED,ESTABLISHED not found"
# Add rule to continue existing connections
iptables -I INPUT 1 -m conntrack --ctstate ESTABLISHED,RELATED -j ACCEPT
InsLoc=2
fi
InsLoc1=`iptables -nvL INPUT --lin | grep -A 1 -i "INVALID" | tail -n 1 | awk '{ print $1 }'`
if [ "x$InsLoc1" == "x" ]
then
# echo "Rule INVALID not found"
# Add rule to Drop unexpected traffic
iptables -I INPUT $InsLoc -m conntrack --ctstate INVALID -j DROP
InsLoc1=`expr $InsLoc + 1`
fi
if [ $InsLoc1 -gt $InsLoc ]
then
# use which ever comes last
InsLoc=$InsLoc1
fi
echo "InsLoc=$InsLoc"
# League of Legends Game Client
iptables -I FORWARD $InsLoc -i br0 -o eth0 -p tcp --dport 5000:5500 -m time --timestart 13:00:00 --timestop 03:00:00 --weekdays Mon,Tue,Wed,Thu --kerneltz -j DROP
iptables -I FORWARD $InsLoc -i br0 -o eth0 -p udp --dport 5000:5500 -m time --timestart 13:00:00 --timestop 03:00:00 --weekdays Mon,Tue,Wed,Thu --kerneltz -j DROP
iptables -I FORWARD $InsLoc -i br0 -o eth0 -p tcp --dport 5000:5500 -m time --timestart 22:30:00 --timestop 03:00:00 --weekdays Fri,Sat --kerneltz -j DROP
iptables -I FORWARD $InsLoc -i br0 -o eth0 -p udp --dport 5000:5500 -m time --timestart 22:30:00 --timestop 03:00:00 --weekdays Fri,Sat --kerneltz -j DROP
iptables -I FORWARD $InsLoc -i br0 -o eth0 -p tcp --dport 5000:5500 -m time --timestart 20:00:00 --timestop 03:00:00 --weekdays Sun --kerneltz -j DROP
iptables -I FORWARD $InsLoc -i br0 -o eth0 -p udp --dport 5000:5500 -m time --timestart 20:00:00 --timestop 03:00:00 --weekdays Sun --kerneltz -j DROP
# Patcher and Maestro
iptables -I FORWARD $InsLoc -i br0 -o eth0 -p tcp --dport 8393:8400 -m time --timestart 13:00:00 --timestop 03:00:00 --weekdays Mon,Tue,Wed,Thu --kerneltz -j DROP
iptables -I FORWARD $InsLoc -i br0 -o eth0 -p tcp --dport 8393:8400 -m time --timestart 22:30:00 --timestop 03:00:00 --weekdays Fri,Sat --kerneltz -j DROP
iptables -I FORWARD $InsLoc -i br0 -o eth0 -p tcp --dport 8393:8400 -m time --timestart 20:00:00 --timestop 03:00:00 --weekdays Sun --kerneltz -j DROP
# 2099 TCP - PVP.Net
iptables -I FORWARD $InsLoc -i br0 -o eth0 -p tcp --dport 2099 -m time --timestart 13:00:00 --timestop 03:00:00 --weekdays Mon,Tue,Wed,Thu --kerneltz -j DROP
iptables -I FORWARD $InsLoc -i br0 -o eth0 -p tcp --dport 2099 -m time --timestart 22:30:00 --timestop 03:00:00 --weekdays Fri,Sat --kerneltz -j DROP
iptables -I FORWARD $InsLoc -i br0 -o eth0 -p tcp --dport 2099 -m time --timestart 20:00:00 --timestop 03:00:00 --weekdays Sun --kerneltz -j DROP
# 5223 TCP - PVP.Net
iptables -I FORWARD $InsLoc -i br0 -o eth0 -p tcp --dport 5223 -m time --timestart 13:00:00 --timestop 03:00:00 --weekdays Mon,Tue,Wed,Thu --kerneltz -j DROP
iptables -I FORWARD $InsLoc -i br0 -o eth0 -p tcp --dport 5223 -m time --timestart 22:30:00 --timestop 03:00:00 --weekdays Fri,Sat --kerneltz -j DROP
iptables -I FORWARD $InsLoc -i br0 -o eth0 -p tcp --dport 5223 -m time --timestart 20:00:00 --timestop 03:00:00 --weekdays Sun --kerneltz -j DROP
# 5222 TCP - PVP.Net
iptables -I FORWARD $InsLoc -i br0 -o eth0 -p tcp --dport 5222 -m time --timestart 13:00:00 --timestop 03:00:00 --weekdays Mon,Tue,Wed,Thu --kerneltz -j DROP
iptables -I FORWARD $InsLoc -i br0 -o eth0 -p tcp --dport 5222 -m time --timestart 22:30:00 --timestop 03:00:00 --weekdays Fri,Sat --kerneltz -j DROP
iptables -I FORWARD $InsLoc -i br0 -o eth0 -p tcp --dport 5222 -m time --timestart 20:00:00 --timestop 03:00:00 --weekdays Sun --kerneltz -j DROP
# 8088 Spectator Mode
iptables -I FORWARD $InsLoc -i br0 -o eth0 -p tcp --dport 8088 -m time --timestart 13:00:00 --timestop 03:00:00 --weekdays Mon,Tue,Wed,Thu --kerneltz -j DROP
iptables -I FORWARD $InsLoc -i br0 -o eth0 -p tcp --dport 8088 -m time --timestart 22:30:00 --timestop 03:00:00 --weekdays Fri,Sat --kerneltz -j DROP
iptables -I FORWARD $InsLoc -i br0 -o eth0 -p tcp --dport 8088 -m time --timestart 20:00:00 --timestop 03:00:00 --weekdays Sun --kerneltz -j DROP
admin@RT-AC68U-6000:/jffs/scripts# date
Sun Apr 12 20:42:26 DST 2015
