Hi folks!
I'm trying to figure out how to control (simply to enable and disable) AiProtection from the command line. What I would like to do is, set up a cron-based schedule to enable and disable AiProtection Parental Controls (or a client entry within it - I don't mind which).
The problem is, AiProtection offers Web & Apps Filters, and Time Scheduling, but not the intersection of the two: I would like to permit all access to a device normally, but filter out certain apps/websites during set times of particular days (6am-6pm M-F only). The result would be: other (not listed) client devices have unrestricted access at all times. Listed device(s) have unrestricted access outside the scheduled times, restricted access (but still have internet access) within those times.
I think the following are the cru commands to create the schedule, and I understand I'd need to set up a jffs script those commands to make them survive router reboots... I just need the missing command.
cru a filtering-on "0 6 MON-FRI * * [turn AiProtection Parental Controls on]"
cru a filtering-off "0 18 MON-FRI * * [turn AiProtection Parental Controls off]"
Any ideas?
Any ideas?
