Scheduled reboot set up issue
To RMerlin
It's fatality:(
try as You wrote:
1. enable "Format JFFS partition at next boot"
2. press "Apply"
3. putty (SSH)
ASUSWRT-Merlin RT-AC68U_3.0.0.4 Sat Jun 7 16:32:17 UTC 2014
admin@RT-AC68U:/tmp/home/root# nvram unset jffs2_size
admin@RT-AC68U:/tmp/home/root# nvram commit
admin@RT-AC68U:/tmp/home/root# reboot
and see again
admin@RT-AC68U:/tmp/home/root# cat << EOF > /jffs/scripts/services-start
> #!/bin/sh
> /usr/sbin/cru a ScheduledReboot "0 5 * * * reboot"
> EOF
-sh: can't create /jffs/scripts/services-start: nonexistent directory
It's fatality:(
2. press "Apply"
3. putty (SSH)
and see again
> #!/bin/sh
> EOF
No idea then. You must be skipping a step somewhere, or something else is wrong, cause this should just work. Check in System Log for any error related to jffs2, otherwise I have no other idea.
Type the following commands and show us the output:
# mount
# nvram get jffs2_on
# ls -l /jffs/
# mkdir /jffs/scripts
# grep -i jffs /tmp/syslog.log
admin@RT-AC68U:/tmp/home/root# mount
rootfs on / type rootfs (rw)
/dev/root on / type squashfs (ro,relatime)
devtmpfs on /dev type devtmpfs (rw,relatime,size=127720k,nr_inodes=31930,mode=755)
proc on /proc type proc (rw,relatime)
tmpfs on /tmp type tmpfs (rw,relatime)
sysfs on /sys type sysfs (rw,relatime)
devpts on /dev/pts type devpts (rw,relatime,mode=600)
usbfs on /proc/bus/usb type usbfs (rw,relatime)
admin@RT-AC68U:/tmp/home/root# nvram get jffs2_on
1
admin@RT-AC68U:/tmp/home/root# ls -l /jffs/
admin@RT-AC68U:/tmp/home/root# mkdir /jffs/scripts
mkdir: can't create directory '/jffs/scripts': Read-only file system
admin@RT-AC68U:/tmp/home/root# grep -i jffs /tmp/syslog.log
Jan 1 04:00:13 kernel: 0x000004000000-0x000006000000 : "jffs2"
