Scheduling rebooting??
"0 6 2 * *"
You want Tuesday, of any month (*) and any week (*).
"0 6 2 * 1"
Would be the Tuesday, of any month (*), the first week (1).
That's at least the theory. The "week" parameter isn't a standard cron parameter AFAIK, might be specific to the crond build in Busybox I guess.
Hi Sorry to bother you and I apologize for bumping such an old topic. I started learning merlin and its capabilities from this very own forum topic.
If I want Tuesday, of any month (*) and any week (*), it would be:
0 6 * * 2
Isnt it?
I was a bit confused.
It's:
min hour day month week
# cru
Cron Utility
add:    cru a <unique id> <"min hour day month week command">
delete: cru d <unique id>
list:   cru l
It's:
# cru
Cron Utility
list:   cru l
I tried for my own reboot schedule "0 5 3 * *" I wanted to reboot every Wednesday 5AM.
But this script rebooted my router yesterday at 5am. May 3rd.
http://www.openjs.com/scripts/jslibrary/demos/crontab.php
And this generator also tells me to change the "week" part instead of the "day."
"0 5 * * 3" ?
Still confused.
It did exactly what you told it....
min = 0, hour = 5, day of month = 3, month = any, day of week = any
You want "0 5 * * 3"
(for day of week, Sunday is either 0 or 7)
RMerlin had it "0 X X * *" this way but "X X * * X" seems the right one for what I want to do. Thanks a lot!
Good spot John. Perhaps "cru l" should say "day-of-week" instead of "week" to avoid confusion.
Regarding RMerlin's comment that "week" is non-standard. This has been the standard format in every version of Unix I've come across.
will this guide http://www.snbforums.com/threads/scheduling-rebooting.11044/#post-68429 work with 378.53 ?
im bit confused because Enable JFFS partition is already activated standard
i need activate the both menus too?
Format JFFS partition at next boot
Enable JFFS custom scripts and configs
in the wiki it say:
#!/bin/sh
cru a ScheduledReboot "0 4 * * * /sbin/reboot"
Put this inside an init-start user script.
i need create a file with notepad++? save it as (txt, sh.)?
in the wiki it say:
#!/bin/sh
I know I'm not in a place to give someone a tip about merlin as I just learned it but I successfully have this done so maybe I'll give it a go.
Use the putty.exe as mentioned by Rmerlin and connect with telnet. Have those codes entered one line at a time. And it creates the .sh for you.
colin it didnt work
i created a file init-start no extension there i add
#!/bin/sh
put it in /jffs/scripts/ and rebooted router
Creating scripts
Don't forget to set any script you create as being executable:
chmod a+rx /jffs/scripts/*
it didnt worked :(
JFFS enabled
custom script enabled
init-start file created with
#!/bin/sh
added in /jffs/scripts/
chmod 0755 for the file only
and router manual restarted
