Scribe Scribe 2.4.4 is out
@visortgw and @JGrana (and anyone else who wants to be a guinea pig ...
The gamma version of scribe has been updated. I *think* this should work on routers where syslogd wants to write to /jffs, but I can't test that part.
If you want to try the gamma version, follow the instructions here: https://www.snbforums.com/threads/scribe-2-5-0-testers-needed.84478/
Trying to remember my logic from years ago makes my brain hurt.
I am away for a few days. I‘ll do some testing this Monday.
Thanks!
@cmkelley Hope this shows you what you need. Let me know if you need anything else — I will be in and out today, but I will definitely get back to you.
                            _
                         _ ( )
       ___    ___  _ __ (_)| |_      __
     /',__) /'___)( '__)| || '_`\  /'__`\
     \__, \( (___ | |   | || |_) )(  ___/
     (____/`\____)(_)   (_)(_,__/'`\____)
     syslog-ng and logrotate installation
     v2.5_0 (gamma)     Coded by cmkelley
     s.    Show scribe status
     rl.   Reload syslog-ng.conf
     lr.   Run logrotate now
     rs.   Restart syslog-ng
     st.   Stop syslog-ng & logrotate cron
     u.    Update scribe
     uf.   Update filters
     su.   scribe utilities
     e.    Exit scribe
     is.   Reinstall scribe
     zs.   Remove scribe
 Please select an option: s
      checking syslog-ng daemon ... alive.
 checking system for necessary scribe hooks ...
          checking S01syslog-ng ... present.
         checking service-event ... present.
            checking post-mount ... present.
               checking unmount ... present.
    checking logrotate cron job ... present.
       checking directory links ... present.
 checking syslog-ng configuration ...
   syslog-ng.conf version check ... in sync. (3.38)
    syslog-ng.conf syntax check ... okay!
          scribe installed version: v2.5_0 (gamma)
             scribe GitHub version: v2.5_0 (gamma)
                    scribe is up to date!
 Press [Enter] to continue:
# pwd
/tmp
# ls -al syslog*
lrwxrwxrwx    1 TheS1R   root            21 Apr 22 09:22 syslog.log -> /opt/var/log/messages
lrwxrwxrwx    1 TheS1R   root            18 Apr 22 09:22 syslog.log-1 -> /jffs/syslog.log-1
# cat syslog.log
Apr 22 09:22:20 GT-AX6000-9980 uiScribe: Mounting WebUI page for uiScribe
Apr 22 09:22:20 GT-AX6000-9980 uiScribe: Mounted uiScribe WebUI page as Main_LogStatus_Content.asp
Apr 22 09:22:29 GT-AX6000-9980 kernel: eth2 (Int switch port: 1) (Logical Port: 1) (phyId: 2) Link DOWN.
Apr 22 09:22:29 GT-AX6000-9980 kernel: br0: port 2(eth2) entered disabled state
Apr 22 09:22:35 GT-AX6000-9980 kernel: eth2 (Int switch port: 1) (Logical Port: 1) (phyId: 2) Link Up at 100 mbps full duplex
Apr 22 09:22:35 GT-AX6000-9980 kernel: br0: port 2(eth2) entered blocking state
Apr 22 09:22:35 GT-AX6000-9980 kernel: br0: port 2(eth2) entered listening state
Apr 22 09:22:37 GT-AX6000-9980 kernel: br0: port 2(eth2) entered learning state
Apr 22 09:22:39 GT-AX6000-9980 kernel: br0: port 2(eth2) entered forwarding state
Apr 22 09:22:39 GT-AX6000-9980 kernel: br0: topology change detected, propagating
# cat syslog.log-1
### Top of Log File ###
Mine wasnb't working, so I forced an update, but still showing 2.4_4
I'm getting the following errror for syslog-ng cofiguration
   syslog-ng.conf version check ...Error opening plugin module; module='http', error='libssl.so.1.1: wrong ELF class: ELFCLASS32'
 in sync. (3.38)
          scribe installed version: v2.4_4 (master)
             scribe GitHub version: v2.4_4 (master)
 in sync. (3.38)
So... I had uninstalled scribe a couple of months back when I had issues on my GT-AX6000. This morning, I completed a clean install of v2.4_4, edited the script to designate "gamma", and updated to v2.5_0 (gamma).
Thanks,
I found a post from @glehel that fixed it. I appologize that I am unable to post the link.
@JT Strickland
 in sync. (3.38)
You have to change the code to look for the gamma branch as described in this post: https://www.snbforums.com/threads/scribe-2-5-0-testers-needed.84478/ ... but yes, the 'libssl.so.1.1' error is a separate issue from scribe or syslog-ng as you discovered.
@visortgw
                            _
                         _ ( )
     u.    Update scribe
     uf.   Update filters
     e.    Exit scribe
     zs.   Remove scribe
# pwd
/tmp
# ls -al syslog*
# cat syslog.log
# cat syslog.log-1
Superb. Glad to hear you installed from scratch too, that part is working then. :)
Only one more thing I'd like to see 'ls -al /jffs/syslog*'. /jffs/syslog.log should be a link to /opt/var/log/messages and /jffs/syslog.log-1 should be a small file.
Appreciate the help!
@JT Strickland
@visortgw
# cd /jffs
# ls -al /jffs/syslog*
lrwxrwxrwx    1 TheS1R   root            21 Apr 22 09:22 /jffs/syslog.log -> /opt/var/log/messages
-rw-rw-rw-    1 TheS1R   root            24 Apr 22 13:00 /jffs/syslog.log-1
Yes, it is! Huge THANKS to you for taking the time to dust off the cobwebs from scribe!
You're welcome. And thanks for your patience.
As I've said before, my main purpose in writing scribe was actually to dive into shell scripting, and I've learned a ton along the way. I honestly had no altruistic intent of "helping people", lol. I specifically don't want donations for scribe because then I would feel a deeper sense of obligation than I already do*, and I want to be able to futz with this because I want to, not because I *have* to. Indeed, if this issue had come up in the middle of 2021, my answer may have had to be, "if you have one of those routers, sorry, you're out of luck or you have to fork it", because there was no way I had time then to devote to this.
For this latest issue with routers wanting to write to /jffs my desire to learn more awk drove me away from adamm's solution (even though it currently works perfectly) and actually get the log file location from the syslogd command string. In theory at least, if Asus changed their minds again and put syslog.log yet somewhere else, scribe should be able to handle that. I hope it never comes to testing that theory though. :)
So, while this is a more complex problem for scribe than other scripts, I did increase the complexity for myself a bit in the pursuit of learning.
* if you just HAVE to give money to someone for scribe, I would appreciate a donation to METAvivor.
Can we expect that Scribe 2.5.0 will soon become the main/official release rather than a gamma (test) release? No rush, just checking to see how long you expect it to take for it to be sufficiently tested/verified.
Hopefully tomorrow evening. JGrana was out of town this weekend, and said he'd test it Monday. Since I don't have a router that puts syslog.log in /jffs, I'm a bit reluctant to just say "looks good from my house" and hope for the best. If JGrana gives it a thumbs up, then the gamma version that is up now will become the release, except it'll clear the screen before the menu comes up.
