Scribe scribe - syslog-ng and logrotate installer
I force downloaded v0.10_2 and now this is shown:
 checking configuration files for necessary scribe hooks ...
          checking S01syslog-ng ... present.
         checking service-event ... present.
            checking post-mount ... present.
    checking logrotate cron job ... alive.
      checking syslog-ng daemon ... dead.
Edit: But update now works. :)
Edit: Still with the syslog-ng daemon ... dead issue though. :(
Can you add support for other routers which have both entware and asuswrt firmware installed, like Netgear R7000.
uname -o = GNU/Linux
or full
Linux router 2.6.36.4brcmarm #1 SMP PREEMPT Thu Apr 4 08:15:40 MSK 2019 armv7l GNU/Linux
edit:
as a workarround I have to change this value to
readonly merlin="GNU/Linux"
[/CODE]
You may still have references to 'kernel' in your existing rules?
Run
syslog-ng -Fevd
Run
syslog-ng -Fevd
I don't have any rules.
Edit: using the scMerlin script to restart all Entware scripts 't' didn't work either: failed.
So '/opt/etc/syslog-ng.d' is empty?
Did you run the diagnostic command?
Try "scribe config" and see if it throws an error at you.
Me too, I whitelisted both "codeload.github.com" and "raw.githubusercontent.com" and still blocked.
 scribe GitHub repository is unavailable!  -- Aborting.
         scribe installed version: v0.10_1
            scribe GitHub version:
[: bad number
 No new version available. (GitHub version[: bad number
 LESS THAN local version)
Running "syslog-ng -Fevd" worked fine, everything clean, I use this often!
@L&LD I'll upload my filter files when we get this solved, most of them are installed automagically when you install or update scribe, just say yes when it asks if "Do you want to update syslog-ng and logrotate example files? [y|n]"
That works here, here is the end of the long output.
syslog-ng syntax check ... okay!
         Checking S01syslog-ng ... present.
        Checking service-event ... present.
That directory is not empty. Must be the default install?
Which diagnostic command?
Does this command seem to show me the source script file? I don't see any obvious errors.
I uninstalled scribe and it asked to reboot the router, which I did. I just re-installed it again and am running the syslog-ng -Fevd command (seems to be taking a long time).
I CTRL-C the syslog-ng -Fevd command and ran scribe status instead. All are present and alive. :)
[: bad number
Did you remember to use "4. Process all lists" in Diversion after editing the whitelist?
[: bad number
Butterfly Bones, I seem to be on v0.10_2 stable with everything working now and I did say 'y' to that question. The logs in /opt/var/log/ are the same as I had before, not what you have. :)
Crap. It's a logic error because I changed the way it stored version numbers. I _THOUGHT_ I had tested it out and it was okay.
However it doesn't die as you found, so just answering yes to updating the scribe script.
I tried a force install and that worked, however I am getting this error that does not seem correct, what am I missing?
 running logrotate ...
 check the output below for errors (blank = no errors)
==> /opt/tmp/logrotate.daily <==
error: Ignoring chkwan because it is writable by group or others.
error: Ignoring dropbear because it is writable by group or others.
error: Ignoring ethernet because it is writable by group or others.
error: Ignoring openvpn because it is writable by group or others.
error: Ignoring pixelsrv because it is writable by group or others.
error: Ignoring skynet because it is writable by group or others.
error: Ignoring vpnfailover because it is writable by group or others.
error: Ignoring wlceventd because it is writable by group or others.
/tmp/mnt/SNB/entware/etc/logrotate.d# ls -al
drwxr-xr-x    2 [redacted] root          4096 May  5 13:16 .
drwxr-xr-x   10 [redacted] root          4096 May  5 13:16 ..
-rw-------    1 [redacted] root           308 May  5 13:16 A00global
-rw-------    1 [redacted] root           123 Apr 12 12:21 chkwan
-rw-------    1 [redacted] root           124 May  5 13:16 crash
-rw-------    1 [redacted] root           125 Apr 26 06:53 divstats
-rw-------    1 [redacted] root           125 Apr 12 12:13 ethernet
-rw-------    1 [redacted] root           117 May  5 13:16 logrotate
-rw-------    1 [redacted] root           136 May  5 13:16 messages
-rw-------    1 [redacted] root           124 Apr 12 12:09 openvpn
-rw-------    1 [redacted] root           142 Apr 20 19:29 pixelsrv
-rw-------    1 [redacted] root           100 May  5 13:16 syslogng
-rw-------    1 [redacted] root           127 May  1 09:56 vpnfailover
-rw-------    1 [redacted] root           125 May  5 13:16 wlceventd
I tried all ways (updated example files, updated script, and the script and example files), but no change in /opt/var/log. :(
I'm at a loss here. They're clearly not writable by anyone but the user. That's all logrotate output. Try rebooting?
Ok, I found that that file (not directory) contains this error message, but the timestamp is Apr 18, 2019. Should I delete it and let it regenerate or will that cause more problems?
edit - no longer using the "dropbear" file, I removed from syslog-ng.d and logrotate.d
Yes, delete it. It will be automatically re-created.
