Scribe scribe - syslog-ng and logrotate installer
I noticed that the /tmp/syslog.log symlink file was written back in a few minutes back to a normal file.
I redirected the skynet log file and now looks good
Sorry I didn't see this earlier, I've been super slammed with work and personal commitments, and even now I'm not actually at home. I'm sorry the scribe installation didn't work for you, I can try to help you out if you want to try again, although I must be honest, right now my plate is very full.
scribe v1.1_0 is up.
Note that when v2.0_0 is eventually released (with a menu), you will not be able to go directly from v1.0_0 to v2.0_0, you will need to be on v1.1_0 or later to upgrade to v2.0_0. Okay, technically you could, but it would involve editing a line in scribe. :)
There was a minor logic error in v1.0_0, when you upgrade to v1.1_0, after the upgrade it will print that v1.0_0 is still installed. Not to fear, it isn't, if you run "scribe status" you will see that v1.1_0 is installed. EDIT: This only occurs if you don't update the example files. If you do update them, it will show that v1.1_0 is installed.
Other than that, a bit of tweaking to the colors and wording, and the logic to support upgrading to v2.0_0 whenever I get around to adding the menu.
I did not get the "v1.0_0 is still installed" doing the update just now. Not that I'm complaining. :)
                         _ ( )
       ___    ___  _ __ (_)| |_      __
     /',__) /'___)( '__)| || '_`\  /'__`\
     \__, \( (___ | |   | || |_) )(  ___/
     (____/`\____)(_)   (_)(_,__/'`\____)
     syslog-ng and logrotate installation
     v1.0_0 (master)  Coded by cynicastic
          scribe installed version: v1.0_0 (master)
             scribe GitHub version: v1.1_0 (master)
 New version available!
 Do you wish to upgrade [y|n] y
 Do you want to update syslog-ng and logrotate example files? [y|n] y
 fetching scribe from GitHub master branch ...
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100   122    0   122    0     0    266      0 --:--:-- --:--:-- --:--:--   356
100 21727    0 21727    0     0  25088      0 --:--:-- --:--:-- --:--:-- 25088
.... %<  snip ------------
setting up scribe ... done.
 copying rc.func.syslog-ng to /opt/etc/init.d ... done.
 scribe updated!
 syslog-ng and logrotate example files updated!
 checking configuration for necessary scribe hooks ...
          checking S01syslog-ng ... present.
         checking service-event ... present.
            checking post-mount ... present.
    checking logrotate cron job ... present.
 checking syslog-ng daemon ...
         syslog-ng syntax check ... okay!
      checking syslog-ng daemon ... alive.
          scribe installed version: v1.1_0 (master)
                    scribe is up to date!
                         _ ( )
 scribe updated!
Oh, ooops, you'll only get the installed version still being v1.0_0 if you don't update the example files. :) I'll update the post.
Ok, I can see that. I used to check against example files on GitHub, but now know I leave them alone, so unless you have changed something in them to improve handling, I never look at them, just trust to update.
I can see where some who have not been knee deep in the syslog-ng mud before might be hesitant to update them. ;)
Smooth update from v0.1 to v1.1_0 here. Updated both. :)
I migrated to 384.11_2 last night. I just tried to install scribe with the following curl error:
                            _
                         _ ( )
     v1.1_0 (master)  Coded by cynicastic
100   122    0   122    0     0     99      0 --:--:--  0:00:01 --:--:--   233
  0     0    0     0    0     0      0      0 --:--:--  0:00:01 --:--:--     0
curl: (60) SSL certificate problem: self signed certificate in certificate chain
More details here: https://curl.haxx.se/docs/sslcerts.html
curl failed to verify the legitimacy of the server and therefore could not
establish a secure connection to it. To learn more about this situation and
how to fix it, please visit the web page mentioned above.
 scribe GitHub repository is unavailable!  -- Aborting.
                            _
                         _ ( )
Is this relevant? post #510
                            _
                         _ ( )
I added a '-k' flag to the curl line (in the 'scribe' script) to ignore the verification part, BUT it had lots of problems running the script !!! (lots of dirs/files not found !!!???)
I ended up using git clone to copy the files/.zip down and manually set up the directories etc in /jffs/scripts/... and /opt/tmp/[scribe]|[scribe-master] .....
I ran the 'scribe' script multiple times and fixed the missing dirs/files until it was happy !!! :)
I was eventually able to run the 'scribe install' and 'scribe restart' to confirm all was working (after copying the 'right' files into /opt/tmp/[scribe]|[scribe-master]/[logrotate.share]|[syslog-ng.share])
Big Hint:
Make sure all the dirs/files are chmod'ed to '0755' otherwise the script is designed to ignore them.
I think this may possibly have been my problem !!!
I already have an existing syslog-ng installation. Appears this may have caused an issue with the installer script:
Downloading http://bin.entware.net/armv7sf-k2.6/Packages.gz
Updated list of available packages in /opt/var/opkg-lists/entware
 syslog-ng already installed!
 Forcing installation may overwrite modified configuration files!
 Do you want to force re-installation of syslog-ng [y|n]? y
 Checking syslog-ng...              dead.
Removing package syslog-ng from root...
Not deleting modified conffile /opt/etc/syslog-ng.conf.
Installing syslog-ng (3.19.1-2) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/syslog-ng_3.19.1-2_armv7-2.6.ipk
Configuring syslog-ng.
Collected errors:
 * resolve_conffiles: Existing conffile /opt/etc/syslog-ng.conf is different from the conffile in the new package. The new conffile will be placed at /opt/etc/syslog-ng.conf-opkg.
 syslog-ng version 3.19 or higher required!
Please update your Entware packages and run scribe install again.
I then confirmed syslog-ng was no longer installed and reinstalled:
Xentrk@RT-AC88U-8248:/jffs/scripts# opkg list-installed | grep syslog
Xentrk@RT-AC88U-8248:/jffs/scripts# opkg install syslog-ng
Collected errors:
Running a check shows syslog-ng is dead. :(
          checking S01syslog-ng ... updated.
         checking service-event ...sed: /jffs/scripts/service-event: No such file or directory
grep: /jffs/scripts/service-event: No such file or directory
 updated.
            checking post-mount ... updated.
    checking logrotate cron job ... updated.
         syslog-ng syntax check ...[2019-05-19T12:11:39.217635] WARNING: Configuration file format is too old, syslog-ng is running in compatibility mode. Please update it to use the syslog-ng 3.19 format at your time of convenience. To upgrade the configuration, please review the warnings about incompatible changes printed by syslog-ng, and once completed change the @version header at the top of the configuration file.;
 okay!
      checking syslog-ng daemon ... dead.
Appears the installer is not handling the condition where an existing syslog-ng.conf file exists?
I renamed /opt/etc/syslog-ng.conf and got a little further in the install process:
Included from /opt/etc/syslog-ng.conf:
11      #   source net function to get udp log messages from local network commented out
12      #   destination log_server function added (commented out) to illustrate sending udp log messages to server on local network
13
14      @version: 3.19
15      @include "/opt/etc/syslog-ng.d/" # Put any customization files in this directory
16---->
16----> ^
17      options {
18          chain_hostnames(no); # Enable or disable the chained hostname format.
19          create_dirs(yes);
20          keep_hostname(yes); # Enable or disable hostname rewriting.
21          log_fifo_size(256); # The number of messages that the output queue can store.
syslog-ng documentation: https://www.balabit.com/support/documentation?product=syslog-ng-ose
contact: https://lists.balabit.hu/mailman/listinfo/syslog-ng
 FAILED!
Xentrk@RT-AC88U-8248:/jffs/scripts# /opt/etc/init.d/S01syslog-ng start
 Starting syslog-ng...              done.
Xentrk@RT-AC88U-8248:/jffs/scripts# /opt/etc/init.d/S01syslog-ng check
