Butterfly Bones
Likely I'd guess. I just checked everything I can think of and all running normally and smoothy. (shrug)I'm starting to think it's because I'm overwriting the script while it's running and it's doing funky things?
Yeah, looking at Jack's scripts, if he does anything after an update, he executes the updated script. I can fix it with some logic tweak.Likely I'd guess. I just checked everything I can think of and all running normally and smoothy. (shrug)
Wait until I post 8_1.I'm teetering, I'm on the edge now.
Okay, going to my router now and going to try this after some lunch!![]()
Yes, I think so, no errors this time.v0.8_1 pushed
* (Hopefully) fixes an issue where continuing the script after upgrading causes spurious error messages
syslog-ng and logrotate installation
v0.8_0 (master) Coded by cynicastic
scribe installed version: v0.8_0
scribe GitHub version: v0.8_1
New version available!
Do you wish to upgrade [y|n] y
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 122 0 122 0 0 293 0 --:--:-- --:--:-- --:--:-- 403
100 15762 0 15762 0 0 17151 0 --:--:-- --:--:-- --:--:-- 17151
Archive: /opt/tmp/scribe.zip
creating: scribe-master/
inflating: scribe-master/.gitattributes
inflating: scribe-master/.gitignore
inflating: scribe-master/README.md
creating: scribe-master/init.d/
inflating: scribe-master/init.d/rc.func.syslog-ng
creating: scribe-master/logrotate.d/
inflating: scribe-master/logrotate.d/A00global
inflating: scribe-master/logrotate.d/crash
inflating: scribe-master/logrotate.d/messages
inflating: scribe-master/logrotate.d/syslogng
creating: scribe-master/logrotate.share/
inflating: scribe-master/logrotate.share/openvpn
inflating: scribe-master/logrotate.share/pixelsrv
inflating: scribe-master/scribe
creating: scribe-master/syslog-ng.d/
inflating: scribe-master/syslog-ng.d/crashes
inflating: scribe-master/syslog-ng.d/syslogng
inflating: scribe-master/syslog-ng.d/wlceventd
creating: scribe-master/syslog-ng.share/
inflating: scribe-master/syslog-ng.share/expandlog
inflating: scribe-master/syslog-ng.share/openvpn
inflating: scribe-master/syslog-ng.share/pixelserv
inflating: scribe-master/syslog-ng.share/skynet
inflating: scribe-master/syslog-ng.share/syslog-ng.conf-no_scl
Downloading http://bin.entware.net/aarch64-k3.10/Packages.gz
Updated list of available packages in /opt/var/opkg-lists/entware
setting up scribe ... done.
Do you want to update syslog-ng and logrotate example and installed (/opt/etc/*.d/) files? [y|n] y
username@RT-AC86U-4608:/tmp/home/root#
Oh for crying in the beer! Fix one problem, create another.v0.8_1 pushed
I used FileZilla and backed up the full USB stick first, then updated. Comparing directories, sizes and timestamps, none of my files in use changed. It is running smoooooove!Oh for crying in the beer! Fix one problem, create another.
V0.8_2 is now up. WARNING: due to a logic error in 0.8_1, if you update the script from 0.8_1, it will also update the example and installed files. Sorry. Message to follow on how to avoid this.
I though I could be extra clever and come up with a fancy sed string that would fix it. Also, my regex-fu is weak. To keep from accidentally overwriting your files, in the v8.0_1 script, you need to look for the line that is:Oh for crying in the beer! Fix one problem, create another.
[ "$inst" = "yes" ] && menu_filters
[ "$upd" = "yes" ] && menu_filters
Whew!I used FileZilla and backed up the full USB stick first, then updated. Comparing directories, sizes and timestamps, none of my files in use changed. It is running smoooooove!![]()
I though I could be extra clever and come up with a fancy sed string that would fix it. Also, my regex-fu is weak. You need to look for the line that is:
Code:[ "$inst" = "yes" ] && menu_filters [CODE] which should be line 367, and replace it with: [CODE] [ "$upd" = "yes" ] && menu_filters [CODE] Again, sorry.
if [ "$upd" = "yes" ] <<== this is line 367
then
getzip
setup_scribe
printf "\n$white $scribe_name updated!$std\n"
[ $upd = "yes" ] && scribe filters gotzip
exit 0
else
printf "\n$white $scribe_name$red not$white updated!$std\n"
fi
then
menu_filters
printf "\n$white %s and %s example and installed files updated!$std\n" "$sng" "$lr"
else
printf "\n$white %s and %s example and installed files$red not$white updated!$std\n" "$sng" "$lr"
fi
syslog-ng -d
/tmp/home/root# syslog-ng -d
[2019-04-07T21:51:36.853044] nanosleep() is not accurate enough to introduce minor stalls on the reader side, multi-threaded performance may be affected;
[2019-04-07T21:51:36.853949] Processing @include statement; filename='/opt/etc/syslog-ng.d/', include-path='/opt/etc:/opt/share/syslog-ng/include'
[2019-04-07T21:51:36.854181] Adding include file; filename='wlceventd', depth='1'
[2019-04-07T21:51:36.854317] Adding include file; filename='crashes', depth='1'
[2019-04-07T21:51:36.854408] Adding include file; filename='0loggly', depth='1'
[2019-04-07T21:51:36.854565] Adding include file; filename='openvpn', depth='1'
[2019-04-07T21:51:36.854656] Adding include file; filename='pixelserv', depth='1'
[2019-04-07T21:51:36.854812] Adding include file; filename='ethernet', depth='1'
[2019-04-07T21:51:36.854902] Adding include file; filename='vpnfailover', depth='1'
[2019-04-07T21:51:36.855058] Adding include file; filename='syslogng', depth='1'
[2019-04-07T21:51:36.855135] Skipping include file, it cannot begin with .; filename='.keep'
[2019-04-07T21:51:36.855290] Adding include file; filename='chkwan', depth='1'
[2019-04-07T21:51:36.855380] Adding include file; filename='skynet', depth='1'
[2019-04-07T21:51:36.855600] Starting to read include file; filename='/opt/etc/syslog-ng.d/0loggly', depth='1'
[2019-04-07T21:51:36.856613] Reading path for candidate modules; path='/opt/lib/syslog-ng'
[2019-04-07T21:51:36.856700] Reading shared object for a candidate module; path='/opt/lib/syslog-ng', fname='libbasicfuncs.so', module='basicfuncs'
No, you only needed to change the line in 0.8_1.Ok, I get nervous in scripts since i do not read them well. I found the "$inst" code, this is what I see and replaced, before I copy it back, is this correct?
Code:if [ "$upd" = "yes" ] <<== this is line 367 then getzip setup_scribe printf "\n$white $scribe_name updated!$std\n" [ $upd = "yes" ] && scribe filters gotzip exit 0 else printf "\n$white $scribe_name$red not$white updated!$std\n" fi if [ "$upd" = "yes" ] then menu_filters printf "\n$white %s and %s example and installed files updated!$std\n" "$sng" "$lr" else printf "\n$white %s and %s example and installed files$red not$white updated!$std\n" "$sng" "$lr" fi
Okay, it's past bedtime here, gotta go to work tomorrow. 0.8_2 now doesn't update the example & *.d files if you try to do it as part of upgrading scribe. It won't run the new script from inside the old, although I've tried a couple methods. I'll have to bang on it some more later. For now, it's plenty usable, calling 'scribe update-filters' will update the example & *.d files once you've installed the new script.No, you only needed to change the line in 0.8_1.
0.8_2 is already fixed.
I clarified the instructions above.
Yes, time for bed for me too. Thanks for the time to update so much of the script, it really is good after my own foul ups early on. As I have stated before, I have tried off and on for year to get syslog-ng running. That time length shows I really am a script dunce.Okay, it's past bedtime here, gotta go to work tomorrow. 0.8_2 now doesn't update the example & *.d files if you try to do it as part of upgrading scribe. It won't run the new script from inside the old, although I've tried a couple methods. I'll have to bang on it some more later. For now, it's plenty usable, calling 'scribe update-filters' will update the example & *.d files once you've installed the new script.
Actually, nevermind, 8.0_2 works just fine. PEBKAC (Problem Exists Between Keyboard And Chair).Yes, time for bed for me too. Thanks for the time to update so much of the script, it really is good after my own foul ups early on. As I have stated before, I have tried off and on for year to get syslog-ng running. That time length shows I really am a script dunce.![]()
This isn't a problem. The .keep file is a zero length file to populate the syslog-ng.d directory. Generally empty directories aren't copied, I understand, so without it the installer wouldn't create the directory. You can delete it or ignore the error.This one caught my eye with the earlier discussion about the .keep file.
Code:Skipping include file, it cannot begin with .; filename='.keep'
We use essential cookies to make this site work, and optional cookies to enhance your experience.
