Script to turn off wireless
Uranya
Hi friends,
I have just finished to configure this awesome firmware for my brand new ASUS RT-AC68U
I need you to help me to create a script that turns off/on wireless
I have tried to use "wl radio off" and "wl radio on" but this doesn't work.
Please help, thank you!
Hi friends,
What is the final goal (overall goal/plan)?
Dear friend, the reason is that I need to have wifi OFF from 3:00 up to 8:00, which the configuration page does not allow.
I'm using scripting through "cru" crontab agent, but I need the right command.
I have tried with this
into services-start added this line:
cru a ra0 "0 3 * * * /tmp/mnt/scripts/custom/radio_off.sh"
and radio_off.sh as below:
#!/bin/sh
log='/tmp/mnt/scripts/custom/custom.log'
NOW=$(date +"%Y.%m.%d %H:%M")
echo >> ${log} "${NOW} >>> Radio: OFF"
wl radio off
At 3:00 o'clock I can find the line into log, but wifi is still on
Do you have a way to solve this?
Thank you again!
#!/bin/sh
wl radio off
Thank you again!
Hello
Here it is how it works for me on RT-N66U
You need to specify which one adapter you want to turn off
To turn off 2.4
wl -i eth1 radio off
To turn off 5.0
wl -i eth2 radio off
The same to turn them on
Hope it helps
BR
Ocram
