searching RMerlin 380.63 alpha 2 ( unofficial / nightly / latest commit ) build for RT-AC88U
Just as an FYI for your debugging.....both iptables commands work OK on my fork with ipset 6.
EDIT: One thing you may want to try is manually loading some of the modules if you aren't already doing so....
 for module in ip_set ip_set_hash_net ip_set_hash_ip xt_set
do
     insmod $module
done
I need to see if maybe xt_set might also be requiring an alias, like the various hash modules needed for the automagic module loader to work properly.
I compiled 380.63_alpha2 without any problems. Only problem is making ipset blacklist win10tracking work.
Don't forget to modprobe xt_set .
I got Win10tracking working. It seems you don't need to load modules... they're already loaded. Only thing is I had to do # ipset -N Win10tracking iphash manually then run the firewall-start. Works now. Not bad work doing trial and error work...
snippet---
# ipset list
Type: hash:ip
Revision: 0
Header: family inet hashsize 1024 maxelem 65536
Size in memory: 8280
References: 1
Members:
64.4.54.253
64.4.54.254
snippet---
snippet---
# ipset list
Type: hash:ip
Revision: 0
References: 1
Members:
64.4.54.253
64.4.54.254
snippet---
Did u compiled for RT-AC88U ?
I think some lines in Win10tracking firewall-start script needs to be changed:
# Create ip set
if [ "$(ipset swap Win10tracking Win10tracking 2>&1 | grep 'Unknown set')" != "" ]; #(change --swap to swap)
then
# ipset -N Win10tracking iphash #(comment out or remove)
ipset create -exist Win10tracking hash:ip #(new command)
fi
Can anyone test this out?
# Create ip set
then
fi
I have both forms in my scripts without problems. ipset 6 is downward compatible with the old command syntax.
