Security Log to see who is…
Nas.CloudBusinessPortal
Id like to track who in connecting to a device on my my network.
The port numbers are 12090 and 12080, just to keep track.
Is there an ezasy way to generate a automatic log?
Are we talking about local<->remote access of those ports? Because you can NOT readily track access between local devices using the router.
If it's NOT local<->local access, I suppose you could just look for those ports in the PREROUTING chain of the nat table and dump them to the syslog.
iptables -t nat -I PREROUTING -p tcp -m multiport --dports 12090,12080 -j LOG
Then browse the entries found in the syslog.
grep -E 'kernel:.* DPT=(12090|12080) ' /tmp/syslog.log | less
For long term usage, the nat rule would have to be installed as a nat-start script. But for short term usage, you can just use ssh.
P.S. You might have to increase the syslog level to debug for the LOG entries to work.
In case it helps:
Port 12080 is used by WebShield, Dwyco Video Conferencing, NetworkServer, Delta Three PC to Phone.
Trojan Troj/Agent-E, Win32.Disprox.A also use this port.
