Installed this Netflix-VPN-Bypass today (nice job Xentrk). Works well except that once I reboot my Asus RT-AC86U router Netflix gets blocked again. I have to issue command (sh /jffs/scripts/IPSET_Netflix.sh) on SSH terminal to make this Netflix-VPN-Bypass work again. How to fix this problem?
Btw, Diversion, DNSCrypt & Skynet are installed in my router. WAN DNS is set manually using 1.1.1.1 & 1.0.0.1. OpenVPN client with IPVanish & DNS config is set to Disabled & redirect internet traffic to Policy Rules (Strict).
#!/bin/sh
That fix it man. Thanks a lot.![]()
nano /jffs/scripts/nat-start - opens the file in text editor
Enter this:
Code:#!/bin/sh sh /jffs/scripts/IPSET_Netflix.sh
ctrl + x -exits text editor
yes -saves the file
chmod 755 /jffs/scripts/nat-start -makes the file executable
reboot
wait 5 mins for script to load and retry
Code:/tmp/home/root# tail -f dnsmasq.log tail: can't open 'dnsmasq.log': No such file or directory tail: no files
Tried navigating to /var/opt/log - same message.
Any clues?
log-async
log-queries
log-facility=/opt/var/log/dnsmasq.log
if [ ! -f /jffs/scripts/post-mount.div ];then # Let Diversion handle Entware
echo -e
logger -st "($(basename $0))" $$ "Mounting Entware '"$1"/entware' on '/tmp/opt'....."
ln -nsf $1/entware /tmp/opt
fi
Yes.Do you enter chmod 755 /jffs/scripts/nat-start after you exit the text editor?
That was missing, so I've now added it to the last 3 lines of the file. - rebooted, and still fails.Do you actually have logging directives in dnsmasq?
/etc/dnsmasq.conf
Code:log-async log-queries log-facility=/opt/var/log/dnsmasq.log
I'm not sure with this... i've ran /jffs/scripts/post-mount and nothing happens.If you do have a reference to Entware's file structure '/opt/var/log/' is it actually mounted?
e.g. /jffs/scripts/post-mount
Code:if [ ! -f /jffs/scripts/post-mount.div ];then # Let Diversion handle Entware echo -e logger -st "($(basename $0))" $$ "Mounting Entware '"$1"/entware' on '/tmp/opt'....." ln -nsf $1/entware /tmp/opt fi
Did you correctly add the three lines to '/jffs/configs/dnsmasq.conf.add' then restart dnsmasq?That was missing, so I've now added it to the last 3 lines of the file. - rebooted, and still fails.
service restart_dnsmasq
I can no longer cd ...
tmp/home/root# cd /var/opt/log
-sh: cd: can't cd to /var/opt/log
otherwise they are lost after a reboot.Code:service restart_dnsmasq
So you have installed Entware ...Yes?
If you haven't installed Entware, then simply change 'log-facility=/a_directory_that_exists on_your_mounted_USB/dnsmasq.log' then tail/browse that file.
nano /jffs/configs/dnsmasq.conf.add
*insert*
log-async
log-queries
ctrl + x
yes
Enter
Dec 10 20:08:39 dnsmasq[5168]: query[A] logsink.devices.nest.com from 192.168.1.118
Dec 10 20:08:39 dnsmasq[5168]: forwarded logsink.devices.nest.com to 1.1.1.1
Dec 10 20:08:39 dnsmasq[5168]: validation result is INSECURE
Dec 10 20:08:39 dnsmasq[5168]: reply logsink.devices.nest.com is 35.190.54.210
Dec 10 20:08:51 dnsmasq[5168]: query[A] dns.msftncsi.com from 127.0.0.1
Dec 10 20:08:51 dnsmasq[5168]: cached dns.msftncsi.com is 131.107.255.255
Dec 10 20:09:06 dnsmasq[5168]: query[A] dns.msftncsi.com from 127.0.0.1
Dec 10 20:09:06 dnsmasq[5168]: forwarded dns.msftncsi.com to 1.1.1.1
Dec 10 20:09:06 dnsmasq[5168]: validation result is INSECURE
Dec 10 20:09:06 dnsmasq[5168]: reply dns.msftncsi.com is 131.107.255.255
Dec 10 20:09:21 dnsmasq[5168]: query[A] dns.msftncsi.com from 127.0.0.1
Dec 10 20:09:21 dnsmasq[5168]: cached dns.msftncsi.com is 131.107.255.255
Dec 10 20:09:36 dnsmasq[5168]: query[A] dns.msftncsi.com from 127.0.0.1
Dec 10 20:09:36 dnsmasq[5168]: forwarded dns.msftncsi.com to 1.1.1.1
Dec 10 20:09:36 dnsmasq[5168]: validation result is INSECURE
Dec 10 20:09:36 dnsmasq[5168]: reply dns.msftncsi.com is 131.107.255.255
So I've tried logging Skygo and all i'm seeing is Nest and Microsoft DNS queries... any ideas?
Code:Dec 10 20:08:39 dnsmasq[5168]: query[A] logsink.devices.nest.com from 192.168.1.118 Dec 10 20:08:39 dnsmasq[5168]: forwarded logsink.devices.nest.com to 1.1.1.1 Dec 10 20:08:39 dnsmasq[5168]: validation result is INSECURE Dec 10 20:08:39 dnsmasq[5168]: reply logsink.devices.nest.com is 35.190.54.210 Dec 10 20:08:51 dnsmasq[5168]: query[A] dns.msftncsi.com from 127.0.0.1 Dec 10 20:08:51 dnsmasq[5168]: cached dns.msftncsi.com is 131.107.255.255 Dec 10 20:09:06 dnsmasq[5168]: query[A] dns.msftncsi.com from 127.0.0.1 Dec 10 20:09:06 dnsmasq[5168]: forwarded dns.msftncsi.com to 1.1.1.1 Dec 10 20:09:06 dnsmasq[5168]: validation result is INSECURE Dec 10 20:09:06 dnsmasq[5168]: reply dns.msftncsi.com is 131.107.255.255 Dec 10 20:09:21 dnsmasq[5168]: query[A] dns.msftncsi.com from 127.0.0.1 Dec 10 20:09:21 dnsmasq[5168]: cached dns.msftncsi.com is 131.107.255.255 Dec 10 20:09:36 dnsmasq[5168]: query[A] dns.msftncsi.com from 127.0.0.1 Dec 10 20:09:36 dnsmasq[5168]: forwarded dns.msftncsi.com to 1.1.1.1 Dec 10 20:09:36 dnsmasq[5168]: validation result is INSECURE Dec 10 20:09:36 dnsmasq[5168]: reply dns.msftncsi.com is 131.107.255.255
grep -F "21:45" /opt/var/log/dnsmasq.log | grep sky >sky.log
Dec 10 21:45:15 dnsmasq[3225]: query[A] init.sky.com from 10.88.8.111
Dec 10 21:45:15 dnsmasq[3225]: forwarded init.sky.com to 79.79.79.78
Dec 10 21:45:15 dnsmasq[3225]: reply init.sky.com is <CNAME>
Dec 10 21:45:15 dnsmasq[3225]: reply init.sky.com.edgekey.net is <CNAME>
Dec 10 21:45:17 dnsmasq[3225]: query[A] desktop.client.ott.sky.com from 10.88.8.111
Dec 10 21:45:17 dnsmasq[3225]: forwarded desktop.client.ott.sky.com to 79.79.79.78
Dec 10 21:45:17 dnsmasq[3225]: reply desktop.client.ott.sky.com is <CNAME>
Dec 10 21:45:17 dnsmasq[3225]: reply desktop.client.ott.sky.com.edgekey.net is <CNAME>
Dec 10 21:45:22 dnsmasq[3225]: query[A] config.ott.sky.com from 10.88.8.111
Dec 10 21:45:22 dnsmasq[3225]: forwarded config.ott.sky.com to 79.79.79.78
Dec 10 21:45:22 dnsmasq[3225]: reply config.ott.sky.com is <CNAME>
Dec 10 21:45:22 dnsmasq[3225]: reply config.ott.sky.com.edgekey.net is <CNAME>
Dec 10 21:45:24 dnsmasq[3225]: query[A] awk.epgsky.com from 10.88.8.111
Dec 10 21:45:24 dnsmasq[3225]: forwarded awk.epgsky.com to 79.79.79.78
Dec 10 21:45:24 dnsmasq[3225]: reply awk.epgsky.com is <CNAME>
Dec 10 21:45:24 dnsmasq[3225]: reply awk.epgsky.com.edgekey.net is <CNAME>
Dec 10 21:45:24 dnsmasq[3225]: query[A] init.sky.com from 10.88.8.111
Dec 10 21:45:24 dnsmasq[3225]: cached init.sky.com is <CNAME>
Dec 10 21:45:24 dnsmasq[3225]: cached init.sky.com.edgekey.net is <CNAME>
Dec 10 21:45:24 dnsmasq[3225]: query[A] p.sky.com from 10.88.8.111
Dec 10 21:45:24 dnsmasq[3225]: forwarded p.sky.com to 79.79.79.78
Dec 10 21:45:24 dnsmasq[3225]: reply p.sky.com is <CNAME>
Dec 10 21:45:24 dnsmasq[3225]: reply p.sky.com.edgekey.net is <CNAME>
Dec 10 21:45:26 dnsmasq[3225]: query[A] config.skyq-b.interactive.sky.com from 10.88.8.111
Dec 10 21:45:26 dnsmasq[3225]: forwarded config.skyq-b.interactive.sky.com to 79.79.79.78
Dec 10 21:45:26 dnsmasq[3225]: reply config.skyq-b.interactive.sky.com is <CNAME>
Dec 10 21:45:26 dnsmasq[3225]: reply config.skyq-b.interactive.sky.com.edgekey.net is <CNAME>
Dec 10 21:45:27 dnsmasq[3225]: query[A] config.ott.sky.com from 10.88.8.111
Dec 10 21:45:27 dnsmasq[3225]: cached config.ott.sky.com is <CNAME>
Dec 10 21:45:27 dnsmasq[3225]: cached config.ott.sky.com.edgekey.net is <CNAME>
Dec 10 21:45:27 dnsmasq[3225]: forwarded config.ott.sky.com to 79.79.79.78
Dec 10 21:45:27 dnsmasq[3225]: forwarded config.ott.sky.com to 79.79.79.77
Dec 10 21:45:27 dnsmasq[3225]: forwarded config.ott.sky.com to 127.0.0.1
Dec 10 21:45:27 dnsmasq[3225]: reply config.ott.sky.com is <CNAME>
Dec 10 21:45:27 dnsmasq[3225]: reply config.ott.sky.com.edgekey.net is <CNAME>
Dec 10 21:45:27 dnsmasq[3225]: query[A] entity.search.sky.com from 10.88.8.111
Dec 10 21:45:27 dnsmasq[3225]: forwarded entity.search.sky.com to 79.79.79.78
Dec 10 21:45:27 dnsmasq[3225]: reply entity.search.sky.com is <CNAME>
Dec 10 21:45:27 dnsmasq[3225]: reply freeflow2.entity.search.sky.com.edgesuite.net is <CNAME>
Dec 10 21:45:28 dnsmasq[3225]: query[A] config.skyq-b.interactive.sky.com from 10.88.8.111
Dec 10 21:45:28 dnsmasq[3225]: cached config.skyq-b.interactive.sky.com is <CNAME>
Dec 10 21:45:28 dnsmasq[3225]: cached config.skyq-b.interactive.sky.com.edgekey.net is <CNAME>
Dec 10 21:45:28 dnsmasq[3225]: forwarded config.skyq-b.interactive.sky.com to 79.79.79.78
Dec 10 21:45:28 dnsmasq[3225]: reply config.skyq-b.interactive.sky.com is <CNAME>
Dec 10 21:45:28 dnsmasq[3225]: reply config.skyq-b.interactive.sky.com.edgekey.net is <CNAME>
Dec 10 21:45:28 dnsmasq[3225]: query[A] images.metadata.sky.com from 10.88.8.111
Dec 10 21:45:28 dnsmasq[3225]: forwarded images.metadata.sky.com to 79.79.79.78
Dec 10 21:45:28 dnsmasq[3225]: reply images.metadata.sky.com is <CNAME>
Dec 10 21:45:28 dnsmasq[3225]: reply prdpdimages.opg.sky.com is <CNAME>
Dec 10 21:45:28 dnsmasq[3225]: reply images.metadata.sky.com.edgekey.net is <CNAME>
Dec 10 21:45:28 dnsmasq[3225]: query[A] analytics.faw.sky.com from 10.88.8.111
Dec 10 21:45:28 dnsmasq[3225]: /opt/share/diversion/list/blockinglist analytics.faw.sky.com is 10.88.8.3
Dec 10 21:45:29 dnsmasq[3225]: query[A] static.skyq-b.interactive.sky.com from 10.88.8.111
Dec 10 21:45:29 dnsmasq[3225]: forwarded static.skyq-b.interactive.sky.com to 79.79.79.78
Dec 10 21:45:29 dnsmasq[3225]: reply static.skyq-b.interactive.sky.com is <CNAME>
Dec 10 21:45:29 dnsmasq[3225]: reply static.skyq-b.interactive.sky.com.edgekey.net is <CNAME>
Dec 10 21:45:29 dnsmasq[3225]: query[A] metrics.sky.com from 10.88.8.111
Dec 10 21:45:29 dnsmasq[3225]: /opt/share/diversion/list/blockinglist metrics.sky.com is 10.88.8.3
Dec 10 21:45:30 dnsmasq[3225]: query[A] uk.imageservice.sky.com from 10.88.8.111
Dec 10 21:45:30 dnsmasq[3225]: forwarded uk.imageservice.sky.com to 79.79.79.78
Dec 10 21:45:30 dnsmasq[3225]: reply uk.imageservice.sky.com is <CNAME>
Dec 10 21:45:30 dnsmasq[3225]: reply uk.imageservice.sky.com.edgekey.net is <CNAME>
Dec 10 21:45:33 dnsmasq[3225]: query[A] qgo-desktop-sgw.skyanywhere.com from 10.88.8.111
Dec 10 21:45:33 dnsmasq[3225]: forwarded qgo-desktop-sgw.skyanywhere.com to 79.79.79.78
Dec 10 21:45:33 dnsmasq[3225]: reply qgo-desktop-sgw.skyanywhere.com is <CNAME>
Dec 10 21:45:33 dnsmasq[3225]: reply ott-sgw.skyanywhere.com is 90.211.176.31
Works for me..
e.g. Fired up the SkyGo app on my laptop 10.88.8.111
Code:grep -F "21:45" /opt/var/log/dnsmasq.log | grep sky >sky.log
Code:Dec 10 21:45:15 dnsmasq[3225]: query[A] init.sky.com from 10.88.8.111 Dec 10 21:45:15 dnsmasq[3225]: forwarded init.sky.com to 79.79.79.78 Dec 10 21:45:15 dnsmasq[3225]: reply init.sky.com is <CNAME> Dec 10 21:45:15 dnsmasq[3225]: reply init.sky.com.edgekey.net is <CNAME> Dec 10 21:45:17 dnsmasq[3225]: query[A] desktop.client.ott.sky.com from 10.88.8.111 Dec 10 21:45:17 dnsmasq[3225]: forwarded desktop.client.ott.sky.com to 79.79.79.78 Dec 10 21:45:17 dnsmasq[3225]: reply desktop.client.ott.sky.com is <CNAME> Dec 10 21:45:17 dnsmasq[3225]: reply desktop.client.ott.sky.com.edgekey.net is <CNAME> Dec 10 21:45:22 dnsmasq[3225]: query[A] config.ott.sky.com from 10.88.8.111 Dec 10 21:45:22 dnsmasq[3225]: forwarded config.ott.sky.com to 79.79.79.78 Dec 10 21:45:22 dnsmasq[3225]: reply config.ott.sky.com is <CNAME> Dec 10 21:45:22 dnsmasq[3225]: reply config.ott.sky.com.edgekey.net is <CNAME> Dec 10 21:45:24 dnsmasq[3225]: query[A] awk.epgsky.com from 10.88.8.111 Dec 10 21:45:24 dnsmasq[3225]: forwarded awk.epgsky.com to 79.79.79.78 Dec 10 21:45:24 dnsmasq[3225]: reply awk.epgsky.com is <CNAME> Dec 10 21:45:24 dnsmasq[3225]: reply awk.epgsky.com.edgekey.net is <CNAME> Dec 10 21:45:24 dnsmasq[3225]: query[A] init.sky.com from 10.88.8.111 Dec 10 21:45:24 dnsmasq[3225]: cached init.sky.com is <CNAME> Dec 10 21:45:24 dnsmasq[3225]: cached init.sky.com.edgekey.net is <CNAME> Dec 10 21:45:24 dnsmasq[3225]: query[A] p.sky.com from 10.88.8.111 Dec 10 21:45:24 dnsmasq[3225]: forwarded p.sky.com to 79.79.79.78 Dec 10 21:45:24 dnsmasq[3225]: reply p.sky.com is <CNAME> Dec 10 21:45:24 dnsmasq[3225]: reply p.sky.com.edgekey.net is <CNAME> Dec 10 21:45:26 dnsmasq[3225]: query[A] config.skyq-b.interactive.sky.com from 10.88.8.111 Dec 10 21:45:26 dnsmasq[3225]: forwarded config.skyq-b.interactive.sky.com to 79.79.79.78 Dec 10 21:45:26 dnsmasq[3225]: reply config.skyq-b.interactive.sky.com is <CNAME> Dec 10 21:45:26 dnsmasq[3225]: reply config.skyq-b.interactive.sky.com.edgekey.net is <CNAME> Dec 10 21:45:27 dnsmasq[3225]: query[A] config.ott.sky.com from 10.88.8.111 Dec 10 21:45:27 dnsmasq[3225]: cached config.ott.sky.com is <CNAME> Dec 10 21:45:27 dnsmasq[3225]: cached config.ott.sky.com.edgekey.net is <CNAME> Dec 10 21:45:27 dnsmasq[3225]: forwarded config.ott.sky.com to 79.79.79.78 Dec 10 21:45:27 dnsmasq[3225]: forwarded config.ott.sky.com to 79.79.79.77 Dec 10 21:45:27 dnsmasq[3225]: forwarded config.ott.sky.com to 127.0.0.1 Dec 10 21:45:27 dnsmasq[3225]: reply config.ott.sky.com is <CNAME> Dec 10 21:45:27 dnsmasq[3225]: reply config.ott.sky.com.edgekey.net is <CNAME> Dec 10 21:45:27 dnsmasq[3225]: query[A] entity.search.sky.com from 10.88.8.111 Dec 10 21:45:27 dnsmasq[3225]: forwarded entity.search.sky.com to 79.79.79.78 Dec 10 21:45:27 dnsmasq[3225]: reply entity.search.sky.com is <CNAME> Dec 10 21:45:27 dnsmasq[3225]: reply freeflow2.entity.search.sky.com.edgesuite.net is <CNAME> Dec 10 21:45:28 dnsmasq[3225]: query[A] config.skyq-b.interactive.sky.com from 10.88.8.111 Dec 10 21:45:28 dnsmasq[3225]: cached config.skyq-b.interactive.sky.com is <CNAME> Dec 10 21:45:28 dnsmasq[3225]: cached config.skyq-b.interactive.sky.com.edgekey.net is <CNAME> Dec 10 21:45:28 dnsmasq[3225]: forwarded config.skyq-b.interactive.sky.com to 79.79.79.78 Dec 10 21:45:28 dnsmasq[3225]: reply config.skyq-b.interactive.sky.com is <CNAME> Dec 10 21:45:28 dnsmasq[3225]: reply config.skyq-b.interactive.sky.com.edgekey.net is <CNAME> Dec 10 21:45:28 dnsmasq[3225]: query[A] images.metadata.sky.com from 10.88.8.111 Dec 10 21:45:28 dnsmasq[3225]: forwarded images.metadata.sky.com to 79.79.79.78 Dec 10 21:45:28 dnsmasq[3225]: reply images.metadata.sky.com is <CNAME> Dec 10 21:45:28 dnsmasq[3225]: reply prdpdimages.opg.sky.com is <CNAME> Dec 10 21:45:28 dnsmasq[3225]: reply images.metadata.sky.com.edgekey.net is <CNAME> Dec 10 21:45:28 dnsmasq[3225]: query[A] analytics.faw.sky.com from 10.88.8.111 Dec 10 21:45:28 dnsmasq[3225]: /opt/share/diversion/list/blockinglist analytics.faw.sky.com is 10.88.8.3 Dec 10 21:45:29 dnsmasq[3225]: query[A] static.skyq-b.interactive.sky.com from 10.88.8.111 Dec 10 21:45:29 dnsmasq[3225]: forwarded static.skyq-b.interactive.sky.com to 79.79.79.78 Dec 10 21:45:29 dnsmasq[3225]: reply static.skyq-b.interactive.sky.com is <CNAME> Dec 10 21:45:29 dnsmasq[3225]: reply static.skyq-b.interactive.sky.com.edgekey.net is <CNAME> Dec 10 21:45:29 dnsmasq[3225]: query[A] metrics.sky.com from 10.88.8.111 Dec 10 21:45:29 dnsmasq[3225]: /opt/share/diversion/list/blockinglist metrics.sky.com is 10.88.8.3 Dec 10 21:45:30 dnsmasq[3225]: query[A] uk.imageservice.sky.com from 10.88.8.111 Dec 10 21:45:30 dnsmasq[3225]: forwarded uk.imageservice.sky.com to 79.79.79.78 Dec 10 21:45:30 dnsmasq[3225]: reply uk.imageservice.sky.com is <CNAME> Dec 10 21:45:30 dnsmasq[3225]: reply uk.imageservice.sky.com.edgekey.net is <CNAME> Dec 10 21:45:33 dnsmasq[3225]: query[A] qgo-desktop-sgw.skyanywhere.com from 10.88.8.111 Dec 10 21:45:33 dnsmasq[3225]: forwarded qgo-desktop-sgw.skyanywhere.com to 79.79.79.78 Dec 10 21:45:33 dnsmasq[3225]: reply qgo-desktop-sgw.skyanywhere.com is <CNAME> Dec 10 21:45:33 dnsmasq[3225]: reply ott-sgw.skyanywhere.com is 90.211.176.31
Are you sure the device you are using the SkyGo app on is actually using your LAN and is not bypassing the router's dnsmasq?
Usually it is best to not use the VPN DNS while attempting to collate the domains, unless that is what is desired.Yeah using SkyGo app on my Macbook connected to router via WiFi. I disable VPN and then remove the device from the VPN policy rules (to bypass the kill switch).
I doubt it...dnsmasq simply responds to a request, and with the three logging directives ACTIVE, simply writes the request/results to the file so how why/would a firewall rule block the write to disk?I wonder if some sort of IP rule is preventing it being logged?
Search the forum? but basically don't use Cloudflare DNS.....What is the "validation result is INSECURE" referencing?
Sorry for not helping sooner. My laptop was in the shop for an extended amount of time for repair.Now to tail and find Sky Go and BBC![]()
My DNS was Cloudflare - I don't use the VPN's DNSUsually it is best to not use the VPN DNS while attempting to collate the domains, unless that is what is desired.
Thanks, I did search DDG (not directly on SNB and didn't find anything (but also never thought to link it Cloudflare for some reason)Search the forum? but basically don't use Cloudflare DNS.....
e.g. Cloudflare is quirky for some users but not all....
Cloudflare DNSSEC INSECURE?
Ah thanks! I think I missed a trick here - I had this OFF. I've now switched to Router Mode. Hopefully that'll help. I had Static routes setup to avoid 8.8.8.8 on my Chromecast, but never looked at the DNSFILTER.Hint: Perhaps explicitly configure the DNSFILTER option to force the Mac to use the router DNS or even Google DNS for testing?
I appreciate this thanks! I am a little stuck on how to add this to the Script though... Could you point me in the right direction how to pull these IP's from GitHubSorry for not helping sooner. My laptop was in the shop for an extended amount of time for repair.
I have harvested the IPv4 addresses for BBC. It was the hardest site I've mined. I had to use a combination of techniques. I will post them on GitHub and update this post with the link.
UPDATE
There are three IPv4 files for BBC on the site https://github.com/Xentrk/Asuswrt-Merlin-Selective-Routing/tree/master.
They are:
You need all three for BBC to work. The first list is from the AS number for BBC. The BBC_IPLAYER list was created by collecting the hostnames from dnsmasq on the router and doing a lookup to get the IPv4 address. The BBC_WEB list was generate using the feature of IPSET to dynamically generate and collect the IPv4 addresses when using a web browser and iPad client. I have found that using a browser or iPad App to watch some streaming media services generates additional domains or IPv4 addresses when compared to a streaming media device.
You can use curl command to download them manually for now. e.g.I appreciate this thanks! I am a little stuck on how to add this to the Script though... Could you point me in the right direction how to pull these IP's from GitHub
I also notice (when trying to figure out the above) there is US region settings in the IPSET_Netflix.sh for pulling AWS JSON IP's... Should users in the EU etc be changing this setting?
Is worth adding SkyGo to you GitHub as listed here...?
/usr/sbin/curl --retry 3 "https://raw.githubusercontent.com/Xentrk/Asuswrt-Merlin-Selective-Routing/master/x3mRouting_BBC" -o "/opt/tmp/x3Routing_BBC"
Chk_Entware 'jq' || { echo -e "\a***ERROR*** Entware" $ENTWARE_UTILITY "not available";exit 99; }
# Download Amazon AWS json file
wget https://ip-ranges.amazonaws.com/ip-ranges.json -O /opt/tmp/ip-ranges.json
# Create IPSET lists
ipset create AMAZONAWS hash:net family inet hashsize 1024 maxelem 65536
#Pull all IPv4s listed for Amazon AWS
jq -r '.prefixes | .[].ip_prefix' < /opt/tmp/ip-ranges.json > /opt/tmp/AmazonAWS
ipset flush AMAZONAWS
awk '{print "add AMAZONAWS " $1}' /opt/tmp/AmazonAWS | ipset restore -!
iptables -t mangle -D PREROUTING -i br0 -m set --match-set x3mRouting_NETFLIX dst -j MARK --set-mark "$FWMARK_WAN" > /dev/null 2>&1
iptables -t mangle -A PREROUTING -i br0 -m set --match-set x3mRouting_NETFLIX dst -j MARK --set-mark "$FWMARK_WAN"
Thread starter | Title | Forum | Replies | Date |
H | Routing wireguard | VPN | 0 |
Welcome To SNBForums
