Selective Routing for Netflix
I ran it and now I see the IPs for Netflix and AmazonAWS. I wont be able to test it until I get home so I'll let you know.
Thank you.
I tested it and it works but once I reboot the router the rules are not staying. Should I be calling the script from nat-start?
Great. I wonder what the issue was before.
Call the script from /jffs/scripts/nat-start:
#!/bin/sh
sh /jffs/scripts/IPSET_Netflix.sh
It will then handle reboots, openvpn changes, etc... remember to make nat-start executable
#!/bin/sh
This is weird. I added it to ne-start and after rebooting I can see everything is added but I can't use Netflix or Amazon. If I run the script manually then I can access Amazon and Netflix.
Log is here https://pastebin.com/yZDHV8HC
So decided to start from the begining. Formarted /jffs/scripts/ then
- Setup VPN
- Setup AB-Solution
- Setup Skynet
- Setup Entware and package "jq"
- Added the steps to call script from /jffs/scripts/nat-start
Rebooted and no Netflix/Amazon
Amazon
Merlin@RT-AC86U-CE18:/tmp/home/root# ipset list AMAZONAWS
Type: hash:net
Revision: 6
Header: family inet hashsize 1024 maxelem 65536
Size in memory: 352
References: 1
Number of entries: 0
Members:
Netflix
Merlin@RT-AC86U-CE18:/tmp/home/root# ipset list NETFLIX
Type: hash:net
Revision: 6
Size in memory: 6880
References: 1
Number of entries: 106
Members:
23.246.0.0/18
185.9.188.0/22
23.246.15.0/24
IP Rule
Merlin@RT-AC86U-CE18:/jffs/scripts# ip rule
0: from all lookup local
9990: from all fwmark 0x7000/0x7000 lookup main
10101: from 192.168.1.126 lookup ovpnc1
32766: from all lookup main
32767: from all lookup default
iptables -nvL PREROUTING -t mangle --line
Merlin@RT-AC86U-CE18:/jffs/scripts# iptables -nvL PREROUTING -t mangle --line
Chain PREROUTING (policy ACCEPT 64018 packets, 28M bytes)
num pkts bytes target prot opt in out source destination
1 14939 11M MARK all -- tun11 * 0.0.0.0/0 0.0.0.0/0 MARK xset 0x1/0x7
2 86 4687 MARK tcp -- br0 * 0.0.0.0/0 0.0.0.0/0 match-set NETFLIX dst,dst MARK or 0x7000
3 0 0 MARK tcp -- br0 * 0.0.0.0/0 0.0.0.0/0 match-set AMAZONAWS dst,dst MARK or 0x7000
I manually run the script ./IPSET_Netflix3.sh and the Amazon address get added and I can play videos from Amazon and Netflix.
I then reboot. Netflix address are there but I can’t play anything. Amazon address are missing and I can’t play anything.
I run ./nat-start manually and everything works until the next reboot.
- Setup VPN
- Setup AB-Solution
- Setup Skynet
Amazon
Netflix
IP Rule
Need to verify that nat-start is being run at boot or if you bounce the WAN iface.
If you can run nat-start from the command line, then it must be executable. Execute the "chmod 755 nat-start" command just to make sure. That is how I have my permissions set. Make sure you are calling the correct script in nat-start. In the post above I used sh /jffs/scripts/IPSET_Netflix.sh as an example. But the revised script I posted is called IPSET_Netflix3.sh.
Go to the WAN page and select the Apply button on the bottom of the page. Then, check the system log to see if nat-start was called. Navigate to the System Log tab. In the web browser, do a Ctrl-F to open up a search on the page and search for nat-start. Here is a snip from mine.
Feb 26 01:25:22 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Feb 26 01:25:22 custom_script: Running /jffs/scripts/nat-start
Feb 26 01:25:23 (VPN_Routing2.sh): 27371 Starting... /jffs/scripts/VPN_Routing2.sh.
Is calling the script when I bounce it but I can't play Netflix or Amazon
00:34:33 (IPSET_Netflix.sh): 3022 Starting IPSET_Netflix.sh... /jffs/scripts/IPSET_Netflix.sh.
Mar 2 00:34:33 custom_script: Running /jffs/scripts/firewall-start (args: eth0)
Mar 2 00:34:33 miniupnpd[3080]: HTTP listening on port 35010
Mar 2 00:34:33 miniupnpd[3080]: Listening for NAT-PMP/PCP traffic on port 5351
Mar 2 00:34:33 Skynet: [INFO] Startup Initiated... ( banmalware autoupdate usb=/tmp/mnt/MERLINUSB )
Mar 2 00:34:35 custom_script: Running /jffs/scripts/dnsmasq.postconf (args: /etc/dnsmasq.conf)
Mar 2 00:34:35 Merlin: AB-Solution added entries via ab_dnsmasq_postconf.sh
Mar 2 00:34:35 Merlin: AB-Solution linked ab_dnsmasq_postconf.sh via /jffs/scripts/dnsmasq.postconf
Mar 2 00:34:36 ovpn-client1[1720]: event_wait : Interrupted system call (code=4)
Mar 2 00:34:36 ovpn-client1[1720]: vpnrouting.sh tun11 1500 1558 10.50.10.6 10.50.10.5 init
Mar 2 00:34:36 openvpn-routing: Configuring policy rules for client 1
Mar 2 00:34:36 openvpn-routing: Tunnel down - VPN client access blocked
Mar 2 00:34:36 ovpn-client1[1720]: /bin/ip route del 10.50.10.1/32
Mar 2 00:34:36 ovpn-client1[1720]: ERROR: Linux route delete command failed: external program exited with error status: 2
Mar 2 00:34:36 ovpn-client1[1720]: /bin/ip route del 107.182.230.214/32
Mar 2 00:34:36 ovpn-client1[1720]: /bin/ip route del 0.0.0.0/1
Mar 2 00:34:36 ovpn-client1[1720]: /bin/ip route del 128.0.0.0/1
Mar 2 00:34:36 ovpn-client1[1720]: Closing TUN/TAP interface
Mar 2 00:34:36 ovpn-client1[1720]: /bin/ip addr del dev tun11 local 10.50.10.6 peer 10.50.10.5
Mar 2 00:34:36 ovpn-client1[1720]: updown.sh tun11 1500 1558 10.50.10.6 10.50.10.5 init
Mar 2 00:34:37 rc_service: service 3438:notify_rc updateresolv
Mar 2 00:34:37 rc_service: waitting "stop_vpnclient1" via udhcpc ...
Mar 2 00:34:37 rc_service: udhcpc 3017:notify_rc stop_upnp
Mar 2 00:34:43 (IPSET_Netflix.sh): 3022 Ending IPSET_Netflix.sh... /jffs/scripts/IPSET_Netflix.sh.
Mar 2 00:34:45 rc_service: udhcpc 3017:notify_rc start_upnp
It doesn't add the address for Amazon
Type: hash:net
Revision: 6
Size in memory: 352
References: 1
Members:
I can see address for NETFLIX but I can't play anything. If I manually call ./nat-start then everything works until the next reboot.
Mar 2 00:39:49 (IPSET_Netflix.sh): 4767 Starting IPSET_Netflix.sh... /jffs/scripts/IPSET_Netflix.sh.
Mar 2 00:39:52 (IPSET_Netflix.sh): 4767 Ending IPSET_Netflix.sh... /jffs/scripts/IPSET_Netflix.sh.
Merlin@RT-AC86U-CE18:/jffs/scripts# ipset list AMAZONAWS
Type: hash:net
Revision: 6
Size in memory: 32288
References: 1
Number of entries: 687
Members:
54.239.104.0/23
205.251.247.0/24
52.94.116.0/22
13.112.0.0/14
52.95.0.0/20
52.15.0.0/16
52.95.249.0/24
54.252.0.0/16
13.228.69.0/24
52.94.199.0/24
54.240.226.0/24
54.240.232.0/22
52.15.247.208/29
205.251.254.0/24
13.248.16.0/21
54.239.0.80/28
18.224.0.0/14
52.66.0.0/16
35.158.136.0/24
52.94.252.0/23
52.94.206.0/23
18.231.0.0/16
52.92.84.0/22
79.125.0.0/17
52.94.8.0/24
35.160.0.0/13
176.34.64.0/18
54.231.160.0/19
52.119.208.0/23
52.94.248.48/28
18.253.0.0/16
52.119.196.0/22
18.228.0.0/16
174.129.0.0/16
52.144.194.128/26
103.8.172.0/22
18.216.0.0/14
In the OpenVPN client near the bottom of the page, there is the option to drop traffic if the tunnel goes down. Change it to No and test. Let me know what happens.
Same issue. After rebooting ipset list AMAZONAWS doesnt show any IPs
Type: hash:net
Revision: 6
Size in memory: 352
References: 1
Members:
I have to manually run the script to get it to work
System logs shows the script running after rebooting.
Feb 13 19:00:32 nat: apply nat rules (/tmp/nat_rules_eth0_eth0)
Feb 13 19:00:32 custom_script: Running /jffs/scripts/nat-start
Feb 13 19:00:32 (IPSET_Netflix.sh): 1107 Starting IPSET_Netflix.sh... /jffs/scripts/IPSET_Netflix.sh.
Feb 13 19:00:32 kernel: ip_set: protocol 6
Feb 13 19:00:32 custom_script: Running /jffs/scripts/firewall-start (args: eth0)
Feb 13 19:00:33 (IPSET_Netflix.sh): 1107 Ending IPSET_Netflix.sh... /jffs/scripts/IPSET_Netflix.sh.
Feb 13 19:00:33 rc_service: udhcpc 981:notify_rc start_upnp
Feb 13 19:00:33 rc_service: waitting "stop_upnp" via udhcpc ...
Feb 13 19:00:33 kernel: scsi 0:0:0:0: Direct-Access USB 2.0 USB Flash Drive 1100 PQ: 0 ANSI: 0 CCS
Maybe the script is running too early?
I suspect Entware has not yet been mounted on /tmp/opt, so the Entware utility 'jq' cannot be found.
You can either add a
sleep 10
in nat-start before calling @Xentrk's script, or @Xentrk can modify his script to wait until Entware is mounted.
sleep 10
Thanks for the help @Martineau. That makes sense. I will add a check for entware and post and update. I won’t be able to work on it until about 12 hrs from now. @robahearts will need to add the sleep 10 for now as a temporary work around. If believe @thelonelycoder has a check in his code for entware being mounted that I can incorporate into the script.
Just test for opkg and wait for it to be true, something like this:
i=10
until [ "$(which opkg)" ]; do
    i=$(($i-1))
    if [ "$i" -lt "1" ];then
        logger "Unable to start whatever for the reason ...."
        exit
    fi
    sleep 1
done
i=10
    i=$(($i-1))
        exit
    fi
    sleep 1
done
But what if the required Entware utility i.e. in this case 'jq' isn't installed? :eek:;)
e.g.
Chk_Entware      || { echo -e "\a***ERROR*** Entware not available";exit 99; }
or
Chk_Entware 'jq' || { echo -e "\a***ERROR*** Entware" $ENTWARE_UTILITY  "not available";exit 99; }
Chk_Entware () {
    # ARGS [wait attempts] [specific_entware_utility]
    local READY=1                   # Assume Entware Utilities are NOT available
    local ENTWARE="opkg"
    ENTWARE_UTILITY=                # Specific Entware utility to search for
    local MAX_TRIES=30
    if [ ! -z "$2" ] && [ ! -z "$(echo $2 | grep -E '^[0-9]+$')" ];then
        local MAX_TRIES=$2
    fi
    if [ ! -z "$1" ] && [ -z "$(echo $1 | grep -E '^[0-9]+$')" ];then
        ENTWARE_UTILITY=$1
    else
        if [ -z "$2" ] && [ ! -z "$(echo $1 | grep -E '^[0-9]+$')" ];then
            MAX_TRIES=$1
        fi
    fi
   # Wait up to (default) 30 seconds to see if Entware utilities available.....
   local TRIES=0
   while [ $TRIES -lt $MAX_TRIES ];do
      if [ ! -z "$(which $ENTWARE)" ] && [ "$($ENTWARE -v | grep -o "version")" == "version" ];then
         if [ ! -z "$ENTWARE_UTILITY" ];then            # Specific Entware utility installed?
            if [ ! -z "$($ENTWARE list-installed $ENTWARE_UTILITY)" ];then
                READY=0                                 # Specific Entware utility found
            else
                # Not all Entware utilities exists as a stand-alone package e.g. 'find' is in package 'findutils'
                if [ -d /opt ] && [ ! -z "$(find /opt/ -name $ENTWARE_UTILITY)" ];then
                fi
            fi
         else
            READY=0                                     # Entware utilities ready
         fi
         break
      fi
      sleep 1
      logger -st "($(basename $0))" $$ "Entware" $ENTWARE_UTILITY "not available - wait time" $((MAX_TRIES - TRIES-1))" secs left"
      local TRIES=$((TRIES + 1))
   done
   return $READY
Also you should fix the use of 'jq'
for IPv4 in `jq -r '.prefixes | .[].ip_prefix' < ip-ranges.json`
change to
for IPv4 in `jq -r '.prefixes | .[].ip_prefix' < /jffs/scripts/ip-ranges.json`
@robahearts. I hope the entware check will fix your issues.
Script updates include:
1. Fixed the use of jq by applying full directory path of ip-ranges.json file as noted by
@Martineau
2. Included check for entware mount. I need more time to take a look at the code @Martineau posted. Looks very thorough. I tested with the entware check code @thelonelycoder uses in servies-start before I saw the posts. Will look things over in more detail tomorrow.
3. Removed output messages for the code that checks if a shared whitelist file exists.
4. Warning messages that were generated when the script was executed the first time are now sent to /dev/null.
Thanks for the input everyone.
#!/bin/sh
# Script: IPSET_Netflix3.sh
# Author: Xentrk
# 3-Mar-2018 Version 3.1
# Thank you to @Martineau on snbforums.com for educating myself and others on Selective
# Routing using Asuswrt-Merlin firmware.
# Script Description:
# The purpose of this script is for selective routing of Netflix traffic using
# Autonomous System Numbers (ASNs). ASNs are assigned to entities such as Internet
# Service Providers and other large organizations that control blocks of IP addresses.
# Netflix and other services that use Amazon AWS servers are blocking VPN's.
# This script will
#   1. Create shared whitelist entry for ipinfo.io in /jffs/shared-SelectiveRouting-whitelist for use by AB-Solution and Skynet.
#      Otherwise, ipinfo.io may be blocked and the script will not work.
#    2. Obtain the IPv4 addresses used by Netflix and Amazon AWS USA from ipinfo.io.
#      IPv6 addresses are excluded in this version.
#   3. Create the IPSET list NETFLIX
#   4. Add the IPv4 address to the IPSET list NETFLIX
#   5. Route IPv4 addresses in IPSET list NETFLIX to WAN interface.
# Note 1: IPSET syntax differs between version 6 and 4.5
#             Syntax for ipset v6
#                ipset create WAN0 list:set
#                ipset add WAN0 setlist (e.g. SPEEDTEST)
#             for routers running ipset v4.5 (ipset -V)
#                ipset -N WAN0 setlist (e.g. SPEEDTEST)
# Note 2: In the event one needs to use IPv6 in the future, the syntax is: ipset -N NETFLIX-v6 hash:net family ipv6
# Note 3: Troubleshooting
#            You can use these sites for AS validation and troubleshooting to lookup ASNs:
#               https://bgp.he.net/AS16509 (Click on the prefixes tab to view IP addresses)
#               http://ipinfo.io/AS2906
# Note 4: Required OpenVPN Client Settings
#         - Redirect Internet Traffic = Policy Rules or Policy Rules (Strict)
#         - Others?
logger -t "($(basename $0))" $$ Starting IPSET_Netflix.sh..." $0${*:+ $*}."
# Uncomment for debugging
set -x
# Prevent script from running concurrently when called from nat-start
PROGNAME=$(basename "$0")
LOCKFILE_DIR=/tmp
LOCK_FD=200
lock() {
    local prefix=$1
    local fd=${2:-$LOCK_FD}
    local lock_file=$LOCKFILE_DIR/$prefix.lock
    # create lock file
    eval "exec $fd>$lock_file"
    # acquier the lock
    flock -n $fd \
        && return 0 \
        || return 1
eexit() {
    local error_str="$@"
    echo $error_str
    exit 1
main() {
    lock $PROGNAME \
        || eexit "Only one instance of $PROGNAME can run at one time."
# check shared-SelectiveRouting-whitelist so ipinfo.io is not blocked
# by AB-Solution and Skynet
# checking if shared-SelectiveRouting-whitelist exists
if [ -s "/jffs/shared-SelectiveRouting-whitelist" ];then
# file found, no further checks
else
# create shared white list for ABS and Skynet"
  echo "ipinfo.io" > /jffs/shared-SelectiveRouting-whitelist
fi
ipset create NETFLIX hash:net family inet hashsize 1024 maxelem 65536
#Pull all IPv4s listed for Netflix USA - AS2906
netsv4=`curl http://ipinfo.io/AS2906 2>/dev/null | grep -E "a href.*2906\/" | grep -v ":" |sed 's/^.*\">//; s/<.*//; /^\s*$/d'`
for net in $netsv4
do
  ipset add NETFLIX $net
done
unset netsv4
# Prevent entware funcion jq from executing until entware has mounted
RC='/opt/etc/init.d/rc.unslung'
i=30
until [ -x "$RC" ] ; do
  i=$(($i-1))
  if [ "$i" -lt 1 ] ; then
     logger "entware in error state which prevents script from running"
    exit
  fi
  sleep 1
done
# Download Amazon AWS json file
wget https://ip-ranges.amazonaws.com/ip-ranges.json -O /jffs/scripts/ip-ranges.json
# Create IPSET lists
ipset create AMAZONAWS hash:net family inet hashsize 1024 maxelem 65536
#Pull all IPv4s listed for Amazon AWS
do
  ipset add AMAZONAWS $IPv4
done
unset IPv4
#Create table to contain items added automatically by wan #
ip rule del prio 9990 > /dev/null 2>&1
ip rule add from 0/0 fwmark 0x7000/0x7000 table main prio 9990
iptables -t mangle -D PREROUTING -i br0 -p tcp -m set --match-set NETFLIX dst,dst -j MARK --set-mark 0x7000/0x7000 > /dev/null 2>&1
iptables -t mangle -A PREROUTING -i br0 -p tcp -m set --match-set NETFLIX dst,dst -j MARK --set-mark 0x7000/0x7000
iptables -t mangle -D PREROUTING -i br0 -p tcp -m set --match-set AMAZONAWS dst,dst -j MARK --set-mark 0x7000/0x7000 > /dev/null 2>&1
iptables -t mangle -A PREROUTING -i br0 -p tcp -m set --match-set AMAZONAWS dst,dst -j MARK --set-mark 0x7000/0x7000
logger -t "($(basename $0))" $$ Ending IPSET_Netflix.sh..." $0${*:+ $*}."
main
I was assuming that this is checked during install.
My code therefore is only delaying the start of some other code until entware is mounted and with it the already installed packages.
#!/bin/sh
Now your script may potentially wait up to 30 secs for Entware, it may be prudent to change the way your script is called from nat-start, as there is no reason why nat-start execution needs to be stalled unnecessarily.
Use
sh /jffs/scripts/IPSET_Netflix.sh &
Yes finally got it to work. Xentrk
The script is giving an error on the "else" under:
else
I had to #else in order to run it. I also have the sleep 10 under nat-start.
Thank you all for the help.
Embarrassed about the error :eek: But good news that it works :D.
I'll fix the error you received on the check for the existence of the whitelist file and update the code that checks for entware as well. We should then have a version that I can post on github rather than keeping the source code on the forum. I will need your help to test the updated script.
Also, please make the change the script is called per @Martineau recommendation.
I did some searching on the forum to see what issues others have had with entware. For example, what happens if someone removes the USB containing entware? I came across the wiki article on this topic (see Gotchas, Extended Boot Time section). Sounds like there have been some lively discussions on the delay loop in services start method vs moving the entware rc.unslung call to post-mount that I was not aware of.
AB4 will only use dnsmasq.postconf and post-mount. I have moved all code to linked files in these two.
I detect and act accordingly if entware is not found during boot or when a device is plugged in.
My new code works 100% reliable for all situations I played through. There are no delay routines at all in my scripts.
Either the Entware folder is present when post-mount runs or not. There is no if's and but's in my code for that.
