Is it possible, via pfsense, to selectively route applications/services like we've discussed? By that, what I mean is:
Set up multiple VPN connections / interfaces. E.g. UK/USA/JP/IE etc
Route, for example, BBC iPlayer traffic over UK VPN, Hulu over USA VPN etc and then everything else not fitting those traffic rules, route it over WAN
Does pfsense domain routing work like dnsmasq? Currently on my RT-AC5300 I have dnsmasq.conf.add and add my own domains there to run over separate Smart DNS IP's. That's all I do. It's a bit hit and miss though and now I find I want to route everything over VPN instead. Hopefully with a fast box it will help me get nice VPN speeds, enough to get 4K streams working properly.
Yes, selective routing you can choose what traffic to route to WAN or to one of several OpenVPN interfaces. Unbound is the DNS resolver in pfSense. Similar to dnsmasq but different too.
I plan to make selective routing on pfSense a topic of a future blog post once the 2.4.4 release is finalized as there are a lot of changes in pfBlockerNG in 2.4.4 when compared to the 2.4.3 release.
Assuming i can get this working for UK netflix, does this script mean that i do not need to set up ipset= in dnsmasq anymore as it'll refresh each time i reboot the router?
Netflix is working on this laptop (no WAN tunnel for this device) but is not working when i try using the app on my Amazon Fire TV device.
If i set a WAN tunnel for the Amazon Fire device, amazon and Netflix both play fine.
Please can someone help me debug this? what do you need? logs etc..
I would suggest the use of the script say every couple of weeks to flush the ipset and possibly remove obsolete entries.
Leaving dnsmasq to also update the ipset in real-time is also recommended - although I suspect there wouldn't be many additions that have yet to be propagated to the 'ipinfo' site.
So once a day using a cron schedule and also when the router is shutdown cleanly (see services-stop), backup the ipset to a USB drive, then to save time, whenever the router is rebooted simply restore the ipset backup.
Yes, but nat-start may be called twice during the boot process, and also whenever the WAN/firewall is restarted.
So if you have the ipset backup on a USB drive, then post-mount could be used or even init-start to ensure the ipset restore is only requested once during the boot process.
If I set a policy rule for the Amazon Fire to tunnel to WAN it works fine (as it should).
It has to be the Fire TV is going to some addresses that are not on my IPSET list.
I would like to compare the addresses, from the Fire TV, going out, when the device policy is set, with the addresses when selective routing is set. What's the best method for this please?
You can then read the file containing the domain names you harvested, perform an nslookup on each one to obtain the IPv4 addresses, and load the list to an ipset. Save each ipset list to a separate text file and do a diff to compare the two lists. For example
for domain_name in $(awk '{ print $1 }' /jffs/scripts/BBCdns)
do
for ip in $(nslookup $DNS | awk '/^Name:/,0{if (/^Addr/)print $3}'); do
ipset add IPLAYER $ip
done
done
I have just followed @Xentrk's 'harvesting' method by scanning dnsmasq log 'query' entries
DNSMASQ_LOG="/tmp/mnt/xxxxxxxx/dnsmasq.log"
DEVICE=10.88.8.155
for DNSQUERY in $(grep "query" $DNSMASQ_LOG | grep "$DEVICE" | grep "nflx" | awk '{ print $6 }' | sort -u )
do
#Say iptables -t mangle -D PREROUTING -i br0 -d $DNSQUERY -j MARK --set-mark 0x7000/0x7000
#Say iptables -t mangle -A PREROUTING -i br0 -d $DNSQUERY -j MARK --set-mark 0x7000/0x7000
echo -e $cBCYA"\t\tExtracted '"$DNSQUERY"'"
for IP in $(nslookup "$DNSQUERY" | grep -oE '([0-9]{1,3}\.){3}[0-9]{1,3}' | grep -v "127.0.0.1")
do
echo -en $cBRED
ipset test NETFLIX $IP
if [ $? -gt 0 ];then
echo -e $cBYEL"\t\tipset add NETFLIX" $IP
fi
done
done
Results:
Extracted 'ipv4-c001-lhr004-my-isp.1.oca.nflxvideo.net'
78.146.119.219 is NOT in set NETFLIX.
ipset add NETFLIX 78.146.119.219
Extracted 'ipv4-c002-lhr004-my-isp.1.oca.nflxvideo.net'
78.146.119.221 is NOT in set NETFLIX.
ipset add NETFLIX 78.146.119.221
Extracted 'ipv4-c002-sou001-my-isp.1.oca.nflxvideo.net'
78.146.119.61 is NOT in set NETFLIX.
ipset add NETFLIX 78.146.119.61
Extracted 'ipv4-c004-ltn001-my-isp.1.oca.nflxvideo.net'
78.146.119.49 is NOT in set NETFLIX.
ipset add NETFLIX 78.146.119.49
Extracted 'occ-0-1688-299.1.nflxso.net'
However, if dnsmasq is tracking (ipset=/nflxso.net/nflxvideo.net/NetflixUSA) , then my dnsmasq log shows that they were added to my ipset NetflixUSA:
Jun 25 14:58:16 dnsmasq[1639]: query[A] occ-0-1688-299.1.nflxso.net from 10.88.8.155
Jun 25 14:58:16 dnsmasq[1639]: forwarded occ-0-1688-299.1.nflxso.net to 9.9.9.9
Jun 25 14:58:16 dnsmasq[1639]: reply occ-0-1688-299.1.nflxso.net is 78.146.119.221
Jun 25 14:58:16 dnsmasq[1639]: reply occ-0-1688-299.1.nflxso.net is 78.146.119.219
Jun 25 14:59:05 dnsmasq[1639]: query[A] ipv4-c002-sou001-my-isp.1.oca.nflxvideo.net from 10.88.8.155
Jun 25 14:59:05 dnsmasq[1639]: forwarded ipv4-c002-sou001-my-isp.1.oca.nflxvideo.net to 9.9.9.9
Jun 25 14:59:05 dnsmasq[1639]: ipset add NetflixUSA 78.146.119.61 ipv4-c002-sou001-my-isp.1.oca.nflxvideo.net
Jun 25 14:59:05 dnsmasq[1639]: reply ipv4-c002-sou001-my-isp.1.oca.nflxvideo.net is 78.146.119.61
Jun 25 14:59:05 dnsmasq[1639]: query[A] ipv4-c002-lhr004-my-isp.1.oca.nflxvideo.net from 10.88.8.155
Jun 25 14:59:05 dnsmasq[1639]: forwarded ipv4-c002-lhr004-my-isp.1.oca.nflxvideo.net to 9.9.9.9
Jun 25 14:59:05 dnsmasq[1639]: ipset add NetflixUSA 78.146.119.221 ipv4-c002-lhr004-my-isp.1.oca.nflxvideo.net
Jun 25 14:59:05 dnsmasq[1639]: reply ipv4-c002-lhr004-my-isp.1.oca.nflxvideo.net is 78.146.119.221
Jun 25 15:00:04 dnsmasq[1639]: query[A] occ-0-1688-299.1.nflxso.net from 10.88.8.155
Jun 25 15:00:04 dnsmasq[1639]: forwarded occ-0-1688-299.1.nflxso.net to 9.9.9.9
Jun 25 15:00:05 dnsmasq[1639]: reply occ-0-1688-299.1.nflxso.net is 78.146.119.219
Jun 25 15:00:05 dnsmasq[1639]: reply occ-0-1688-299.1.nflxso.net is 78.146.119.221
Jun 25 15:00:06 dnsmasq[1639]: query[A] ipv4-c004-ltn001-my-isp.1.oca.nflxvideo.net from 10.88.8.155
Jun 25 15:00:06 dnsmasq[1639]: forwarded ipv4-c004-ltn001-my-isp.1.oca.nflxvideo.net to 9.9.9.9
Jun 25 15:00:06 dnsmasq[1639]: ipset add NetflixUSA 78.146.119.49 ipv4-c004-ltn001-my-isp.1.oca.nflxvideo.net
Jun 25 15:00:06 dnsmasq[1639]: reply ipv4-c004-ltn001-my-isp.1.oca.nflxvideo.net is 78.146.119.49
Jun 25 15:00:06 dnsmasq[1639]: query[A] ipv4-c001-lhr004-my-isp.1.oca.nflxvideo.net from 10.88.8.155
Jun 25 15:00:06 dnsmasq[1639]: forwarded ipv4-c001-lhr004-my-isp.1.oca.nflxvideo.net to 9.9.9.9
Jun 25 15:00:06 dnsmasq[1639]: ipset add NetflixUSA 78.146.119.219 ipv4-c001-lhr004-my-isp.1.oca.nflxvideo.net
Jun 25 15:00:06 dnsmasq[1639]: reply ipv4-c001-lhr004-my-isp.1.oca.nflxvideo.net is 78.146.119.219
Whilst useful in determining (in real-time) new Netflix related domains using the harvesting scripts, I'm not sure why @Xentrk would imply that it is necessary to create explicit iptables Netflix PREROUTING rules unless there is evidence that the dnsmasq technique no longer works?
DEVICE=10.88.8.155
do
do
echo -en $cBRED
fi
done
done
Results:
So not sure why @Xentrk would imply that additional scripts are required to create explicit iptables Netflix PREROUTING rules unless there is evidence that the dnsmasq technique no longer works?
Interesting this is what i get. Nothing in there about "netflix":
admin1@RT-AC86U:/tmp/mnt/sda1/adblocking/logs# cat netflix
Jun 25 18:10:28 dnsmasq[1585]: forwarded rgom10-en.url.trendmicro.com to 103.86.99.100
Jun 25 18:10:28 dnsmasq[1585]: forwarded rgom10-en.url.trendmicro.com to 103.86.96.100
Jun 25 18:10:28 dnsmasq[1585]: query[AAAA] rgom10-en.url.trendmicro.com from 127.0.0.1
Jun 25 18:10:28 dnsmasq[1585]: reply rgom10-en.url.trendmicro.com is <CNAME>
Jun 25 18:10:28 dnsmasq[1585]: reply trendmicro.com.edgesuite.net is <CNAME>
Jun 25 18:10:28 dnsmasq[1585]: reply a151.g.akamai.net is 42.99.128.161
Jun 25 18:10:28 dnsmasq[1585]: reply a151.g.akamai.net is 42.99.128.168
That trendmicro check happens each time i do a "check your network" on netflix on the Fire TV.
DEVICE=10.88.8.155
do
do
echo -en $cBRED
fi
done
done
Results:
I've added logging to my dnsmasq.conf.add and it's capturing data, however it's spamming the following:
Jun 25 21:56:52 dnsmasq[1698]: query[A] dns.msftncsi.com from 127.0.0.1
Jun 25 21:56:52 dnsmasq[1698]: cached dns.msftncsi.com is 131.107.255.255
Jun 25 21:56:57 dnsmasq[1698]: query[A] dns.msftncsi.com from 127.0.0.1
Jun 25 21:56:57 dnsmasq[1698]: cached dns.msftncsi.com is 131.107.255.255
Jun 25 21:57:02 dnsmasq[1698]: query[A] dns.msftncsi.com from 127.0.0.1
Jun 25 21:57:02 dnsmasq[1698]: forwarded dns.msftncsi.com to 103.86.99.100
Jun 25 21:57:02 dnsmasq[1698]: forwarded dns.msftncsi.com to 103.86.96.100
Jun 25 21:57:02 dnsmasq[1698]: reply dns.msftncsi.com is 131.107.255.255
Jun 25 21:57:07 dnsmasq[1698]: query[A] dns.msftncsi.com from 127.0.0.1
Jun 25 21:57:07 dnsmasq[1698]: cached dns.msftncsi.com is 131.107.255.255
Jun 25 21:57:12 dnsmasq[1698]: query[A] dns.msftncsi.com from 127.0.0.1
Jun 25 21:57:12 dnsmasq[1698]: cached dns.msftncsi.com is 131.107.255.255
Jun 25 21:57:17 dnsmasq[1698]: query[A] dns.msftncsi.com from 127.0.0.1
Jun 25 21:57:17 dnsmasq[1698]: cached dns.msftncsi.com is 131.107.255.255
Jun 25 21:57:22 dnsmasq[1698]: query[A] dns.msftncsi.com from 127.0.0.1
Jun 25 21:57:22 dnsmasq[1698]: cached dns.msftncsi.com is 131.107.255.255
Jun 25 21:57:27 dnsmasq[1698]: query[A] dns.msftncsi.com from 127.0.0.1
Jun 25 21:57:27 dnsmasq[1698]: forwarded dns.msftncsi.com to 103.86.99.100
When i do some button pushing on netflix (on the Fire TV) I dont see anything new in this list. If I run nslookup on netflix.co.uk it shows up. I thought that the list updates when any request happens?
