Thank you!
I'm going to take a little time to absorb that code and may have a few questions afterwards. Until starting this I have never written a single line of code in bash or for a router.
I have noticed that the script stops working on occasion (usually when I wake up in the morning). I assume that is what this is. Probably has a small part in the timing issue I previously mentioned too. I set a timer for the router to reboot at 5 AM so that will take care of most instances I think except when I'm on vacation and staying up late trying to learn the basics of a new programming language as well as routing basics.
That is if it only happens at 2 AM...
One more thing. I don't think you use Netflix if I remember right, but the hard coded DNS issue raised it's head again. I'm thinking about running a script that pulls in all known Netflix IPs from radb.net along with the other ipset-netmasq script to see if that catches everything. Any thoughts on this or better ideas?
Thanks again for your assistance. I have been reading for more than two weeks before I stumbled on this thread. You're a godsend.
