Selective Routing with Asuswrt-Merlin
Hi @Xentrk from the above post, I tried executing the script but for both of these lines:
iptables -t mangle -A PREROUTING -i br0 -p tcp -m set --match-set LAN_GW src,dst -j MARK --set-mark 0x7000/0x7000
iptables -t mangle -A PREROUTING -i br0 -p tcp -m set --match-set OVPNC1 src,dst -j MARK --set-mark 0x1000/0x1000
I received:
iptables: No chain/target/match by that name.
To recap, this is my configuration:
  1. On VPN Client GUI page, set Accept DNS Configuration = Exclusive
  2. Redirect Internet Traffic = Policy Rules (Strict)
  3. All entries from the policy routing table have been removed and Create NAT on tunnel is set to Yes.
  4. I have specified the VPN clients in the OVPNC1 file to list the ip address of the devices that will go thru the VPN.
I have verified the IPSET lists are populate for OVPNC1 and WAN_GW. The IP RULE confirms the rules are created. But issuing the above -t mangle command just throws iptables: No chain/target/match by that name.
Can something be blocking this script from running or creating the PREROUTING for LAN_GW/OVPNC1?
Kman, do you have the same router as me? AC68u?
I received:
Did you add the -D line first?
iptables -t mangle -D PREROUTING -i br0 -p tcp -m set --match-set LAN_GW src,dst -j MARK --set-mark 0x7000/0x7000
iptables -t mangle -D PREROUTING -i br0 -p tcp -m set --match-set OVPNC1 src,dst -j MARK --set-mark 0x1000/0x1000
What does this command show?
iptables --line -t nat -nvL
I saw this code in some scripts posted by others. Try adding it after the !#/bin/sh and before the fwmarks and tables are created to see if it helps.
for i in /proc/sys/net/ipv4/conf/*/rp_filter ; do
echo 0 > $i
done
Hopefully, someone else will be able to help.
Here are some other commands to debug:
route -n
ip route show table local
I'm afraid that does nothing.
Here are the contents of /etc/dnsmasq.cong file on a router I support.
https://pastebin.com/80mZTft3
Perhaps there is something else in here that is required to get logging working for you in addition to log-queries and log-facility options. But from what I have read, those two options should do it.
You may want to try adding the options for interfaces and the option domain-needed.
If that does not work, then I am out of ideas. You may want to start a new thread about getting dnsmasq to log your queries to see if you can get some help that way.
I saw this code in some scripts posted by others. Try adding it <snip> to see if it helps.
echo 0 > $i
done
This crucial code snippet was finally officially added to Firmware 380.63? (6-Nov-2016) so should already be standard on all current Firmwares (see script /usr/sbin/vpnrouting.sh to confirm)
echo 0 > $i
done
route -n
Yes I have added the -D and now also added the
echo 0 > $i
done
result:
+ iptables -t mangle -D PREROUTING -i br0 -p tcp -m set --match-set LAN_GW src,dst -j MARK --set-mark 0x7000/0x7000
+ iptables -t mangle -A PREROUTING -i br0 -p tcp -m set --match-set LAN_GW src,dst -j MARK --set-mark 0x7000/0x7000
+ iptables -t mangle -D PREROUTING -i br0 -p tcp -m set --match-set OVPNC1 src,dst -j MARK --set-mark 0x1000/0x1000
+ iptables -t mangle -A PREROUTING -i br0 -p tcp -m set --match-set OVPNC1 src,dst -j MARK --set-mark 0x1000/0x1000
@Rappy it is the same router as yours, AC68U.
Why is there also a dnsmasq.conf in the tmp/etc/ directory? This one has different config. Should I leave that one alone?
It is a symbolic link, /tmp/etc is the same as /etc. In my sftp gui, if I type /etc and hit enter, it resolves to /tmp/etc.
For me they are both different. The tmp one has none of the extra parameters I put in the other one.
Can you go to the root directory level (cd .. a few times) and enter the l s - a l | grep etc command (spaces between "l" and "s" and the dash and "a" and the "a" and "l" are added to get around blocks put in place by this technical forum site that does not allow me to enter basic linux commands in a forum post. :mad:
This is mine:
lrwxrwxrwx    1 admin    root             7 Oct  5 03:01 etc -> tmp/etc
Note the symbolic link with the arrow.
What does your report?
You mean like this? ;)
ls  -lah  /  |  grep   ">"
lrwxrwxrwx    1 admin    root           7 Oct  4 21:00 e tc -> tmp/e tc
lrwxrwxrwx    1 admin    root           8 Oct  4 21:00 home -> tmp/home
lrwxrwxrwx    1 admin    root           9 Oct  4 21:00 media -> tmp/media
lrwxrwxrwx    1 admin    root           7 Oct  4 21:00 mnt -> tmp/mnt
lrwxrwxrwx    1 admin    root           7 Oct  4 21:00 opt -> tmp/opt
lrwxrwxrwx    1 admin    root          13 Oct  4 21:00 root -> tmp/home/root
lrwxrwxrwx    1 admin    root           7 Oct  4 21:00 var -> tmp/var
You nailed it! I like your solution better. :D
That confirms the symbolic link of etc and tmp/etc...Still does not explain why you are seeing a different dnsmasq.conf. Should not be the case. If you navigate to /etc it should go to /tmp/etc. At least mine does. Well, you can go to /etc AND /tmp/etc and do the ls command and grep for dnsmasq.conf. Then, compare the timestamp on the file. If you rename the file in one directory, can you still list two different files?
That confirms the symbolic link of etc and tmp/etc...Still does not explain why you are seeing a different dnsmasq.conf. Should not be the case. If you navigate to /etc it should go to /tmp/etc. At least mine does. Well, you can go to /etc AND /tmp/etc and do the ls command and grep for dnsmasq.conf. Then, compare the timestamp.
They both now appear to match, but when I first change something in one of them, say to add some of the lines you suggested, it doesn't update in the other one. Then eventually the original (and the link) revert to the un adulterated config.
Restart dnsmasq then after verifying you have the log-queries and log-facility lines in dnsmasq.conf. The log-dhcp option should not be required for what we are trying to accomplish. Try doing a tail on the log file while surfing the web. Do you see entries being added?
If you do not see any logging to dnsmasq.conf, please start a new thread for the issue or install AB-Solution. The dnsmasq config that is installed as part of AB-Solution works and allows me to mine traffic for selective routing with no issues. You have the scripts. You just need the domain names to finish complete your objective.
Just an update, I ended up installing AB Solutions (which works great btw) and retried running the script, but the same errors:
Something is not right with iptables on your router. Please post the output of the commands below, along with your firmware and router so we can ask @RMerlin about it.
iptables --verbose -t mangle -vL PREROUTING
iptables --version
@Rappy, I think this may be the missing piece to getting dnsmasq logging working for you. Can you check these settings?
In dnsmasq.conf file, have an entry like the following:
resolv-file=/tmp/resolv.conf
In the resolv.conf file, add:
nameserver 127.0.0.1
On my system, /etc/tmp/resolv.conf is a link to /rom/etc/resolv.conf
lrwxrwxrwx    1 admin    root            20 Oct 13 14:07 resolv.conf -> /rom/etc/resolv.conf
iptables --version
Please see below. Note, I have altered IP add. Router: AC68U, fw 380.68_4.
admin@RT-AC68U:/tmp/home/root# iptables --verbose -t mangle -vL PREROUTING
Chain PREROUTING (policy ACCEPT 13M packets, 12G bytes)
 pkts bytes target     prot opt in     out     source               destination
3049K 3769M MARK       all  --  tun11  any     anywhere             anywhere             MARK xset 0x1/0x7
 6548  929K MARK       all  --  tun21  any     anywhere             anywhere             MARK xset 0x1/0x7
 8064  614K MARK       all  --  !ppp0  any     anywhere             cwcwddd.dsl.ca       MARK or 0x8000
libiptc vlibxtables.so.7. 1872 bytes.
Table `mangle'
Hooks: pre/in/fwd/out/post = 0/260/2f8/428/4c0
Underflows: pre/in/fwd/out/post = 1c8/260/390/428/4c0
Entry 0 (0):
SRC IP: 0.0.0.0/0.0.0.0
DST IP: 0.0.0.0/0.0.0.0
Interface: `tun11'/XXXXXX..........to `'/................
Protocol: 0
Flags: 00
Invflags: 00
Counters: 3049351 packets, 3768950264 bytes
Cache: 00000000
Target name: `MARK' [40]
Entry 1 (152):
Interface: `tun21'/XXXXXX..........to `'/................
Protocol: 0
Flags: 00
Invflags: 00
Counters: 6548 packets, 929435 bytes
Cache: 00000000
Entry 2 (304):
DST IP: 99.128.150.121/255.255.255.255
Interface: `ppp0'/XXXXX...........to `'/................
Protocol: 0
Flags: 00
Invflags: 01
Counters: 8064 packets, 613533 bytes
Cache: 00000000
Entry 3 (456):
Interface: `'/................to `'/................
Protocol: 0
Flags: 00
Invflags: 00
Counters: 12997572 packets, 11708616915 bytes
Cache: 00000000
Target name: `' [40]
verdict=NF_ACCEPT
Entry 4 (608):
Protocol: 0
Flags: 00
Invflags: 00
Counters: 3974696 packets, 4160325173 bytes
Cache: 00000000
verdict=NF_ACCEPT
Entry 5 (760):
SRC IP: 192.168.1.0/255.255.255.0
DST IP: 192.168.1.0/255.255.255.0
Interface: `'/................to `br0'/XXXX............
Protocol: 0
Flags: 00
Invflags: 00
Counters: 13158 packets, 6804359 bytes
Cache: 00000000
Entry 6 (912):
Protocol: 0
Flags: 00
Invflags: 00
Counters: 9022106 packets, 7548259449 bytes
Cache: 00000000
verdict=NF_ACCEPT
Entry 7 (1064):
Protocol: 0
Flags: 00
Invflags: 00
Counters: 3141498 packets, 1734310330 bytes
Cache: 00000000
verdict=NF_ACCEPT
Entry 8 (1216):
Protocol: 0
Flags: 00
Invflags: 00
Counters: 12164356 packets, 9282803322 bytes
Cache: 00000000
verdict=NF_ACCEPT
Entry 9 (1368):
Protocol: 0
Flags: 00
Invflags: 00
Counters: 0 packets, 0 bytes
Cache: 00000000
Target name: `ERROR' [64]
error=`BWDPI_FILTER'
Entry 10 (1544):
Protocol: 0
Flags: 00
Invflags: 00
Cache: 00000000
verdict=RETURN
Entry 11 (1696):
Protocol: 0
Flags: 00
Invflags: 00
Cache: 00000000
error=`ERROR'
admin@RT-AC68U:/tmp/home/root# iptables --version
iptables v1.4.14
Table `mangle'
Entry 0 (0):
Protocol: 0
Flags: 00
Invflags: 00
Cache: 00000000
Entry 1 (152):
Protocol: 0
Flags: 00
Invflags: 00
Cache: 00000000
Entry 2 (304):
Protocol: 0
Flags: 00
Invflags: 01
Cache: 00000000
Entry 3 (456):
Protocol: 0
Flags: 00
Invflags: 00
Cache: 00000000
verdict=NF_ACCEPT
Entry 4 (608):
Protocol: 0
Flags: 00
Invflags: 00
Cache: 00000000
verdict=NF_ACCEPT
Entry 5 (760):
Protocol: 0
Flags: 00
Invflags: 00
Cache: 00000000
Entry 6 (912):
Protocol: 0
Flags: 00
Invflags: 00
Cache: 00000000
verdict=NF_ACCEPT
Entry 7 (1064):
Protocol: 0
Flags: 00
Invflags: 00
Cache: 00000000
verdict=NF_ACCEPT
Entry 8 (1216):
Protocol: 0
Flags: 00
Invflags: 00
Cache: 00000000
verdict=NF_ACCEPT
Entry 9 (1368):
Protocol: 0
Flags: 00
Invflags: 00
Cache: 00000000
Entry 10 (1544):
Protocol: 0
Flags: 00
Invflags: 00
Cache: 00000000
verdict=RETURN
Entry 11 (1696):
Protocol: 0
Flags: 00
Invflags: 00
Cache: 00000000
error=`ERROR'
iptables v1.4.14
It appears you may have the same iptables issue as @Ted Danson does with iptables on the AC68U.
https://www.snbforums.com/threads/u...te-domains-to-a-vpn-client.41560/#post-351464. I've never had a problem with it. I hope the community can help on this issue.
