Selective TOR by destination URL?
There are no plans to do any further development on the Tor implementation. It's available only because the code was already there, it was just a matter of enabling it.
Alright. Thanks for getting back, anyway.
Hope, anything possible here with custom scripts...
If you setup Entware on the router, then you may install the Privoxy package. You may configure Privoxy as an HTTP proxy that forwards to TOR. Privoxy also supports user action on the URL pattern that can forward to TOR or not.
Thanks, interesting idea!
Privoxy is a good option. In case, you don't want all features but simply URL redirection, lighttpd is a better choice...less a resource hog
