Serial console port on L2 managed switch & iMac MAVERICKS
oymd
Aloha everyone
I have a TP-Link SG3109 9 port L2 Managed Gigabit Switch.
I am trying to communicate with it through my iMac for the past 2 days, but I have miserably failed.
The switch has a SERIAL PORT, and also a Web enabled interface.
I am unable to log on to it, as the IP address in the PDF manual is: 192.168.0.1 or 192.168.1.1 and typing in the FIRST only brings up my SKY ROUTER'S web page, and the SECOND fails to bring up anything.
The manual says I need to setup the switch FIRST via the serial connector and to access the CONSOLE, so I bought off Amazon a SERIAL TO USB connection, which came with some PROLIFIC drivers.
Some research on the net pointed me to some more recent drivers for PROLIFIC PL2303 chip in MAVERICKS OSX, which I've downloaded and installed.
I also downloaded some terminal programs like COOLTERM and SECURECRT, BUT I HAVE NO CLUE HOW TO USE THEM OR EVEN COMMUNICATE with the switch....I can't type anything in those terminal programs, and I'm at a loss!!??
I also saw some threads explaining how to use terminal, but again it's all code and very difficult to understand.
Can someone please explain a SIMPLE way to do this...
Or in plain English??
Many thanks
You need to
1) Get the terminal program listening on the right interface (you're on your own there, maybe it's called ttyUSB)
2) Define the parameters for the session:
Bits per second
: 38400 for TL-SG3109, TL-SL3452, TL-SL3428 , TL-SL5428E ;
Data bits : 8
Parity : None
Stop bits : 1
Flow control : None
Once these two are done, you should be able to connect and interact with the session.
You need to
Bits per second
Data bits : 8
Parity : None
Stop bits : 1
Flow control : None
I'm currently stuck at finding the right drivers for my USB/SERIAL cable..!!
