Hi, I wanted to set up a router VPN on my AC68U. I installed asuswrt_Merlin for that, and I see it's possible to create a VPN tunnel & set certain IPs to use VPN, exclude others. However, the only way to change from using the tunnel to not using it is by manually moving the IP.
Is it possible to create 2 separate groups? I want 1 group to go through VPN and another group to bypass the VPN, both on the same router. If I am on the VPN group and want to switch to the other group, I want to be able to reconnect to other group. Is that possible with the AC68 or perhaps another Asus router??
Is my only option to purchase a 2nd router and have 2 separate networks running simultaneously on the same WAN? I would love to be able to use a single router for this purpose, but perhaps I'm asking for too much.
If what I'm asking for not possible, is it possible to create a whitelist to exclude certain apps from using the VPN tunnel? Certain services like Amazon, Netflix and online banking are very good at detecting VPNs so it would be nice to whitelist those. Again, I might be asking for the impossible, but I'm trying to get a network-wide VPN & exclude certain things when and only if they cause an issue.
