Setting up WireGuard Server and Connecting — No access.
Jan 9 18:15:52 rc_service: httpd 1562:notify_rc restart_wgs;restart_dnsmasq;
Jan 9 18:15:52 custom_script: Found service-event, but script is not set executable!
Jan 9 18:15:52 wsdd2[6312]: Terminated received.
Jan 9 18:15:52 wsdd2[6312]: terminating.
Jan 9 18:15:52 Samba_Server: smb daemon is stopped
Jan 9 18:15:52 Samba_Server: daemon is started
Jan 9 18:15:52 WireGuard: Starting server.
Jan 9 18:15:52 custom_script: Running /jffs/scripts/service-event-end (args: restart wgs)
Jan 9 18:15:52 wsdd2[13270]: starting.
Jan 9 18:15:52 dnsmasq[1550]: exiting on receipt of SIGTERM
Jan 9 18:15:52 custom_config: Appending content of /jffs/configs/dnsmasq.conf.add.
Jan 9 18:15:52 dnsmasq[13274]: started, version 2.89 cachesize 1500
Jan 9 18:15:52 dnsmasq[13274]: asynchronous logging enabled, queue limit is 5 messages
Jan 9 18:15:52 dnsmasq-dhcp[13274]: DHCP, IP range 192.168.103.2 -- 192.168.103.254, lease time 1d
Jan 9 18:15:52 dnsmasq-dhcp[13274]: DHCP, IP range 192.168.101.2 -- 192.168.101.254, lease time 1d
Jan 9 18:15:52 dnsmasq-dhcp[13274]: DHCP, IP range 192.168.102.2 -- 192.168.102.254, lease time 1d
Jan 9 18:15:52 dnsmasq[13274]: using only locally-known addresses for xxxxx.net
Jan 9 18:15:52 dnsmasq[13274]: read /etc/hosts - 105 names
Jan 9 18:15:52 dnsmasq[13274]: using nameserver 103.86.96.100#53
Jan 9 18:15:52 dnsmasq[13274]: using nameserver 103.86.99.100#53
Jan 9 18:15:52 dnsmasq[13274]: using nameserver 1.1.1.1#53
Jan 9 18:15:52 dnsmasq[13274]: using nameserver 8.8.8.8#53
Jan 9 18:15:53 custom_script: Running /jffs/scripts/service-event-end (args: restart dnsmasq)
I've tried to change the keepalive time at server.
Well. I can confirm that the problem gone with the original Asus firm.
Even the last merlin beta fails.
Same config, only replacing the firm.
