Johno
I've installed Wireguard server on a Raspberry Pi3 and have it configured to run as a service listening on a specified port, with all UDP traffic to the specified port on the WAN's static IP address forwarded to the Pi3. With the Wireguard client installed on a laptop connected to the same wireless network, activating the WG client connection causes the following log warning:
2020-05-03 00:20:21.984: [TUN] [SP4] peer(A/BI…7rTY) - Handshake did not complete after 5 seconds, retrying (try 2)
The server endpoint is defined as my router's public IP address and port number but I'm wondering if a laptop on the same network as the WG server would have it's traffic bypass the WAN interface and hence the port forwarding and hence not be directed to the Raspi3 and so the WG client can't connect to the WG server?
I've tethered the same laptop to my smartphone's WiFi hotspot so that the WG client is talking to the router from outside the LAN via the phone's mobile data network but still no difference - the WG client log still shows the "handshake did not complete" warning and no connection is established with the WG server.
Can anyone suggest whether any router settings will affect the connection? I read something on another post about disabling NAT acceleration doing the trick so I've done the same, but to no avail.
Any ideas anyone?
Any ideas anyone?
