Settings Capture
KenEsq
Is there a tool that can either read the settings backup file or can parse through the router and create a text file of all the settings.
Trying to remember (or read screenshots) of everything I've changed/configured when cleaning nvram always leads to a problem or two.
Keep a text backup of it. Assuming a USB disk mounted as sda1, for example:
nvram show | sort > /mnt/sda1/settings.txt
You mean create one by hand or is there a tool that will generate a text file of all the current settings?
I'm not complaining, just trying to figure out the best way to do this for multiple routers/APs.
The command I wrote will generate that text file if you run it over SSH/Telnet.
