ogre
I have a wired backbone in my house and a RT-AC66U in one corner of the house and an RT-AC87U in another corner on the other floor.
Both setup as APs and configured with Roaming assistant enabled (defaulting to -70dB)
same SSID for 5GHz, but set on different channels (36 and 44).
Works great for the most part, but sometimes my Nexus 6 just stops working - it indicates signal, but no network access at all. If I power cycle the wifi on it it works again, connecting to the AP with the strongest signal.
Are there any other settings to consider for my setup or is the fault solely on the Nexus 6 side?
